I posted a while ago about my leaking sending unit in my 69 coronet.
Well, the weather broke finally so I got to work on it today
the problem was not with the sender, but rather the inside "lip" which the rubber gasket mates to when applied. Somehow the lower part of the lip has been warped or bent in so there is little or no contact to the rubber ring.
I had an extra ring, so I doubled up. After doing this (which was tricky and required a lot of pushing) I sealed off the hoses and tipped the tank up. Still a small slow leak from around the bottom, which I suspected. Improvement, but not sealed.
I decided I can put a little sealant on the inside lip, replace the two gaskets and crank the ring back into place.
The two sealers I am looking at is a fuel tank sealer Napa # 7651565
or Liquid metal Napa # 7651139
the fuel tank sealer is permanent once applied, however the liquid metal is sandable, drillable, etc.
Any thoughts? the last thing I need is to jack up my tank now that I almost have it fixed. This is why I ask the opinion of the all knowing moparts forum
thanks!!
eight
