Re: gauge silliness
[Re: HealthServices]
#665354
04/09/10 05:46 PM
04/09/10 05:46 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Here is some of the grounds to your headlights. Notice there are several of them. Now, how do these grounds make it back to the [-] side of the battery? Thru the chassis, then the motor mount bolt, then thru the [-] cable? Or even worst thru the voltmeter negative and/or the temp guage wire and then thru the motor mount bolt? I hope not. Hopefully you have a cable directly from your [-] side of the battery to the chassis.
Re: gauge silliness
#665355
04/09/10 05:47 PM
04/09/10 05:47 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Do you have a good ground going from the chassis to the [-] battery?
If you do, then you still have to check these and well the other grounds. If you don't you know where your problem is.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
Re: gauge silliness
#665357
04/09/10 05:48 PM
04/09/10 05:48 PM
Posts: 5,037 hi
sharpie
Moparts Linguist
Moparts Linguist
hi
probably not.
So what all do you suggest I do?
Re: gauge silliness
[Re: sharpie]
#665358
04/09/10 05:51 PM
04/09/10 05:51 PM
Posts: 7,759 So Cal
HealthServices
So Cal
If you look at your wiring system you are providing power to everything. But just as important is the ground [-]. Are you providing a good ground to everything? The headlights require more power than just about everything else except for the starter. If you have a ground issue the headlights will tax it.
It is a good thing you only have a two headlight system, with a 4 headlight system if you were to put on the high beam you would either burn something out or the headlights would be even dimmer.
Edit: The other problem with dim headlights is voltage loss going thru the bulkhead, light switch, foot switch, bulkhead again, and finally the headlights. Voltage checks will verify where your losses are.
Allen
Re: gauge silliness
#665360
04/09/10 05:59 PM
04/09/10 05:59 PM
Posts: 7,759 So Cal
HealthServices
So Cal
But the proper fix is to put a ground from the battery [-] to the chassis, and a wire from the chassis to the engine block. Make sure the chassis ground for the wiper is good too as well as checking the other grounds. Notice how most battery grounds have a extra wire? this extra goes to the chassis. The Ground issue may not be your only problem but it is a good start. Especailly if you know you do not have a engine and chassis ground.
Allen
Re: gauge silliness
#665363
04/09/10 06:51 PM
04/09/10 06:51 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Ok check all grounds first, this includes... - the headlight grounds in the circuit pictured.
- engine to chassis ground
- chassis to battery ground
- Battery to chassis ground
- Check the ground you have at the wiper.
- check path of power to oil pressure guage and to temp guage.
Allen
Re: gauge silliness
#665365
04/09/10 07:23 PM
04/09/10 07:23 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
In an odd, way, grounds are more important than + voltage. No voltage, no output. If you have voltage but bad grounds, though, that voltage will find a different path to ground, and that's where some wierd stuff can happen.
And FWIW, that blue/black ignition feed shown in an earlier post is an adversary to us all. It connects to almost every ign-hot item, it reaches from the alternator to way up under the dash, yet it has no fusing on it whatsoever. At least my 70 300 didn't. DAMHIK.
Anyone doing extra wiring, wiring repairs, or just loves their car should review that circuit in a FSM and put an inline fuse in it somewhere!
Re: gauge silliness
[Re: Fury Fan]
#665366
04/13/10 02:50 PM
04/13/10 02:50 PM
Posts: 5,037 hi
sharpie
Moparts Linguist
Moparts Linguist
hi
I think I have an idea of what's going on now. I mapped my gauges, and if you look at the gauges that aren't responding, you can clearly see there is one circuit that they share with only each other - the grounding circuit. I'm going to doublecheck the grounds today by making new grounds for both the oil and volts and grounding them close (i.e. not through the bulkhead). I'll update this afternoon.
