727 tailshaft cracked in two again. #663322
04/06/10 10:24 PM
04/06/10 10:24 PM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
I have about a 2" travel on my yoke that slips inside the tailshaft, Is that enough play to keep my driveshaft from hitting my tailshaft? How much play should I have?
1970 AAR CUDA 1970 Super Bee 383 Auto 1969 Super Bee 383 4Spd 1968 Satellite 500 Stroker 1986 Shelby GLHS 1970 Coronet 500 383 Auto 1996 Indy Pace Truck 1998 Dakota R/T 408 Stroker
Re: 727 tailshaft cracked in two again. [Re: 1AARCUDA] #663323
04/06/10 10:34 PM
04/06/10 10:34 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is it more than 3/4" out from being bottomed... whats
the rest of your set up... are you running front motor
plate and mid plate with a solid trans mount... I have
seen many tail shafts break from that set up... what
rear suspension
Re: 727 tailshaft cracked in two again. [Re: 1AARCUDA] #663324
04/06/10 10:34 PM
04/06/10 10:34 PM
the netherlands
3
383duster Offline
super street
383duster  Offline
super street
3
the netherlands
In my opinion that is 1" travel too much, 1" travel is normal and has always worked good for me.
did your tailshaft cracked with the 2" travel on the yoke? Then I think that the yoke was wobbling because it was not engaged enough on the shaft.
Re: 727 tailshaft cracked in two again. [Re: 1AARCUDA] #663325
04/06/10 11:03 PM
04/06/10 11:03 PM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
When everything is in place and my rear u joint is planted in my third member yoke without the u bolts connected, I can slide my shaft in the tail housing 2 inches til it hits the area behind the splines and bottoms out. I am running a 500 stroker with moroso solid motor mounts and stock 440 GTX leaf springs and a pinion snubber. Is that 2 inches to much play?
Re: 727 tailshaft cracked in two again. [Re: 1AARCUDA] #663326
04/06/10 11:11 PM
04/06/10 11:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Way too much..........I shoot for no more than 3/4`s of an inch myself and that`s w/Cal-tracs leaf springs and never an issue.
Re: 727 tailshaft cracked in two again. [Re: 1AARCUDA] #663327
04/06/10 11:14 PM
04/06/10 11:14 PM
Florida STAYcation
dOc ! Online penguin-006
The village idiot's idiot
dOc !  Online Penguin-006
Florida STAYcation
With the DS and UJ engaged into the yoke .. how much in-and-out play is there ? ...
Re: 727 tailshaft cracked in two again. [Re: 1AARCUDA] #663328
04/06/10 11:22 PM
04/06/10 11:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
WAY too much.... even in the tranny book it says
3/4"
Re: 727 tailshaft cracked in two again. [Re: MR_P_BODY] #663329
04/06/10 11:26 PM
04/06/10 11:26 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Are you checking the travel with the rear end at ride height or with the car jacked up with the axle hanging?
Re: 727 tailshaft cracked in two again. [Re: MR_P_BODY] #663330
04/06/10 11:28 PM
04/06/10 11:28 PM
Florida STAYcation
Florida STAYcation
Hay P ... 3/4 of an inch ? ... WOW ... if there was any real spring or pinion-angle movement .. it could bottom out.
I missed that post what you quoted. Knowing this ...I would think that there is either a bend D-shaft or the bushing IN the TS is worn-out and sloppy.
Re: 727 tailshaft cracked in two again. [Re: WILD BILL] #663331
04/06/10 11:29 PM
04/06/10 11:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Very true... with that much I sure hope its hanging,
shouldnt have more than 3/4" at curb height
Re: 727 tailshaft cracked in two again. [Re: dOc !] #663332
04/06/10 11:33 PM
04/06/10 11:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
3/4" at curb height that number comes from the 727
trans book( I forget the author but its the one everyone
uses)
Re: 727 tailshaft cracked in two again. [Re: MR_P_BODY] #663333
04/07/10 07:00 AM
04/07/10 07:00 AM
Greentown Indiana
moparmxz Offline
moparmxz  Offline
Greentown Indiana
My experience has been that most broken tailshafts come from a improperly shortened driveshaft(out of balance or a phasing problem).Of course lots of things could be happening,chassis flex,improper pinion angle,trans tailshaft bushing wore out. Heck even the trans shaft could be bent.Good luck
Randy Brough 1967 440 Dart S/P 6.37 106mph best eighth 3150 lbs
Re: 727 tailshaft cracked in two again. [Re: moparmxz] #663334
04/07/10 08:34 AM
04/07/10 08:34 AM
Tennessee
727builder Offline
727builder  Offline
Tennessee
Stock leaf springs are too weak for the power you putting out. Has too much pinion travel and under power the pinion is moving upward till it puts the u-joint in a bind then it cracks the tailhousing.
Re: 727 tailshaft cracked in two again. [Re: MR_P_BODY] #663335
04/07/10 09:17 AM
04/07/10 09:17 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I forget the author but its the one everyone uses
Carl Munroe
Re: 727 tailshaft cracked in two again. [Re: WILD BILL] #663336
04/07/10 09:19 AM
04/07/10 09:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Carl Munroe
Yeah... that be him... thanks Bill
Re: 727 tailshaft cracked in two again. [Re: 1AARCUDA] #663337
04/07/10 10:48 AM
04/07/10 10:48 AM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
The car is on jackstands with the jacks on the axle tubes. taking the driveshaft to get 2" cut off new u joints and rebalance.
Re: 727 tailshaft cracked in two again. [Re: 1AARCUDA] #663338
04/07/10 10:59 AM
04/07/10 10:59 AM
the netherlands
3
383duster Offline
super street
383duster  Offline
super street
3
the netherlands
I think it is better too add 1" , cutting off 2" wil give you 4" endplay
Re: 727 tailshaft cracked in two again. [Re: 383duster] #663339
04/07/10 12:13 PM
04/07/10 12:13 PM
Locomotion Offline
Locomotion  Offline
Consider all the possibilities that moparmxz mentioned. Also check the trans mount. If it has any age to it, replace it with a poly mount.
I've always tried to get as much slip-spline engagement as possible. 3/4" - 1" is enough to allow enough u-joint clearance to remove the driveshaft with weight on the rear suspension or the rear end hanging.
Re: 727 tailshaft cracked in two again. [Re: 383duster] #663340
04/07/10 02:43 PM
04/07/10 02:43 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
I hope he didn't leave yet.
codfish
Re: 727 tailshaft cracked in two again. [Re: 1AARCUDA] #663341
04/07/10 02:56 PM
04/07/10 02:56 PM
North Texas
1AARCUDA Offline OP
1AARCUDA  Offline OP
North Texas
Yes I left and I did double check and had them remove one inch only, Also After I removed my cracked housing I noticed that my shaft has some movement maybe a 1/8 inch side to side, is that normal?
