Re: 02 van won't start and the mechanics don't know why
[Re: UCUDANT]
#65421
06/02/08 04:22 PM
06/02/08 04:22 PM
Posts: 1,167 ERIE PA home of the RENCH MOB
mike_vango
sorry i am trying to pass on as much info as i can. i don't know anything really about computer controlled fuel injection. i am assuming he is competent and checked all the really basic things. it DID NOT have fuel, spark or power at the injectors. the computer they ordered won't be here till tomorrow. THANKS
[Re: randal8]
#65425
06/05/08 10:50 PM
06/05/08 10:50 PM
Posts: 18,428 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
High secondary resistence,(bad plug wires or plugs) will cause the secondary voltage to eat away at the primary insulation in the coil. Eventually the high voltage will make its way into the primary circuit and back to the pcm. This will anger the pcm gods and they will shut down the asd relay. The fix is to replace the coil, plugs & wires and maybe the pcm. If your mechanic has a scope, he should be able to see the high voltage spike leaking into the primary circuit.
Now thats funny. You tell us how the PCM knows secondary voltage. ![](/ubbthreads/images/graemlins/confused.gif)
