Re: W2 Rocker Arms
[Re: 65 DODGE POST]
#658719
09/07/12 10:54 PM
09/07/12 10:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Hello guys...this is an old thread...just joined and can't figure how to post? Anyways I am getting these heads in two weeks...
http://www.ebay.com/itm/300774739401?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
They are late 1977 810 castings....race versions...I read somewhere on the early W2's you have to use an assembly like the Harlands...I do not have the heads in front of me but I am getting them shipped here soon. who knows the offset? .775 or .500? I'm just trying to get a head start so I can computer shop until they arrive.. Thanks Jim
You do know thats a single head
What do you mean?
It sounded like you were ordering a pair of heads
Re: W2 Rocker Arms
[Re: MR_P_BODY]
#658722
09/07/12 11:16 PM
09/07/12 11:16 PM
Posts: 82 Cape Coral
65 DODGE POST
Cape Coral
Ok, Well I have to call them I guess...I just read that all W2 heads made after 2002 are machined for the T&D rockers...I just want to make sure I get the right stands/shafts/and offset right the first time so I can slap these on and go...These were on the shelf for fifteen years, just came out of retirement and got put back together...the have been sitting a year.
65 DODGE CORONET 440 INDY EZ HEADS STRANGE S60
Re: W2 Rocker Arms
[Re: MR_P_BODY]
#658724
09/08/12 12:03 AM
09/08/12 12:03 AM
Posts: 13,259 aZLiViN
J_BODY
aZLiViN
scroll down a bit.... it's a pair.
Re: W2 Rocker Arms
[Re: J_BODY]
#658725
09/08/12 12:06 AM
09/08/12 12:06 AM
MR_P_BODY
I already seen it and commented on it
Re: W2 Rocker Arms
[Re: MR_P_BODY]
#658726
09/08/12 05:40 AM
09/08/12 05:40 AM
Posts: 21,451 in a cattle trailer down by th...
Guitar Jones
I have the HS on my W5's I'm pretty sure you are going to need the .775 offsets. But don't expect to just bolt them on and go, they all need to be "adjusted" side to side to center the roller tip over the valve stem.
"Come get your wife"
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Front and rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: W2 Rocker Arms
[Re: 65 DODGE POST]
#658728
09/08/12 08:07 AM
09/08/12 08:07 AM
Guitar Jones
With the long valve heads without rocker stands you need the offset shafts and stands. But like I said, I don't care what you buy they simply are not a bolt on and go proposition.
Re: W2 Rocker Arms
[Re: 65 DODGE POST]
#658729
09/08/12 09:13 AM
09/08/12 09:13 AM
MR_P_BODY
Do all the Race W2 heads need the .180 offset shafts and stands? The new castings and the old castings? I know T & D are considered the better rocker....but my old man had to send his back three times and it to weeks for them to get his right on his Indy head small block...I've also seen guys order them and then they need take some metal off them to make them fit. The W2 heads made after January of 2002 are machined to accept the T&D rockers I guess... I do not want to have to machine my heads or machine new rockers... That's what I mean by bolt on and go..So I'm looking for a rocker set that I can install adjust and go. My heads are made in 1977/78 so I am not sure if they are machined the same as the newer W2s on the rocker pedestals..
You MIGHT have to mill the pedestals to get the proper geometry ... remember these are Mopar heads and nothing is bolt on and go.... if they have MP springs on them I would get new springs the mopar springs are too weak
Re: W2 Rocker Arms
[Re: Belvedere2]
#658731
09/08/12 09:57 AM
09/08/12 09:57 AM
Guitar Jones
I wouldn't buy them from Summit. Todd at Competion Wedge will give you a better deal and better service too.
Re: W2 Rocker Arms
[Re: 11secdart]
#658732
09/08/12 10:49 AM
09/08/12 10:49 AM
Posts: 4,221 New York
polyspheric
New York
A very thin roller bearing between each rocker on the shaft
Like a "lazy susan" bearing turned 90°?
Boffin Emeritus
Re: W2 Rocker Arms
[Re: polyspheric]
#658733
09/08/12 11:00 AM
09/08/12 11:00 AM
Guitar Jones
That's a Torrington bearing.
Re: W2 Rocker Arms
[Re: Guitar Jones]
#658734
09/08/12 11:21 AM
09/08/12 11:21 AM
Posts: 207 People's Republic of Mass.
Belvedere2
I agree. Just giving him the easiest option. Personally if I had to do it all over again I'd start with brand new heads and get them worked over by a pro. My '76s did need some work and the people I talked to about getting them ported said "nope" Castings not so good back then. But what for they are much better than my old X heads. Top end mucho better.
Re: W2 Rocker Arms
[Re: Belvedere2]
#658735
09/08/12 12:02 PM
09/08/12 12:02 PM
Posts: 20,279 PA.
pittsburghracer
"Little"John
"Little"John
PA.
W2's were and still are a nice head and really stepped up the way small block mopars ran. Every STOCK set that I have had on my flowbench max out at about 260cfm and then back up at higher lifts. Perfect for a 520-580 lift cam. There main problem is like stated above " core shift " and cracking problems. The set I ported and used on my duster maxed out at about 308cfm with a 2.02 valve but cracked by the W2 on the outside of the head when bolted down and then up thru the intake port 6 weeks later. Mine were the older style (basic) that used the stock shaft style hold-downs. Lots of work for something like that so I doubt if I will ever try another set. I ported a set of edelbrocks and installed them on that short block and the car runs the same ET.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
Re: W2 Rocker Arms
[Re: pittsburghracer]
#658736
09/08/12 03:48 PM
09/08/12 03:48 PM
dartman366
Mt. Vernon, Ohio
I just put a set of TD's on my Commando heads and you will have to adjust the geometry at the least,,and yes, I agree that Todd @ Competition Wedge can give you as good a deal as anyone and if there is a problem he has the knowledge to understand what you need/want as opposed to the big stores like Summit and Jegs.
Re: W2 Rocker Arms
[Re: dartman366]
#658737
09/09/12 10:44 AM
09/09/12 10:44 AM
65 DODGE POST
Cape Coral
Thanks for all the replies.. I know the old castings are not as great ( fear of porting) but I have an old vintage draw through turbo kit I want to run with a predator carb..I just didn't want to run the turbo through my stock 318 puke heads... although I have to use a stock 273 manifold on the drivers side these heads will still be a dramatic improvement over my 318 heads...( gonna have to do some grinding on the exhaust manifold and find some good gaskets )
