Page 2 of 3 1 2 3
Re: Are there any members here that sell ROL gaskets? [Re: ProSport] #647188
03/28/10 09:51 AM
03/28/10 09:51 AM
Locomotion Offline
Locomotion  Offline
Talk about a run-around. I called Corteco and finally someone answered but he seemed kinda clueless on where to order them from, he gave me a customer service number, 1-800-327-1027, but nobody has answered yet.
That's the ROL tech # in Orlando. When I called Corteco they told me to call ROL also. Makes sense if they sold the gasket line to them. Try again next week. They may have a lot going in in the middle of ownership and/or product line changeover.
Re: Are there any members here that sell ROL gaskets? [Re: Locomotion] #647189
03/28/10 10:34 AM
03/28/10 10:34 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
As I mentioned earlier. they are in a lot of turmoil at the present time.Probably not your best choice at the moment. When they move everything to Mexico, I dont know if it will get much better. There are other gaskets to use.
Myron, I'll try and call you sometime soon.
Todd
RIP Monte Smith
Re: Are there any members here that sell ROL gaskets? [Re: CompWedgeEngines] #647190
03/28/10 10:42 AM
03/28/10 10:42 AM
Locomotion Offline
Locomotion  Offline
Todd
They might move manufacturing to Mexico, but they just moved their Florida (main?) offices from Oviedo to Orlando and appear to be packaging ROL products there also.
Re: Are there any members here that sell ROL gaskets? [Re: 70AARcuda] #647191
03/28/10 09:22 PM
03/28/10 09:22 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
like i said before..the jegs ones I bought for small block were the ROL head gaskets..
looking at the BB ones they appear to be the same unless they have changed them out.
http://www.jegs.com/i/JEGS/555/210540/10002/-1?parentProductId=937090
I called JEGS and the tech guy said he's not allowed to tell me what brand the JEGS gaskets are because it changes every month or so, whatever they get a deal on.
Re: Are there any members here that sell ROL gaskets? [Re: ProSport] #647192
03/28/10 09:36 PM
03/28/10 09:36 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Summit DOES have this one in stock.......
P4349559
4.38 bore
No lock wire
.040 thick
$59.95 per pair.
For up to 12.5 to 1 compression.(I'm about 11.8 to 1)
These any good? Or any of the other MP gasket's I've mentioned?
Re: Are there any members here that sell ROL gaskets? [Re: ProSport] #647193
03/29/10 07:51 AM
03/29/10 07:51 AM
ohio
dbran451 Offline
dbran451  Offline
ohio
Bob just bite the bullet and by a set of Fel-Pros
Re: Are there any members here that sell ROL gaskets? [Re: dbran451] #647194
03/29/10 08:56 PM
03/29/10 08:56 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Which part number?
Re: Are there any members here that sell ROL gaskets? [Re: ProSport] #647195
03/30/10 02:36 AM
03/30/10 02:36 AM
Finland
Hessu Offline
Hessu  Offline
Finland
Few years ago I buy 5 set of rol hi temp head gaskets from falcon performance:
http://stores.ebay.com/Falcon-Sales-e-Store
At that time they were really cheap.
But gaskets and bill game from internalengineparts:
http://internalengineparts.com/
Re: Are there any members here that sell ROL gaskets? [Re: Hessu] #647196
03/30/10 04:11 PM
03/30/10 04:11 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Thats to bad the ROL has become so hard to come by! That has been a great gasket for us even at 13.5:1 never an issue!!! I will have to check my local connection and stock up if he can still get them!
Re: Are there any members here that sell ROL gaskets? [Re: cl440] #647197
03/30/10 05:09 PM
03/30/10 05:09 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Chuck let me know if you find any.
This is really getting frustrating. Especially when all these places are closed by the time I get home from work.
Re: Are there any members here that sell ROL gaskets? [Re: ProSport] #647198
03/30/10 05:39 PM
03/30/10 05:39 PM
ohio
dbran451 Offline
dbran451  Offline
ohio
Which part number?
z1009 4.410 bore .039 compressed
z1039 4.590 bore .051
1105 4.590 bore .051
take your pick and grab your wallet
Re: Are there any members here that sell ROL gaskets? [Re: dbran451] #647199
03/30/10 06:39 PM
03/30/10 06:39 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Ok, 1039 is a composition gasket, the 1105 is a steel core laminate. I'm deciding between those 2, which one is best for my 400 block and 440-1 heads?
I'm gonna avoid the 1009, too many horror stories of them overhanging the bore.
But I'm also still wondering what is 'wrong' with the Mopar P4349559 gasket??
Re: Are there any members here that sell ROL gaskets? [Re: ProSport] #647200
03/30/10 07:11 PM
03/30/10 07:11 PM
ohio
dbran451 Offline
dbran451  Offline
ohio
I am not posative but that mopar gasket is a 1009 felpro
I used the 1039 on my low deck with b1bs heads we used 1105s on a low deck with origanl b1
Re: Are there any members here that sell ROL gaskets? [Re: ProSport] #647201
04/01/10 11:26 AM
04/01/10 11:26 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
I just put a call into my "connection" hope to hear something shortly! I will let you know as soon as I can.
Re: Are there any members here that sell ROL gaskets? [Re: cl440] #647202
04/02/10 08:48 AM
04/02/10 08:48 AM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Bob you have a PM
Re: Are there any members here that sell ROL gaskets? [Re: cl440] #647203
04/02/10 09:45 AM
04/02/10 09:45 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I'm in for a couple spare sets too if the connection works out.
We found something that works great for us, then they stop making it
Bob I tried to find specs on the MP gaskets, and like so many pieces Shep set up, the bill of materials is blank...
Rich H.
Esse Quam Videri
Re: Are there any members here that sell ROL gaskets? [Re: ProSport] #647204
04/02/10 03:46 PM
04/02/10 03:46 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Who makes the Eddlebrock gaskets?
They are white, 4.450" .038"
http://www.summitracing.com/parts/EDL-7325/
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Are there any members here that sell ROL gaskets? [Re: Hemi Allstate] #647205
04/02/10 04:06 PM
04/02/10 04:06 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Corteco..which is now ROL!! And they are not white anymore,they are a light blue color.
Nautilus Racing-
Re: Are there any members here that sell ROL gaskets? [Re: ZIPPY] #647206
04/06/10 01:11 PM
04/06/10 01:11 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Well the connection worked out but I ordered 6 and only received 4. The last 2 are on back order but I was told not to expect to see them.......ever!
I will have to be selfish and keep these 4 for myself! Sorry! If the other 2 come in I will let you know but don't hold your breath, it does not sound promising!
Re: Are there any members here that sell ROL gaskets? [Re: Chris2581] #647207
04/08/10 06:09 PM
04/08/10 06:09 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
So are these Edelbrock Corteco's any good? Seem awful cheap in price.
Page 2 of 3 1 2 3
