Page 2 of 4 1 2 3 4
Re: 413 motorhome engine ???"s [Re: dOc …] #651570
09/13/10 01:50 PM
09/13/10 01:50 PM
Poplar Bluff, Missouri
partfiler69 Offline
Still Wondering
partfiler69  Offline
Still Wondering
Ok, thanks for the tip. What would be a better head to use instead of the 906's. What if I had the 906's flat milled .040?
Back from hiatus
Re: 413 motorhome engine ???"s #651571
09/13/10 01:53 PM
09/13/10 01:53 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
much easier just to take a felt marker and write
"413" on the 383's valvecovers... no?
WH .....???? ... whatchoobeensmokin?
Re: 413 motorhome engine ???"s [Re: partfiler69] #651572
09/13/10 01:56 PM
09/13/10 01:56 PM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
What do you plan on doing with the engine combo ? ... have you pulled the heads off that 413 ? ..... the 906's can not be milled enough to get decent compression with that shortblock.
Re: 413 motorhome engine ???"s [Re: dOc …] #651573
09/13/10 02:03 PM
09/13/10 02:03 PM
partfiler69 Offline
Still Wondering
partfiler69  Offline
Still Wondering
It will be replacing the tired 318 in my wifes 73 satty. It is just a weekend cruiser. Nothin radical or extreme.
Back from hiatus
Re: 413 motorhome engine ???"s [Re: partfiler69] #651574
09/13/10 02:11 PM
09/13/10 02:11 PM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
I think that you would be muchO happier with a combo of a 516 head cut say 30 ... with a set of late model valve sizes.
Have you seen those dished pistons ?
Re: 413 motorhome engine ???"s [Re: dOc …] #651575
09/13/10 02:27 PM
09/13/10 02:27 PM
partfiler69 Offline
Still Wondering
partfiler69  Offline
Still Wondering
What can i find a set of 516's on? This will be my first build. And I won't be jerking the heads off 'till this weekend, so I've yet to see this 'dish'. But eventually i would like to punch the block .062, and make a 426. But for now, BUDGET is the name of the game.
Back from hiatus
Re: 413 motorhome engine ???"s [Re: partfiler69] #651576
09/13/10 02:36 PM
09/13/10 02:36 PM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
Early/mid 60's B engines for the heads ....but if BUDGET is the game and if you already have a set of 906's ....maybe cut those 60.
But it will still have low compression.
Re: 413 motorhome engine ???"s [Re: dOc …] #651577
09/13/10 02:48 PM
09/13/10 02:48 PM
partfiler69 Offline
Still Wondering
partfiler69  Offline
Still Wondering
Back from hiatus
Re: 413 motorhome engine ???"s [Re: partfiler69] #651578
09/13/10 03:21 PM
09/13/10 03:21 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Be sure to cut the intake side of the heads to keep the geometry the same. You can't slam .060" off the intake ports. It requires a different amount and possibly a different angle to keep things the same.
- Stu Harmon
Re: 413 motorhome engine ???"s [Re: feets] #651579
09/13/10 09:12 PM
09/13/10 09:12 PM
partfiler69 Offline
Still Wondering
partfiler69  Offline
Still Wondering
Well, from what I am reading about the low compression of this beast, it seems to have BOOST written all over it!
Back from hiatus
Re: 413 motorhome engine ???"s [Re: partfiler69] #651580
09/13/10 09:31 PM
09/13/10 09:31 PM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
Yes it IS a good lower rpm blower or turbo base motor. And YES .. you do have to cut some off the intake side of the heads to make everything line-up OK after cutting .060 ... the amount and the formula escapes me at this point.
Re: 413 motorhome engine ???"s [Re: dOc …] #651581
09/14/10 09:06 AM
09/14/10 09:06 AM
partfiler69 Offline
Still Wondering
partfiler69  Offline
Still Wondering
Thanks for the help, everybody.
I'm also wondering, is it possible to put a set of 383 pistons in it, or do I need 426W pistons?
Back from hiatus
Re: 413 motorhome engine ???"s [Re: partfiler69] #651582
09/14/10 03:45 PM
09/14/10 03:45 PM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
383 pistons will work ... but you will have about 4 to ONE compression ratio ..
426w pistons would be the ticket OVER those 383 ones ..
Re: 413 motorhome engine ???"s [Re: dOc …] #651583
09/14/10 05:45 PM
09/14/10 05:45 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Hey, the way the quality of gas keeps deteriorating, that may be a good thing....
Re: 413 motorhome engine ???"s [Re: dOc …] #651584
09/14/10 07:15 PM
09/14/10 07:15 PM
partfiler69 Offline
Still Wondering
partfiler69  Offline
Still Wondering
Can't I just have the heads flat milled .010?
Back from hiatus
Re: 413 motorhome engine ???"s [Re: partfiler69] #651585
09/14/10 07:28 PM
09/14/10 07:28 PM
Florida STAYcation
dOc … Offline
dOc …  Offline
Florida STAYcation
MORE LIKE .....1.100 !!
Re: 413 motorhome engine ???"s [Re: partfiler69] #651586
09/15/10 09:50 AM
09/15/10 09:50 AM
Commando1 Offline
Commando1  Offline
Please say you're being facetious.
At least I pray so.
Re: 413 motorhome engine ???"s [Re: Commando1] #651587
09/15/10 03:26 PM
09/15/10 03:26 PM
partfiler69 Offline
Still Wondering
partfiler69  Offline
Still Wondering
At least I pray so.
Yes, this might be my first engine teardown, but I do have a negligable amount of common sense.
Back from hiatus
Re: 413 motorhome engine ???"s [Re: partfiler69] #651588
09/15/10 04:01 PM
09/15/10 04:01 PM
I think someone did some measuring and figured out that 383 pistons would work in a 413 (bored to 4.25) with a 4.15 stroker crank. Not sure anyone has ever actually tried it, though.
That would make it a 472, BTW.
Re: 413 motorhome engine ???"s #651589
09/15/10 04:35 PM
09/15/10 04:35 PM
scratchnfotraction Offline
a 440 crank in a 400 block makes a 470 stroker
would be sweet to make a 413/472 strokers as well
I think I will swing by and pick up that MH 413 thats for sale in my town
I think the odd looking wp and tall heads would deff be kool looking in my 85 truck
should be fine for towing my 440 truck around instead of the 318 sb thats in it
is 300$ a bad deal?,it runs and moves the MH down the road good,no smoke,noise..ect..
its just a PITA to pull out,hope they want to scrap it so I can
Page 2 of 4 1 2 3 4
