Re: Test report QuickFuel 4150 1050 cfm main body [Re: QWK_ENUF] #666762
11/22/10 02:25 AM
11/22/10 02:25 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Thanks Tommy! Did you buy the 1050 main body from pro-form..or Quick Fuel??? I couldn't find it on the QF web site!
Re: Test report QuickFuel 4150 1050 cfm main body [Re: Labratt] #666763
11/22/10 08:49 AM
11/22/10 08:49 AM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
Quick fuel makes Proform. They have lots of combo's that are not on their website.
Re: Test report QuickFuel 4150 1050 cfm main body [Re: VanishPt] #666764
11/22/10 10:21 AM
11/22/10 10:21 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Jesse uses these same proform main bodies in his carbs,says their a very nice piece. the 950 main bodies have a 1.375 venturi. prosystems 1000hp has a 1.585 venturi. the bigs 950 stage 5 plus uses a 850 proform main body with 1.400 venturi. the main body works awsome on my 408 combo. i agree with the others,the proform main bodies are a nice piece. i would'nt use the annular booster in a 4150 main body. the big booster fills up the venturi and does'nt allow enough room for air to get thru.
Re: Test report QuickFuel 4150 1050 cfm main body [Re: Labratt] #666765
11/22/10 01:58 PM
11/22/10 01:58 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
Get the proform 1050 main body thru Jegs or summit or get one thru CRT Cope racing Transmissions. They are 5.00 cheaper at CRT.
WAXER
Re: Test report QuickFuel 4150 1050 cfm main body [Re: QWK_ENUF] #666766
11/22/10 05:59 PM
11/22/10 05:59 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
Will the boosters need changing for e85?
Re: Test report QuickFuel 4150 1050 cfm main body [Re: supercomp] #666767
11/22/10 09:47 PM
11/22/10 09:47 PM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
no, good as is
WAXER
Re: Test report QuickFuel 4150 1050 cfm main body [Re: QWK_ENUF] #666768
11/22/10 11:35 PM
11/22/10 11:35 PM
PA
ajcasini Offline
ajcasini  Offline
PA
What size boosters are in the main body? I am thinking I may try one of these main bodies as well on an E85 setup for my engine combo next season.
Re: Test report QuickFuel 4150 1050 cfm main body [Re: ajcasini] #666769
08/31/11 01:23 PM
08/31/11 01:23 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Jegs part# is 793-6-1050 $221.99
Re: Test report QuickFuel 4150 1050 cfm main body [Re: b1dartsport] #666770
09/01/11 02:02 PM
09/01/11 02:02 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I run a 1050AN QF that I bought used from a MOPARTS member several years back. I called Quick Fuel and they gave me ALL the specs to set it up. I really like the carb and the service from QF. Quality piece.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
