Where to get and What brand 8 Bolt FLEX PLATE
#665544
04/09/10 07:27 PM
04/09/10 07:27 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
I need to get a new Flex Plate for the motor. Previous was a 6 bolt.... Now need a 8 bolt flex plate Any recomendations on where to get one,,, brand ?,,,etc ? part numbers welcome............ Also need to get a "bolt kit" for the flex plate.... Thanks in advance, DOUG
Re: Where to get and What brand 8 Bolt FLEX PLATE
[Re: 69CHARGERMD]
#665546
04/09/10 08:06 PM
04/09/10 08:06 PM
We use the B&M 8-bolt flexplate. It is round instead of diamond shaped.
#665547
04/09/10 08:24 PM
04/09/10 08:24 PM
I USE THE MOPAR PERFORMANCE ONE.for some reason i like the way it lines up and no issues with it. i recommend it. i use the ARP converter bolts. they are 12 point and its nice getting the whole wrench on the bolt and torque away. i use the mopar performance flex plate to crank bolts.nice and heavy duty.
#665548
04/09/10 08:24 PM
04/09/10 08:24 PM
69CHARGERMD
KENTUCKY
Poppa J, I only see one listed at Summit ( see link ), this is a 8 bolt they mention... Internal engine balance,,,( which i assume is what i need ),,, new motor,,,etc.... Can you look at the link,,,does this look like what i need ? ps,,they also mention the bolt kits ,,, 1/2 ",,,from MP,,,$ 59,,,YIKES,,,,, does this look correct ? thanks, Doug Chris ,,,any info on the MP plate,,,and ARP bolt kit? http://www.summitracing.com/parts/BMM-10231/
[Re: Lee446]
#665552
04/09/10 08:43 PM
04/09/10 08:43 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
We use the Turbo Action plate/bolt kit.Never any problems. www.turboaction.com
[Re: Lee446]
#665553
04/09/10 08:44 PM
04/09/10 08:44 PM
After breaking a couple of MP's I went to the B&M and never looked back.
how did you break a few of these flexplates??? what do you have 3000 hp?
#665554
04/09/10 09:05 PM
04/09/10 09:05 PM
Doug, That is the correct one. It is nessesary to buy new 7/16" crank bolts which are the hemi 8 bolt crank bolts. I have two or three MP performance 8 bolt SFI plates, we don't run them anymore so if you want to try on of those PM me your address and I will give you one. poppaj
[Re: ro23car]
#665556
04/09/10 09:09 PM
04/09/10 09:09 PM
i had an issue with the b&m plate the holes for the conveter didnt seem to line up properly and required some opening in the holes.
and wasnt happy with the quality.
#665557
04/09/10 09:11 PM
04/09/10 09:11 PM
poppaj, ill take one of the 8 bolt flexplates, since you still owe me for the msd crank trigger hardware, this would be a good tradeoff since the msd hardware cost me $100.00
#665558
04/09/10 09:28 PM
04/09/10 09:28 PM
69CHARGERMD
KENTUCKY
1/2 " ?
that is the size i saw on the jegs and summit site,,,,
[Re: 69CHARGERMD]
#665559
04/09/10 09:34 PM
04/09/10 09:34 PM
1/2 " ?
flexplate to crank bolts are 1/2 doug,
#665560
04/09/10 09:43 PM
04/09/10 09:43 PM
Doug, I always say 7/16" for some reason, they are 1/2". poppaj
#665561
04/09/10 09:48 PM
04/09/10 09:48 PM
69CHARGERMD
KENTUCKY
Thanks Jim,,,,Thanks Chris,,,,, I will keep ya'll posted,,,, Just got the motor back today,,,and need to start mocking some things up before i drop it in......... I am hoping i can make the CC event in May,,,,,,,,,, DOUG hopefully things will go off without a bang,,,,,,
[Re: 69CHARGERMD]
#665562
04/09/10 09:57 PM
04/09/10 09:57 PM
Good luck Doug with the install. Sure hope to see you at the CC event in May. Are you going to install 2-4's so you can run NSS?? poppaj
[Re: CrAzYMoPaRGuY]
#665564
04/10/10 08:09 AM
04/10/10 08:09 AM
69CHARGERMD
KENTUCKY
CrzyMoparGuy,,,what flex plate are you running ? Jim,,,nope,,no 2x4's for now,,,but i am "parts gathering" for the "new" build,,,for a NSS motor,,, Doug
[Re: 572B1]
#665566
04/10/10 08:27 AM
04/10/10 08:27 AM
i got a mp 8 bolt flexplate on all my cars. 65 dodge going low low 9's with 967 hp has one with no issues. i personally like them the best.
#665567
04/10/10 08:50 AM
04/10/10 08:50 AM
Posts: 1,647 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I use the Mopar Performance flexplate also. Been in for 3 years. I used the B&M flexplates before this. I had 4 or 5 of them crack around the flexplate holes, in 2 years. The holes are very close to the edge on the B&M flexplates. There is more metal around the flexplate holes on the mopar performance flex plates.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: Dartsport540]
#665568
04/10/10 08:53 AM
04/10/10 08:53 AM
I use the Mopar Performance flexplate also. Been in for 3 years. I used the B&M flexplates before this. I had 4 or 5 of them crack around the flexplate holes, in 2 years. The holes are very close to the edge on the B&M flexplates. There is more metal around the flexplate holes on the mopar performance flex plates. [IMG]http://www.bigblockdart.com/forum/attachment.php?attachmentid=6184[/IMG]
x2 that was the big problem.
[Re: BradH]
#665572
04/10/10 10:10 AM
04/10/10 10:10 AM
69CHARGERMD
KENTUCKY
Captain... These are the links with part numbers,,,at JEGS,,,, (Summit does NOT have the flexplate in stock,,,) http://www.jegs.com/i/Mopar%20Performance/312/P4529752AB/10002/-1?CT=999http://www.jegs.com/i/ARP/070/200-2905/10002/-1
[Re: 69CHARGERMD]
#665573
04/10/10 10:14 AM
04/10/10 10:14 AM
69CHARGERMD
KENTUCKY
ps,,,that second link does NOT include the covertor bolts,,,, Here are a few more part numbers,,,that were passed on to me,,, bolts dcc-4120464 flex plate to crank converter bolts arp-240-7302
[Re: BradH]
#665576
04/11/10 07:24 PM
04/11/10 07:24 PM
Dartsport540
Ringtown, Pa.
When I called Reactor, 2 years ago, they weren't making the 8 bolt flexplates anymore?? Maybe they started again??
