Re: honestly, how hard is rebuilding front end?
[Re: Mofopar]
#660811
04/05/10 02:47 PM
04/05/10 02:47 PM
Posts: 12,248 Looking for a way out of Middl...
IMGTX
You don't suggest I it straight again?
I don't suggest it but it has been done many times before. How bad is it bent? Small dips don't usually cause problems even though they should be replaced.
LCA's are already out to change the bushings. How can I check on a bench? (it looks OK i.e. the same as right side)
If they look the same side to side (Not bent) and the length from the Ball joint hole to the center of the T-bar hex is the same your OK
Not sure post pics. That's why were are here.
72 Duster I bought last year. I think you're probably right about it getting dinged, it all adds up, even my steering column misalignment.
Thanks for the help!
A bodies used the same parts from late 60's to the mid 70's so the parts should be able to be gotten cheap.
Start another post about what years interchange and I bet you will be pleasantly surprised.
Around here that is about $50 to $75 worth of parts at the most from the local Pull-a-part.
The problem is shipping to Canada is a probably more.
