W2 Rocker Arms #658698
04/01/10 11:37 PM
04/01/10 11:37 PM
West Coast
Dr340w2 Offline OP
All Talk. No Action.
Dr340w2  Offline OP
West Coast
Just wondering about different rocker arms that are being used on w2 motors?
aka: Albergetti
Re: W2 Rocker Arms [Re: Dr340w2] #658699
04/01/10 11:59 PM
04/01/10 11:59 PM
, PA
sleepyhead416 Offline
, PA
Mopar blues on my 416 roller
Re: W2 Rocker Arms [Re: Dr340w2] #658700
04/02/10 12:09 AM
04/02/10 12:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Welcome to the jungle
I have 2 systems... one is the blue MP (which is a
Crane rocker) and 2nd is TD... the TD is a better system
if you are into a bigger cam... I should also state
that both of these are roller cam engines in the .650
or better lift
Re: W2 Rocker Arms [Re: MR_P_BODY] #658701
04/02/10 05:41 AM
04/02/10 05:41 AM
Sherman Texas
The Shocker Offline
The Shocker  Offline
Sherman Texas
Harlan Sharps roller rockers on my non roller 408...
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
Re: W2 Rocker Arms [Re: The Shocker] #658702
04/02/10 06:30 AM
04/02/10 06:30 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
IMO if this is a new build your only choices are Harland Sharp, Jesel or T&D. Since Crane and Erson are no longer around it limits the options.
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: W2 Rocker Arms [Re: Plumb Wired] #658703
04/02/10 07:05 AM
04/02/10 07:05 AM
, PA
, PA
5 years w/ISKY toolroom springs 630 roller 1.6 & 1.5 ratios
Re: W2 Rocker Arms [Re: sleepyhead416] #658704
04/02/10 07:35 AM
04/02/10 07:35 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
590 lift M/P mechanical cam, original W2 ductile iron rockers. I`ve never broken one since I started using them over 15 years ago. But then again we have a little " trick" we use which I`m sure helps. A very thin roller bearing between each rocker on the shaft.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: W2 Rocker Arms [Re: 11secdart] #658705
04/02/10 09:08 AM
04/02/10 09:08 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Crane Gold 1.6 Roller Rockers.
Tony
70 AARCuda Vitamin C
Re: W2 Rocker Arms [Re: Dr340w2] #658706
04/02/10 11:07 AM
04/02/10 11:07 AM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
i have ran norris stainless on my w2 motor for 21 years and lots of 7400 rpm passes with 650 roller and have broken only 2..but they are warranty
for life and have had no problem with norris.
Re: W2 Rocker Arms [Re: Plymouth340] #658707
04/02/10 11:27 AM
04/02/10 11:27 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Norris rockers are nice pieces. Investment cast stainless,
bronze bushed, available in 1.5 and 1.6
Unfortunately, no longer produced.
Re: W2 Rocker Arms [Re: Dr340w2] #658708
04/02/10 12:08 PM
04/02/10 12:08 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
I am going to give a set of T&D 1.7's a try this year. These are the Econo W2 head version.
Re: W2 Rocker Arms [Re: StrokerAspen] #658709
04/02/10 12:57 PM
04/02/10 12:57 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
My pump gas 426 340 based stroker has 1.55 T&D's, super nice pieces for sure but way overkill for a HYD cammed street engine.
Re: W2 Rocker Arms [Re: ScottSmith_Harms] #658710
04/02/10 03:08 PM
04/02/10 03:08 PM
West Coast
Dr340w2 Offline OP
Dr340w2  Offline OP
West Coast
Thank You for all the helpful info.
This is a high compression roller cam 340. No Stroker. W2's (oval port) single carb.
aka: Albergetti
Re: W2 Rocker Arms [Re: Dr340w2] #658711
04/02/10 05:02 PM
04/02/10 05:02 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
My point was that there are only a few manufacturers still in business. Crane, MP (Crane), Erson and Norris all made good pieces but are no longer around so if you buy a set of them used and break one your good luck finding replacements. Just ask me how I know!
Mike Gray
RIP Monte Smith
aka: OutlawFish
Re: W2 Rocker Arms [Re: Plumb Wired] #658712
04/02/10 05:34 PM
04/02/10 05:34 PM
CEDAR RAPIDS
Plymouth340 Offline
Plymouth340  Offline
CEDAR RAPIDS
Norris is still making then...i just talked to then 3 days ago and he is sending me my w2 replacement rockers..
Re: W2 Rocker Arms [Re: Plumb Wired] #658713
04/02/10 05:35 PM
04/02/10 05:35 PM
West Coast
Dr340w2 Offline OP
Dr340w2  Offline OP
West Coast
Thank You very much for the info.
P.S. Fast small blocks do rule!
aka: Albergetti
Re: W2 Rocker Arms [Re: Dr340w2] #658714
04/02/10 05:44 PM
04/02/10 05:44 PM
mo
ALKYW5DART Offline
ALKYW5DART  Offline
mo
harland sharp 1.65 rockers on my w-5 headed 416. used mp blue ones before with no problem just needed 1.65 for the geometry
Re: W2 Rocker Arms [Re: Plymouth340] #658715
04/02/10 07:41 PM
04/02/10 07:41 PM
S/ST 3040 Offline
S/ST 3040  Offline
I know they had some loose rockers. (not enough to make up a full set)
but, unless something has changed from a few weeks ago, they aren't
making anymore.
It would be nice though.
Re: W2 Rocker Arms [Re: Dr340w2] #658716
09/07/12 10:07 PM
09/07/12 10:07 PM
Cape Coral
65 DODGE POST Offline
Cape Coral
Hello guys...this is an old thread...just joined and can't figure how to post? Anyways I am getting these heads in two weeks...
http://www.ebay.com/itm/300774739401?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
They are late 1977 810 castings....race versions...I read somewhere on the early W2's you have to use an assembly like the Harlands...I do not have the heads in front of me but I am getting them shipped here soon. who knows the offset? .775 or .500? I'm just trying to get a head start so I can computer shop until they arrive..
65 DODGE CORONET 440 INDY EZ HEADS STRANGE S60
Re: W2 Rocker Arms [Re: 65 DODGE POST] #658717
09/07/12 10:46 PM
09/07/12 10:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You do know thats a single head
