Re: Who else is running a Powerglide in their Mopar ?
[Re: a408swinger]
#663074
04/12/10 09:36 PM
04/12/10 09:36 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I picked up My rear engine dragster a few years ago. The guy had a shortie 727 and a 493 RB with Indy Heads...He was currently going 5.40-5.30's in the 8th mile 60ft was in the mid to upped 1 teens or so. I knew a 3 speed wasnt going to cut it in the dragster...It was a very heavy for dragstr with driver well over 2000+ lbs. But the driver is big guy too 6'4 and 270 lbs. Anyways I purchased the Power Glide Hand Book By Carl Monroe (sp)? Anyways. I went through about 6 cases before finding a good one. Purchased a shortie stock 1.76 gear set. Add a Billet clutch hub, new servo, 300M 350 input shaft picked up some thin clutches and plates to fit as many clutch discs possible in the front IIRC it was 7, and ended up with 5 out in the rear. Added a deep pan and trans brake. Set pack clearance to about .100-.120 in the rear, and about .070-.090 in the front, bought a used Coan converter, thow'd this junk together..First time I built a Glide. Went out and ran way down in the 4's in the 8th mile, and pulled consistent ONE flat 60 ft....This wasnt no one pass wonder either, dead heat in July... Two seasons later, the trans is still working fine with nothing more than stock parts. For the guys who probably picked up E/T in moderately heavy cars, with moderate HP over a 727..its simple...the cars wasnt set up properly, and was spinning..something...
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: a408swinger]
#663076
04/13/10 06:55 AM
04/13/10 06:55 AM
Posts: 429 Sherman Texas
The Shocker
Sherman Texas
No magic stall at all. My first converter was a Dynamic that Sean supposedly had set up for my combination. It was a 9" unit that went to 4800. I had also talked to JW and they just happened to call me back a few weeks later to see if I ever bought a converter. After telling him my combination he said no way did I need a 9" and 4800 was too tight. He told me he could build me an 8" that would run much better than the Dynamic unit. I took a chance and ordered it and sold my Dynamic. I put it in and it went to 5200-5300 and picked up .5 and 5 mph. It also worked great with nitrous. With a glide you want it to stall within 1000-1500 rpms of where you shift. If you shift at 7000 you want a converter that will flash to 5800-6000 when you launch the car.
Gotcha, does this 1000 -1500 stall below shift rpm theory apply to all cars regarldess of weight ,hp ,etc.Im not trying to ask a dumb question ,im just trying to learn .A convertor swap is needed on my car as well ,just wanting to get one thats right for my car ...
[Re: DJVCuda]
#663078
04/13/10 08:02 AM
04/13/10 08:02 AM
Posts: 414 pa
demongup
pa
lol... he HAD to make that last pass before lunch... meanwhile my pizza was getting cold!
c mon ,what's more important,food or racing?
[Re: Super Scamp]
#663079
04/13/10 08:05 AM
04/13/10 08:05 AM
Posts: 414 pa
demongup
pa
Well I thought this thread would be in the history books by now.. All you Street/Strip boy's need to stay with the 727 3 speed..3000lb cars need it.. for those cars in the 1800 to 2800 weight class run a Glide..
With comments like yours ,this thread will continue to be debated. I'm 3400 lbs with a glide and most likely faster than you.
[Re: demongup]
#663080
04/13/10 08:11 AM
04/13/10 08:11 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
[Re: emarine01]
#663081
04/13/10 08:50 AM
04/13/10 08:50 AM
Posts: 3,695 nc
emarine01
nc
Hey is that correct.. 50 hp to turn a pork flite
Is this true, 50hp seems like a lot to drive a pump
[Re: Super Scamp]
#663085
04/13/10 09:43 AM
04/13/10 09:43 AM
DJVCuda
Atco NJ
[Re: bigtimeauto]
#663086
04/13/10 09:48 AM
04/13/10 09:48 AM
Posts: 414 pa
demongup
pa
with you its food. Rememeber that day at cecil when i was on my golf cart and you took a bite out of my burger??? lol
LOL!!! forgot all about that. I also did the same thing to NIGA Rob with a funnel cake ....actually I stole the whole plate.
[Re: Super Scamp]
#663087
04/13/10 09:52 AM
04/13/10 09:52 AM
Posts: 414 pa
demongup
pa
3400 lbs and growing with every pie... meanwhile you sliped off the trailor and your head.. get a grip on the tranny button and bring it to Bristol Tenn. April 22/25 K&N Spring Fling 20's.. Well since we r internet racing ....I will still bet on the over weight car on a true 10 tire with no F-IN wheelie bar and crap 440-1 heads Carslie mopar meet ? I'm in for a race Oh yea bring your food stamps .I don't race for free
[Re: bigtimeauto]
#663092
04/13/10 05:17 PM
04/13/10 05:17 PM
Posts: 541 South Carolina
a408swinger
mopar addict
mopar addict
South Carolina
its in the internet it must be. glides are fster than 3 speeds to!
everybody with a proflite i'll trade you a glide for it!
Just curious but have you run a good glide set up in your current car? Its not like Im a chevy guy or anything, hell even my Mustang is Mopar powered. I have run a 904, 727, and a glide all in the same car with the same motor and tried several different converters with each. My car is 3390 lbs and was fastest with the glide. So in my case a 2 speed is faster than a 3 speed. I do run a 1.98 first gear which helps get the car moving but still only have 2 gears. Im only telling you what worked best for me after lots of testing with all 3 trannys.
Post deleted by Defbob
[Re: The Shocker]
#663093
04/13/10 05:50 PM
04/13/10 05:50 PM
