Re: Freeing stuck fuel pump pushrod
[Re: beatgoeson]
#660059
04/03/10 07:19 PM
04/03/10 07:19 PM
Most folks just remove the mechanical pump and go electric when that happens--I talked to Herb McCandless the other day and he even had to do it on his high $$ Imperial that he does the Power Tour with etc--Mopar sold a TON of soft crappy quality FP p rods at one time and that is the problem--Sorry to hear your trouble.
[Re: beatgoeson]
#660060
04/03/10 07:25 PM
04/03/10 07:25 PM
Posts: 637 Maryland USA
beatgoeson
Maryland USA
Thanks The rods only a little over a year old , Why does mopar sell that junk? really suck because its on a restored car so I really wanted the stock fuel pump without resorting to Elec. Now I'm curious how much metel went in my engine.
[Re: reflections7]
#660065
04/03/10 09:00 PM
04/03/10 09:00 PM
theres been problems with the pushrods years ago, soft metal mushrooming the pushrod. it happened to my 68 hemi rr. the metal will be soft enough to wiggle out with visegrips on the pushrod. id be looking for a different brand other than mopar performance as this is a reoccuring problem.
[Re: 469runner]
#660068
04/03/10 09:51 PM
04/03/10 09:51 PM
Posts: 307 Georgia
69bfan
Georgia
A trick that has worked for me in the past is to take a box end wrench if you have enough room to get it into the open and slide it over the rod. As you push on the other end of the wrench, it will put pressure on the rod as a fulcrum action and will hopefully move for you. A flare nut wrench may also have to be used if it has fallen futher down towards the fuel pump arm, yet still be stuck up in the motor. Good luck!!!
www.restorationpartsandmaterials.comCorrect Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs. www.dalescudashop.comCorrect style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
[Re: nz383man]
#660070
04/04/10 08:29 AM
04/04/10 08:29 AM
Use "vintage" old ones--always! There are still some of the crappy batch out there on shelves--they had a rough finish on the tips--looked like they were done on a belt sander
[Re: 1_WILD_RT]
#660074
04/04/10 12:24 PM
04/04/10 12:24 PM
beatgoeson
Maryland USA
Update!! I got it out this morning! I used needle nosed pliers and worked for 10 min. The metal was so soft it just flaked off. Beware I bought it new about a year ago from my friend at the dealership parts dept. Compairing it to the old one it has lost a good 3/16th. to 1/4" on the cam end. Now What would you guys recommend on removing a 1/4" of shaved metal from my motor? I will change the oil and filter but , I guess I should drop the pad too? Now I need to find a good seasonded rod. Thanks for the help and if you have a MP pushrod lay around lose it! I will post a picture later.
[Re: ireland383]
#660076
04/04/10 01:23 PM
04/04/10 01:23 PM
RapidRobert
My new one (dont remem where I got it) has concentric rings on the end like tree trunk rings. I'm wondering if it's one of the bad ones
[Re: RapidRobert]
#660077
04/04/10 01:26 PM
04/04/10 01:26 PM
Posts: 21,847 Kirkland, Washington
Pacnorthcuda
I think that IS a bad one. I bought a MP rod back in the 90's that had rings (sort of irregular rings as I recall), I ended up using the nice looking 30 year old original one instead. A rough surface sliding against metal cant be good.
