Re: Are there any members here that sell ROL gaskets?
[Re: ProSport]
#647188
03/28/10 09:51 AM
03/28/10 09:51 AM
Posts: 5,894 Florida
Locomotion
Talk about a run-around. I called Corteco and finally someone answered but he seemed kinda clueless on where to order them from, he gave me a customer service number, 1-800-327-1027, but nobody has answered yet.
That's the ROL tech # in Orlando. When I called Corteco they told me to call ROL also. Makes sense if they sold the gasket line to them. Try again next week. They may have a lot going in in the middle of ownership and/or product line changeover.
[Re: Locomotion]
#647189
03/28/10 10:34 AM
03/28/10 10:34 AM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
As I mentioned earlier. they are in a lot of turmoil at the present time.Probably not your best choice at the moment. When they move everything to Mexico, I dont know if it will get much better. There are other gaskets to use.
Myron, I'll try and call you sometime soon.
Todd
RIP Monte Smith
[Re: CompWedgeEngines]
#647190
03/28/10 10:42 AM
03/28/10 10:42 AM
Locomotion
Myron, I'll try and call you sometime soon. Todd
They might move manufacturing to Mexico, but they just moved their Florida (main?) offices from Oviedo to Orlando and appear to be packaging ROL products there also.
[Re: ProSport]
#647192
03/28/10 09:36 PM
03/28/10 09:36 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Summit DOES have this one in stock.......
P4349559 4.38 bore No lock wire .040 thick $59.95 per pair. For up to 12.5 to 1 compression.(I'm about 11.8 to 1)
These any good? Or any of the other MP gasket's I've mentioned?
[Re: ProSport]
#647198
03/30/10 05:39 PM
03/30/10 05:39 PM
Posts: 654 ohio
dbran451
ohio
Bob just bite the bullet and by a set of Fel-Pros
Which part number?
z1009 4.410 bore .039 compressed z1039 4.590 bore .051 1105 4.590 bore .051
take your pick and grab your wallet
[Re: dbran451]
#647199
03/30/10 06:39 PM
03/30/10 06:39 PM
ProSport
Akron, Ohio
Ok, 1039 is a composition gasket, the 1105 is a steel core laminate. I'm deciding between those 2, which one is best for my 400 block and 440-1 heads?
I'm gonna avoid the 1009, too many horror stories of them overhanging the bore.
But I'm also still wondering what is 'wrong' with the Mopar P4349559 gasket??
[Re: ProSport]
#647200
03/30/10 07:11 PM
03/30/10 07:11 PM
Posts: 654 ohio
dbran451
ohio
I am not posative but that mopar gasket is a 1009 felpro I used the 1039 on my low deck with b1bs heads we used 1105s on a low deck with origanl b1
[Re: ProSport]
#647201
04/01/10 11:26 AM
04/01/10 11:26 AM
Posts: 2,563 S.E. Michigan
cl440
S.E. Michigan
Chuck let me know if you find any.
This is really getting frustrating. Especially when all these places are closed by the time I get home from work.
I just put a call into my "connection" hope to hear something shortly! I will let you know as soon as I can.
[Re: cl440]
#647203
04/02/10 09:45 AM
04/02/10 09:45 AM
Posts: 17,881 S.E. Michigan
ZIPPY
S.E. Michigan
I'm in for a couple spare sets too if the connection works out. We found something that works great for us, then they stop making it Bob I tried to find specs on the MP gaskets, and like so many pieces Shep set up, the bill of materials is blank...
Rich H.
Esse Quam Videri
[Re: ProSport]
#647204
04/02/10 03:46 PM
04/02/10 03:46 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
Who makes the Eddlebrock gaskets? They are white, 4.450" .038" http://www.summitracing.com/parts/EDL-7325/Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#647205
04/02/10 04:06 PM
04/02/10 04:06 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Corteco..which is now ROL!! And they are not white anymore,they are a light blue color.
[Re: ZIPPY]
#647206
04/06/10 01:11 PM
04/06/10 01:11 PM
cl440
S.E. Michigan
Well the connection worked out but I ordered 6 and only received 4. The last 2 are on back order but I was told not to expect to see them.......ever! I will have to be selfish and keep these 4 for myself! Sorry! If the other 2 come in I will let you know but don't hold your breath, it does not sound promising!
