Page 2 of 4 1 2 3 4
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: fstfish66] #660840
04/12/10 02:17 PM
04/12/10 02:17 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
Scratch wanted some more pics,
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: rattler] #660841
04/12/10 02:19 PM
04/12/10 02:19 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
Another
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: rattler] #660842
04/12/10 02:25 PM
04/12/10 02:25 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
If anyone wonders why i used 2 frames, its because i wanted an original style bed( flat wood) and the dak frame woudn't let me do that because it kicked up in the rear. Randy
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: rattler] #660843
03/27/11 03:39 AM
03/27/11 03:39 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: RUMBLON] #660844
07/23/13 10:25 AM
07/23/13 10:25 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Thought i would bumop this, any more Dakota swaps lately?
Plus this section needs more posts.Im on the hunt for an older dodge or plymouth truck now out west.
maybe even considering a studebaker pickup.
RUMBLON
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: RUMBLON] #660845
07/23/13 07:29 PM
07/23/13 07:29 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
For those few that have not seen my 57 in paint.
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: rattler] #660846
07/23/13 07:32 PM
07/23/13 07:32 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
under hood shot
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: rattler] #660847
07/23/13 08:50 PM
07/23/13 08:50 PM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
BEAUTY-- is that snakeskin green? a Viper color?
RUMBLON
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: RUMBLON] #660848
07/23/13 10:46 PM
07/23/13 10:46 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
Yep, Viper color. I don't think it would get near as much attention if it was a different color.
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: rattler] #660849
08/06/13 05:53 PM
08/06/13 05:53 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
That is killer
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: DusterKrazy] #660850
11/18/13 04:34 AM
11/18/13 04:34 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
If I found a 87 era Dakotawith the V6 in it, will the k member take the V8 or will that have to be replaced.???
Rumblon
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: RUMBLON] #660851
11/18/13 10:05 PM
11/18/13 10:05 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Rumblon
I used spool mounts on the motor with custom mounts on the frame.
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: RUMBLON] #660852
11/19/13 12:03 AM
11/19/13 12:03 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Rumblon
There is no replaceable K member on a Dakota. They are a one piece frame like the full sized trucks.
In a hot rod, the V8 in place of the V6 is not an issue, in the real truck, the 87 engine compartment was smaller the the 88 & newer and firewall and radiator clearance may become an issue.
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: RUMBLON] #660853
11/21/13 02:44 AM
11/21/13 02:44 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
Rumblon
I would like to think its the same K frame,but i do not know for sure,,but the 1987 3.6 v6 is a 318 minus 2 cylinders,i would think they share the same block motor mount ears,,,either way its not hard to fab a bracket to use the spoool mounts,,also you can check a guy callled schumaker he makes all sorta of adapter and better then original mopar motor mounts
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: fstfish66] #660854
11/21/13 03:52 PM
11/21/13 03:52 PM
85086
Lil Herman
Lil Herman
85086
If my frame wouldn't of been hacked in the first place I would of just put a mustang II on it. There is a 200 hours in just getting the frame to work.
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: poorboy] #660855
12/01/13 08:32 PM
12/01/13 08:32 PM
OHIO
cheapracer Offline
cheapracer  Offline
OHIO
The 87-90 are the same, in 91 they bumped out the nose to fit the v8 easier becase of fan clearance. The 87-90 still have 5lug wheels in 91 up went to 6lugs. But all dakotas will except the magnum v8's due to they run the same motor mounts as the v6. I have owned severel dakotas.
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: cheapracer] #660856
10/02/14 12:44 AM
10/02/14 12:44 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Found a 89 with a V6 in it. Are these V6s any good for a ratrod project? This one is an auto, I would like to build a cheapo ratrod using a mid 40s truck cab. Now that I have the move to Idaho done and a small place built to live I have time to start looking around.
RUMBLON
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: RUMBLON] #660857
10/02/14 02:32 AM
10/02/14 02:32 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
My 48 Plymouth has a throttle body EFI, 3.9 V6, from a 1990 Dakota, mine has the 5 speed and 3:55 gears. (It actually has the full Dakota frame under it.) The car is fun to drive, it feels fast, even though it really isn't. I can get a chirp from the 235 x 75 x 15 radials through a good tight limited slip rear axle in 3rd gear! I get 17 mpg beating the crap out of it, and it will get over 20 on the highway if I can keep it around 70. When I blow this 3.9 up, there is another one waiting. Nothing wrong with the 3.9, they are tough, have decent power range, a will pull decent mileage. The only issue I see is there is little aftermarket support, as far as performance parts available. I am considering a turbocharger for the next 3.9, time will tell. Gene
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: RUMBLON] #660858
10/09/14 03:07 AM
10/09/14 03:07 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
RUMBLON
I had one of those v6 dakota 1987 3.9 v 6 5 speed 2 bbl was a good motor,,,if you look around you may find a mopar performance 4 bbl intake,,, i dont know if any after market intakes were made for that motor,,,its a 318 minus 2 front cylinders
2015 cherokee
2013 R/T classic
Re: DAKOTA DONORS- WHAT YEARS R BEST-Whos used them? [Re: fstfish66] #2058777
04/21/16 01:40 AM
04/21/16 01:40 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Been looking again for a donor for my 50 studebaker truck. ALL of the ones I find are 6s. like this one.
http://boise.craigslist.org/pts/5544695020.html
Page 2 of 4 1 2 3 4
