Hey fellow Mopar addicts,
I always see a lot of comments & questions about which brand of wheel opening moldings fit better than others. Truth is, none of them are going to fit perfectly due to so many variables. Yes, some are better than others, but it takes patience & work to make any of them great. So, having said that, I thought I would offer you guys some tips that I have learned in the last 20 years of messing with the junk we call Mopars.
First thing to do is go to your local Harbor Freight, or similar store, and pick up some heavy duty rubber coated spring clips. These are cheap-like $1.00 each. Buy about 12 of them. Then mock up your molding where it fits the best-this is a good 2 person job to prevent scratches. You may find the front or rear doesn’t match the body perfectly. In this case you may have to split the middle or decide which is the least noticeable.
Take your 1st spring clip and place it at the top center of the molding, then take the others and work your way out. When placing the clips on the molding, do so in such a way, that pressure is being exerted against the side of the fender-this keeps it seated against the body for a flush look. Then with an 1/8” drill bit drill the center top hole and place a screw there. Then work the hole to the left, then the right, alternating back and forth. You may find, that to get the molding to sit perfectly flush with the body, the wide band that the screws go through might have to be bent slightly. If you look at some original moldings this is where they are sometimes “wrinkled” and this works well to help the fitting. I have included a picture for reference that I hope helps. I know this may sound a bit confusing and it is without a demonstration, but every little bit helps right? Also, take you time. This usually takes me several hours and I have done them dozens of times.
Paul
