Re: Challenger steering - lower bearing install help [Re: Challenger 1] #664656
04/22/10 12:02 PM
04/22/10 12:02 PM
Canada
GDB Offline
GDB  Offline
Canada
I was wondering if you have a part # for the lower bearing for a 74?
Re: Challenger steering - lower bearing install help [Re: GDB] #664657
04/22/10 01:18 PM
04/22/10 01:18 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yes I do, but not here in front of me now. I'll look it up tonight and post it.
Re: Challenger steering - lower bearing install help [Re: conv440] #664658
04/22/10 09:08 PM
04/22/10 09:08 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
Re: Challenger steering - lower bearing install help [Re: badblack68] #664659
04/23/10 10:34 AM
04/23/10 10:34 AM
Canada
GDB Offline
GDB  Offline
Canada
Thanks i can get plastic ones no problem, i am looking for metal one that came on 74's and was hoping Challenger 1 had a part # if it was still available through Chrysler.
Re: Challenger steering - lower bearing install help [Re: GDB] #664660
04/23/10 11:21 AM
04/23/10 11:21 AM
Cincinnati, Ohio
Cincinnati, Ohio
Thanks i can get plastic ones on Ebay no problem, i am looking for metal one that came on 74's and was hoping Challenger 1 had a part # if it was still available through Chrysler.
Dug out my reciepts,
The bearing support is 3748229 support S 19054003 list in 3-04 was 7.45 cost was 5.59
Bearing is # 4147318 Bearing S 19014004 list 10.45 cost was 7.84 in 3-04
If I remember right, he coundn't find # for the spring or the clip which I reused. It would not be hard to find a spring to retain the bearing and to make a clip, which is nothing more than a C clip made out of a heavy gauge wire.
These # are off of my receicpts and I'm 99% sure these are right for a 74. I hope they still have em.
Re: Challenger steering - lower bearing install help [Re: Challenger 1] #664661
04/23/10 11:53 AM
04/23/10 11:53 AM
Canada
GDB Offline
GDB  Offline
Canada
wow thats great, thanks. I do need a clip but i am sure i can rig up something.
Re: Challenger steering - lower bearing install help [Re: GDB] #664662
04/23/10 05:27 PM
04/23/10 05:27 PM
Canada
GDB Offline
GDB  Offline
Canada
As a follow up, i called my local Chrysler dealer and there is over a hundred of these listed on inventory at warehouse but the bearing support which i dont need, didnt come up as anything but lots of bearings though. Only $18 Canadian too!!!
Re: Challenger steering - lower bearing install help [Re: GDB] #664663
04/23/10 05:31 PM
04/23/10 05:31 PM
Cincinnati, Ohio
Cincinnati, Ohio
Good news, I maybe order me up another bearing or two, for stock.
The bearing support really shouldn't wear out so I could see them not stocking many of them.
Re: Challenger steering - lower bearing install help [Re: Challenger 1] #664664
04/23/10 11:27 PM
04/23/10 11:27 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
the new bearing that you get from chrysler is not even close to the original. It may work but the original is a far superior design
Re: Challenger steering - lower bearing install help [Re: prochargedhemi] #664665
03/26/11 02:43 PM
03/26/11 02:43 PM
Connecticut
biginchmotor Offline
Connecticut
I purchased the superseded # bearing 4147318. and I am not sure I am going to use it. It is not a sealed bearing, dirt/moisture can get in, inside diameter is slightly larger then the original making it sloppy on the shaft. Would like to know if someone has the original part # of the bearing before it was superseded to 4147318, John.
Re: Challenger steering - lower bearing install help [Re: JulesdaWiperman] #664666
03/26/11 08:16 PM
03/26/11 08:16 PM
cataclysm80 Offline
cataclysm80  Offline
Nice Thread, Lots of good info. Been a few years since I dug into a steering column, but I've been thinking about digging in again.
Tav
Re: Challenger steering - lower bearing install help [Re: biginchmotor] #664667
03/26/11 11:31 PM
03/26/11 11:31 PM
Cincinnati, Ohio
Cincinnati, Ohio
That's weird, because that bearing fit just right on the 2 71 and 74 columns that I have rebuilt.
Yea it's a open design bearing, but that's how Mopar made em.
A little grease packed in em will make last another 25 years.
Re: Challenger steering - lower bearing install help [Re: Challenger 1] #664668
10/25/11 11:38 PM
10/25/11 11:38 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
Sorry to dig up this old post. I am going to rebuild my 71 Floor shift column here shortly, and I am trying to convert to the 74 style bottom bearing setup.
I found the bearing available, but the retainer, which I believe is the metal sleeve (3748229) around it is no long available from Dodge. What else might it be on? Any floor shift column post 74?
