Re: 727 tailshaft cracked in two again.
[Re: 1AARCUDA]
#663342
04/07/10 03:00 PM
04/07/10 03:00 PM
Posts: 337 the netherlands
383duster
super street
super street
the netherlands
Yes I left and I did double check and had them remove one inch only,
So now your shaft wil have 3" endplay?
[Re: 1AARCUDA]
#663343
04/07/10 03:09 PM
04/07/10 03:09 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Let me get this straight, your first post said you had your yoke 2" sticking out. Every body said that was to much and should be 3/4" -1". Then you shorten the drive shaft 1" that would now make it three inches out ????????????? Hope you have more tail shafts as your going to need them. Oh there's one more thing, if you have one of the original type tail shaft boot seals that stick out 1 1/2" from the tail shaft, you need to run the yoke flush with that. ![](/ubbthreads/images/graemlins/drive.gif)
[Re: rowin4]
#663344
04/07/10 04:10 PM
04/07/10 04:10 PM
Posts: 1,443 Maryland
Dads426
Maryland
Back in the 70's we were busting tailshafts amost every weekend. Turned out that the driveshaft that was "balanced" by a reputible shop wasn't even close. Sent it to another shop and the problem stopped. Vibration was not noticable in the car.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: rowin4]
#663345
04/07/10 04:39 PM
04/07/10 04:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Let me get this straight, your first post said you had your yoke 2" sticking out. Every body said that was to much and should be 3/4" -1". Then you shorten the drive shaft 1" that would now make it three inches out ????????????? Hope you have more tail shafts as your going to need them. Oh there's one more thing, if you have one of the original type tail shaft boot seals that stick out 1 1/2" from the tail shaft, you need to run the yoke flush with that. ![](/ubbthreads/images/graemlins/popcrn.gif)
I have NO CLUE what he wants ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Dads426]
#663346
04/07/10 09:37 PM
04/07/10 09:37 PM
Posts: 1,090 Saskatchewan, Canada
barracudabob
Had the same problem last year. Got a new driveshaft from a reputable builder, and started breaking tailshaft housings. Took the shaft to another place to check balance, and it was way out. They fixed it, and no more problems.
