Re: Power Window Wiring Grommets?
[Re: cataclysm80]
#65832
05/30/08 04:41 AM
05/30/08 04:41 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
The grommets were similsr through the eighties but the outer diameter varies...Not a problem on a clone just drill the hole to fit the grommet but if the holes are already drilled you need to find the correct grommets...BTW if the holes aren't drilled you'll find there are factory dimples in the door & "A" pillar showing the factory locations....
[Re: 1_WILD_RT]
#65833
05/30/08 09:01 AM
05/30/08 09:01 AM
Posts: 3,072 Farmland, IN
Ludington1
Farmland, IN
Hey Tav, keep us posted on the details and how the kit works for you please. Another option would be to cut off the older grommets. Then you can remove and re-use them without cutting the wiring. It is not perfect, but would probably not be visible once installed, and I am assuming the restored car won't be out in the elements much anymore where the functionality for sealing would be required... mostly just to stop wiring from rubbing bare. ![](/ubbthreads/images/graemlins/Twocents.gif) Darren
[Re: cataclysm80]
#65835
05/30/08 10:34 AM
05/30/08 10:34 AM
Ludington1
Farmland, IN
Tav, I'm sending you some e-mails now... check out the ads here, like in C-Body For Sale... lots of those luxo-cruisers came with power windows, and many are now parts cars, maybe other sites like C-Body Dry Dock too.
Darren
[Re: cataclysm80]
#65836
05/30/08 02:34 PM
05/30/08 02:34 PM
Posts: 3,076 Renton, Wa.
Classof70Chally
super gas
super gas
Renton, Wa.
The XV kit looks real good, but I haven't test fit it yet. Soon...
They build to order, but it only takes a week.
After looking at it, I think using the factory style window switches will be a snap except for maybe the drivers switch which may require a little more work. I'll keep you all posted as it comes together, and let you know how to do it. Keep an eye out for those grommets for me will ya.
Tav
I am also thinking about this mod in the future for my sig car. Some pics of modifications to the harness to use the factory switches would be great if you get a chance. ![](/ubbthreads/images/graemlins/smile.gif)
[Re: Classof70Chally]
#65837
05/30/08 08:14 PM
05/30/08 08:14 PM
Tav, will any work: ![](http://i303.photobucket.com/albums/nn133/krisiesmopes/DSCN4484.jpg) I have 2 of each, I will put them in the box with your other gear if any will work for you.
[Re: 1_WILD_RT]
#65839
06/04/08 06:25 PM
06/04/08 06:25 PM
Posts: 4,165 Florida
cataclysm80
Glad moparts is up & running again. ![](/ubbthreads/images/graemlins/smile.gif) I'll try to measure mine and post that pic tomorrow. Tav
[Re: cataclysm80]
#65842
06/06/08 01:38 AM
06/06/08 01:38 AM
Here's my pic. Looks like the E body grommets are 1 7/8 hole size for the door, and 1 3/8 hole size for the body.
It's pretty amazing that mopar used so many different grommets.
getitgone please let me know if I can have 2 of each of these sizes and if I owe you anything for them.
Tav
Don't worry about it, they will be on the way to you tomorrow ![](/ubbthreads/images/graemlins/beer.gif)
