Re: Challenger steering - lower bearing install help
[Re: GDB]
#664657
04/22/10 01:18 PM
04/22/10 01:18 PM
Challenger 1
Cincinnati, Ohio
I was wondering if you have a part # for the lower bearing for a 74?
Yes I do, but not here in front of me now. I'll look it up tonight and post it.
[Re: badblack68]
#664659
04/23/10 10:34 AM
04/23/10 10:34 AM
Posts: 4 Canada
GDB
Canada
Thanks i can get plastic ones no problem, i am looking for metal one that came on 74's and was hoping Challenger 1 had a part # if it was still available through Chrysler.
[Re: GDB]
#664660
04/23/10 11:21 AM
04/23/10 11:21 AM
Challenger 1
Cincinnati, Ohio
Thanks i can get plastic ones on Ebay no problem, i am looking for metal one that came on 74's and was hoping Challenger 1 had a part # if it was still available through Chrysler.
Dug out my reciepts,
The bearing support is 3748229 support S 19054003 list in 3-04 was 7.45 cost was 5.59 Bearing is # 4147318 Bearing S 19014004 list 10.45 cost was 7.84 in 3-04
If I remember right, he coundn't find # for the spring or the clip which I reused. It would not be hard to find a spring to retain the bearing and to make a clip, which is nothing more than a C clip made out of a heavy gauge wire.
These # are off of my receicpts and I'm 99% sure these are right for a 74. I hope they still have em.
[Re: GDB]
#664663
04/23/10 05:31 PM
04/23/10 05:31 PM
Challenger 1
Cincinnati, Ohio
As a follow up, i called my local Chrysler dealer and there is over a hundred of these listed on inventory at warehouse but the bearing support which i dont need, didnt come up as anything but lots of bearings though. Only $18 Canadian too!!!
Good news, I maybe order me up another bearing or two, for stock. The bearing support really shouldn't wear out so I could see them not stocking many of them.
[Re: biginchmotor]
#664667
03/26/11 11:31 PM
03/26/11 11:31 PM
Challenger 1
Cincinnati, Ohio
I purchased the superseded # bearing 4147318. and I am not sure I am going to use it. It is not a sealed bearing, dirt/moisture can get in, inside diameter is slightly larger then the original making it sloppy on the shaft. Would like to know if someone has the original part # of the bearing before it was superseded to 4147318, John.
That's weird, because that bearing fit just right on the 2 71 and 74 columns that I have rebuilt.
Yea it's a open design bearing, but that's how Mopar made em. A little grease packed in em will make last another 25 years.
[Re: Challenger 1]
#664668
10/25/11 11:38 PM
10/25/11 11:38 PM
Posts: 10,514 Chicago, Illinois
Devil
Chicago, Illinois
Sorry to dig up this old post. I am going to rebuild my 71 Floor shift column here shortly, and I am trying to convert to the 74 style bottom bearing setup. I found the bearing available, but the retainer, which I believe is the metal sleeve (3748229) around it is no long available from Dodge. What else might it be on? Any floor shift column post 74? Thanks
