Page 2 of 3 1 2 3
Re: Early build E-body-differences [Re: DetMatt] #649691
03/25/10 08:17 AM
03/25/10 08:17 AM
cataclysm80 Offline
cataclysm80  Offline
early cudas did not come with rear swaybar.
My nov. `69 buiLt A66 Challenger has no rear swaybar as well.
My June of 70 'Cuda does have the rear sway bar. (on the broadcast sheet and everything)
Rear sway bars came out sometime before the trans am program in the spring of 70.
Tav
Re: Early build E-body-differences [Re: cajunmopar] #649692
03/25/10 08:22 AM
03/25/10 08:22 AM
cataclysm80 Offline
cataclysm80  Offline
The rear interior panels also have a different hole location near the quarter glass.
I'd love to hear more info on this. I know my August of 69 Challenger has that screw hole going into the front of the sail panel area. I think most 1970 models are that way. I know the 71 models have that screw positioned a few inches more forward on the car going in towards the quarter window glass. (I'll try to post a pic during lunch today.)
Did this changeover happen sometime during the 70 model year? When?
It's making it hard to find rear panels that will go onto my car.
Tav
Re: Early build E-body-differences [Re: cataclysm80] #649693
03/25/10 10:24 AM
03/25/10 10:24 AM
70RT Offline
70RT  Offline
I came across a salvage yard Oct '69 built Challenger base model that had a couple of thin spring steel flats (approx 5" l x 1.5" w) that apparently were installed in the corner or the front bumper to hold the rubber inserts in place. They mounted underneath one of the bumper bracket nuts. Has anyone else come across these? I'm thinking it was an early build thing that was dropped later in 70. I believe that they may have gone away when the factory started scalloping the V-slot they cut into the bumper wrap around for the rubber insert. Comments?
Re: Early build E-body-differences [Re: 70RT] #649694
03/25/10 12:45 PM
03/25/10 12:45 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
Those bracket in the front bumper are something I had never heard of, and I've pulled apart a fair share of Challengers.
I saw them at a swap meet for the first time a couple of years ago.
Rare pieces, but I can see why they left them off.
I have later version of the rubber bumper inserts that have adhesive on them.
Re: Early build E-body-differences [Re: cataclysm80] #649695
03/25/10 03:39 PM
03/25/10 03:39 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
Rear sway bars came out sometime before the trans am program in the spring of 70. very interessting as im trying to figure out witch month my 222655 cuda is built,i know its not going to be spot on the day. i red i think on hamtramck-site a bulletin that said that rear sway bars where introduced" at the first of the year" does that mean january/1 ?
Tav
Re: Early build E-body-differences [Re: cuda-sweden] #649696
03/27/10 02:30 AM
03/27/10 02:30 AM
South, FL
cudaized Offline
cudaized  Offline
South, FL
...im trying to figure out witch month my 222655 cuda is built,i know its not going to be spot on the day.
1970 `cuda = SPD should be C17 Wed or C18 Thu
(I'm guessing the 18th)
THE Actual build day is anyones guess.
Ola
Re: Early build E-body-differences [Re: cudaized] #649697
03/28/10 10:40 AM
03/28/10 10:40 AM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
Ola
hej,sorry i got it wrong. the number is 222665 whats your guess on that one.im no good with the spd thing,as what does C stand for/what month?please make a guess on my 222665 nr,pretty please
Re: Early build E-body-differences [Re: cuda-sweden] #649698
03/28/10 10:58 AM
03/28/10 10:58 AM
USA
Lawn Monkey Offline
Lawn Monkey  Offline
USA
What is the earliest build date?
My JS23VOB October 69 build date does not have torque boxes, and no cut outs in trunk lid
Re: Early build E-body-differences [Re: cuda-sweden] #649699
03/28/10 11:28 AM
03/28/10 11:28 AM
Finland
CarelianCuda Offline
Finland
1970 models:
8 = August 1969
9 = September
A = October
B = November
C = December
1 = January 1970, etc.........
It's possible at difference between VINs is even 10 000 with the same SPD.
B07 / 0B182xxx http://cudaworld.com/adDetail.php?cat_id=9&sub_id=0&ad_id=2342
B07 / 0B192xxx http://cudaworld.com/adDetail.php?cat_id=9&sub_id=0&ad_id=2303
Interesting thing of those tags is also at there are no J54 (or N96) neither.
Mine have also same SPD with exactly same thing and no J54 even the sheet.
Some late Hemicudas looks to have both J54 and N96 on their tags
1970PlymouthCuda383
1970AMCHornet2D232
2003TruckmastersOkenosDurangoSlt+
2008DodgeChallengerSRT8
Re: Early build E-body-differences [Re: Lawn Monkey] #649700
03/28/10 11:31 AM
03/28/10 11:31 AM
Finland
Finland
801 = August 1. 1969
1970PlymouthCuda383
1970AMCHornet2D232
Re: Early build E-body-differences [Re: CarelianCuda] #649701
03/28/10 11:42 AM
03/28/10 11:42 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The earliest SPDs I have on file for 1970 E-bodies so far are;
Hamtramck - 801
LA - 818
For any 1970 car though, there is NO way to know the actual build day.
Edited to fix typo.
Re: Early build E-body-differences [Re: Alaskan_TA] #649702
03/28/10 12:05 PM
03/28/10 12:05 PM
USA
Lawn Monkey Offline
Lawn Monkey  Offline
USA
Hamtramck - 802
LA - 818
Scratching my head,,,, does 802 = August 2nd 1969
and 818 = August 18 1969
Are build dates in 69 considered early ?
Re: Early build E-body-differences [Re: Lawn Monkey] #649703
03/28/10 12:14 PM
03/28/10 12:14 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Yes, '69. The 1970 model year ran from August 1, 1969 to July 31, 1970.
Personally, I consider the cars scheduled in the first month at each plant "early".
Re: Early build E-body-differences [Re: Alaskan_TA] #649704
03/28/10 12:18 PM
03/28/10 12:18 PM
Finland
Finland
Hamtramck - 802
On another board i said 802 and then you said at Diamante had 801 (but later invoice).
So that is basics of my reply
1970PlymouthCuda383
1970AMCHornet2D232
Re: Early build E-body-differences [Re: CarelianCuda] #649705
03/28/10 12:21 PM
03/28/10 12:21 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I hit the wrong button, I know of a few with 801. Thanks for the catch, I'll fix it to avoid any cofusion.
Re: Early build E-body-differences [Re: Alaskan_TA] #649706
03/28/10 12:28 PM
03/28/10 12:28 PM
Kirkland, Washington
Pacnorthcuda Offline
I had an August 69 70 Barracuda (sequence number 100327) that I swear did not have beams in the doors--I wish I had pics to prove, but I don't.
I rememeber removing the driver's door and thinking how light it was. After removing the inner panel I saw no beams.
Years later I removed the doors from another early build 'Cuda (sequence 108632) and it had the beams.
Re: Early build E-body-differences [Re: Pacnorthcuda] #649707
03/28/10 02:26 PM
03/28/10 02:26 PM
New State
kidmopar Offline
kidmopar  Offline
New State
I LOVE this stuff! Keep it going!
Post deleted by moparts [Re: Alaskan_TA] #649708
03/28/10 11:16 PM
03/28/10 11:16 PM
Re: Early build E-body-differences #649709
03/28/10 11:21 PM
03/28/10 11:21 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Any more details? I have heard of a few 1970 LA cars with VERY low VINs but I do not have details on them other than the VIN yet.
Post deleted by moparts [Re: Alaskan_TA] #649710
03/28/10 11:38 PM
03/28/10 11:38 PM
Page 2 of 3 1 2 3
