Re: How loud are the Dynomax Super Turbo? (audio added) [Re: Ronnman] #666457
04/12/10 08:35 PM
04/12/10 08:35 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I will also add that I am running the larger case "hemi" dynomax, for improved flow..(normally recommended for Motorhome or towing or truck apps.) They fit a B or C body fine, I am not sure about A body..
The car picked up a ton of power from the repo factory style mufflers I replaced..
On my Roadrunner project I sprung for some NOS Hush Thrush... and they are a lot louder...
Re: How loud are the Dynomax Super Turbo? (audio added) [Re: sthemi] #666458
04/12/10 08:45 PM
04/12/10 08:45 PM
Lenox Iowa
MMiller Offline
MMiller  Offline
Lenox Iowa
Hmm, cars must be alot louder inside then my truck. Anybody that is going to throw away thier Flowmasters can send them to me. My truck has 3" exhaust with crossover, Super 40's and tailpipes way out the back, and long tube headers up front. When I did drive it on the street it was quite enough not to cause any unwanted attention, had a nice rumble, and nice sound at WOT. This however is a full size truck with 8' bed too. Here is what is sounds like at 6000 rpms and a good load. The tailpipes point straight at the big chunk of steel behind my truck.
http://www.youtube.com/watch?v=gEzs3XmMqVs&NR=1
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver,
90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
Re: How loud are the Dynomax Super Turbo? (audio added) [Re: MMiller] #666459
04/12/10 09:49 PM
04/12/10 09:49 PM
IL
71383beep Offline
71383beep  Offline
IL
'73 GK6 Challenger Rallye - 340 4-Speed
Re: How loud are the Dynomax Super Turbo? (audio added) [Re: 71383beep] #666460
04/13/10 04:47 PM
04/13/10 04:47 PM
BDW Online content OP
BDW  Online Content OP
Sound great,
What kind of system do you have?
Re: How loud are the Dynomax Super Turbo? (audio added) [Re: BDW] #666461
04/14/10 07:30 AM
04/14/10 07:30 AM
IL
71383beep Offline
71383beep  Offline
IL
Like your post...super turbos on the TTI 2 1/2" X pipe system with their 1 7/8" headers.
I like them. Not too loud and not too soft. I guess they could be a tick louder at idle, but I don't care for flowmasters much.
Here's a vid with the hood open in the garage and a walk around the car to the back.
Re: How loud are the Dynomax Super Turbo? (audio added) [Re: 71383beep] #666462
04/14/10 07:59 AM
04/14/10 07:59 AM
germany
440sat72 Offline
440sat72  Offline
germany
i dont know wether that's been said already but it'll make a big difference wether you are using 2,5 or a 3" system. the cam will make a big difference, too.
Re: How loud are the Dynomax Super Turbo? (audio added) [Re: Ronnman] #666463
04/14/10 12:31 PM
04/14/10 12:31 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
cnxt - Not sure what you have now, but based on your sound clips, Dynomax Super Turbos will NOT be as loud. I posted below a chart of different mufflers with the decibel levels.
Ron
you know that by the videos I have found the superturbos look to be more noisy really than the ultarflows but I think is more high pitch related than effective NOISE...
Db measuremenst covers all the audio bandwidth, BUT the mid frequency are the most disturbing to the human at same leves than lower frequencies. So even getting same or more Db level on Ultraflows the lower frequency is less disturbing on them
Re: How loud are the Dynomax Super Turbo? (audio added) [Re: NachoRT74] #666464
04/14/10 01:11 PM
04/14/10 01:11 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
As I have had both on my car with an X-pipe, the ultraflows to me are quieter at cruising speeds. The straight through design vs. the turbo style seems to help it breath better at those rpms. Now I am referring to inside the car noise not exterior........but who cares about that!!
I am also working with 3" exhaust and 11:1 440.
Re: How loud are the Dynomax Super Turbo? (audio added) [Re: BDW] #666465
04/14/10 02:46 PM
04/14/10 02:46 PM
Shoreline, Washington
72roadrunnergtx Offline
440 with 2” TTI headers into their 3” “x-pipe “ system including the Dynomax mufflers.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: How loud are the Dynomax Super Turbo? (audio added) [Re: 72roadrunnergtx] #666466
04/14/10 04:00 PM
04/14/10 04:00 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
2-1/2" TTi with SuperTurbo's.
IMHO,they are the best sounding muffs for Mopars.
Leave the Flowmasters for the BBC and 5.0L crowd.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: How loud are the Dynomax Super Turbo? (audio added) [Re: 68Cbarge] #666467
04/14/10 07:37 PM
04/14/10 07:37 PM
I really appreciate the replies, I'm pretty sure I'll go with the super turbos they offer on the standard system.
Re: How loud are the Dynomax Super Turbo? (audio added) [Re: BDW] #666468
04/14/10 09:27 PM
04/14/10 09:27 PM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
tti exhaust 3" dynomax turbo's
Re: How loud are the Dynomax Super Turbo? (audio added) [Re: NachoRT74] #666469
04/15/10 07:47 PM
04/15/10 07:47 PM
That's a very interesting point, the human ear can really on hear between 500 - 2500Hz, the test methods for sound pressure levels (dBs) usually measure all the way up to 20,000Hz. So it's very possible that mufflers could "appear" louder on a standardize chart, when in practice the opposite could be true.
It's sorta like using a microscope to view a sign, then wondering why is appears fuzzy with just glasses.
Re: How loud are the Dynomax Super Turbo? (audio added) [Re: BDW] #666470
04/15/10 08:09 PM
04/15/10 08:09 PM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
here is my 360 dart with dynomax super turbos. tti headers, 3" pipe, magnaflow x-pipe, mufflers and 3" tail pipes. i went with the bigger case 3" muffler. the car is so nice and quiet inside now. i love it...
in person the car is deeper sounding and not quite as loud sounding. must have been an echo off the house or something..
http://www.abodyjoe.com/pictures/71%20Dart/exhaust/dart%20exhaust.avi
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: How loud are the Dynomax Super Turbo? (audio added) [Re: abodyjoe] #666471
04/15/10 08:35 PM
04/15/10 08:35 PM
Minnesota
Barnstorm Offline
Barnstorm  Offline
Minnesota
Mopar doesn't need muffs but my SS396 and my GMC Syclone sounded great...great CHEAP muff.
The little old lady from Pasadena is back!
Re: How loud are the Dynomax Super Turbo mufflers? [Re: DennisH ] #666472
04/15/10 08:45 PM
04/15/10 08:45 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
They sound good. No drone. TTI's w/Dynomax Turbos behind the 440. I open up the QTP's when i want to disturb the neighborhood.
Ditto..This is 2" header TTI system with a full 3" x-tube with Dynomax Super Turbo mufflers out the back valence with tips. Be advised that the tailpies and type of tips change the sound pretty significantly too. While I was installing the electric cutouts, I have the tailpipe removed. It's a lot deeper of an exhaust note and is significantly louder. Not much of a surprise there. http://www.facebook.com/video/video.php?v=253879558807&saved
After making this video clip, I demo'd the electric cutouts on Dennis's car and had to get some for myself. I added a short piece of pipe and an oval megaphone after them to smooth out the harshness of the sound. It makes a big difference with and without the megaphones on in the uncapped sound quality. The coolness factor is off the charts.
Re: How loud are the Dynomax Super Turbo mufflers? [Re: jbc426] #666473
04/15/10 08:47 PM
04/15/10 08:47 PM
Ditto.. http://www.facebook.com/video/video.php?v=253879558807&saved
Sounds pretty cool, got any pics of the install?
Re: How loud are the Dynomax Super Turbo mufflers? [Re: BDW] #666474
04/15/10 08:51 PM
04/15/10 08:51 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Not yet, but I'll get out there and shoot some and get them posted this weekend.
Re: How loud are the Dynomax Super Turbo mufflers? [Re: jbc426] #666475
04/15/10 09:02 PM
04/15/10 09:02 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
This is with TTI's 2.5" exhaust and dynomax super turbos.
http://www.youtube.com/watch?v=UzsQ0qMYTQQ
