Re: stroker vs. aftermarket heads [Re: 68cuda2003] #661364
04/05/10 09:11 PM
04/05/10 09:11 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I done both when I did my current mill.Just remember all of the costs when stepping into a basic EZ head It wont end with "just heads" whoever sets your heads up(do not just buy them from Indy and bolt them on)will recommend a valvetrain and cam setup when you decide which heads you want.I would stay with the top end you have and get that heavy,old rod and piston set,possibly cracked crank,and get a good base for your new heads for next season
Gus
64 Plymouth Savoy
Dana 60
Re: stroker vs. aftermarket heads [Re: fourgearsavoy] #661365
04/07/10 02:17 AM
04/07/10 02:17 AM
Texas, USA
68cuda2003 Offline OP
Texas, USA
Lots of great advise... any others opinions out there? Thanks guys.
Re: stroker vs. aftermarket heads [Re: 68cuda2003] #661366
04/07/10 11:49 AM
04/07/10 11:49 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Your current iron heads have oversize valves? Anything else done to them? They sound like decent heads. Id do the stroker shortblock- get the hard part out of the way and have the improved low end and mid range punch. Better heads and cam will be simple future bolt ons.
Keep old mopars alive.
Re: stroker vs. aftermarket heads [Re: 68cuda2003] #661367
04/07/10 12:34 PM
04/07/10 12:34 PM
gregsdart Offline
gregsdart  Offline
One other option- put it together with what you have, and have fun, meanwhile advertising it for sale and collecting the right parts for what you want.
Personally, I favor the lowdeck combos, even for the street. a well done pumpgas 512 can put out very serious power, and be lighter than a 440 block motor. Also, any headers that will fit an iron head 440 combo will fit on a 400 based- raised exhaust port head combo, like a 440-1 head on a 400 block.
