Re: Factory rear sway bars?
[Re: smokkem]
#649203
03/25/10 09:23 AM
03/25/10 09:23 AM
Posts: 6,111 NotRussia
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
here is my work in progress, its a 70 4.10 b body dana in a 71 cuda, trying to make a 71 super trac pac set up, does this look right? does it look like your 72 cuda set up? bolts to the frame and connects to the upper leaf spring bracket, please pardon the dust
The B-body rear is narrower than the e-body. So...did you bend the rear bar to be narrower to get it to fit?
[Re: screamindriver]
#649204
03/25/10 09:45 AM
03/25/10 09:45 AM
Posts: 904 Berwyn, IL
Moparlar
Berwyn, IL
Here's a pic of the 71-72 B body rear bar axle plate..
That hole in the center looks way to big like someone cut it out. My plates have a small hole to go over thw bolt in the spring.
Larry
[Re: Moparlar]
#649205
03/25/10 10:04 AM
03/25/10 10:04 AM
Posts: 765 Shoreline, Washington
72roadrunnergtx
Larry
I agree, appears to be a modified 72' plate, possibly to fit the 73' and later spring isolator mount.
[Re: 72roadrunnergtx]
#649206
03/25/10 11:16 AM
03/25/10 11:16 AM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
My 78 Fury has a factory rear sway bar.
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: smokkem]
#649209
03/25/10 06:11 PM
03/25/10 06:11 PM
2fast4yourBrain
Whack top Dodger
Whack top Dodger
NotRussia
I cut the spring perches off and rewelded them in the correct ebody location, I think I moved them outward 1" on each side
Ahh...thought you might've moved the springs inboard w/a Dr. Diff kit or something.
[Re: NachoRT74]
#649216
03/29/10 10:51 PM
03/29/10 10:51 PM
Posts: 6,140 Valencia, España
NachoRT74
Valencia, España
they were to work PERFECT except for one detail: the area raising up to rod link provision was meeting with axle housing, making imposible to fit. That was what made to take the conclusion the axle pedestals are shorter on 73/74 than 71/72.... and even some ppl said I'm wrong about, geometry doesn't fail, and I'm still practically sure of that although never compaired axle pedestals side by side.
If wasn't for that, they were to work!
At the end had to buy another ones, this time the correct ones WITH PICS!
[Re: generallee6901]
#649219
11/04/10 09:33 AM
11/04/10 09:33 AM
Posts: 2,592 None
71rm23
None
I had a 72 roadrunner that had a rear bar.
72 Had the rear sway bars. I'm looking for both front and rear for my 71 RR
[Re: burdar]
#649221
11/04/10 11:00 AM
11/04/10 11:00 AM
Posts: 1,037 Texas, Dallas
G_T
Texas, Dallas
I was under my 68 Imperial the other day - it has a Panhard bar in it I never knew mopar used panhard bars in cars...
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com
2012 Charger SRT8
