A-Body Idler arm clearance issue!! #646889
03/21/10 12:48 PM
03/21/10 12:48 PM
New Jersey
U_Code_Cuda Offline OP
New Jersey
I am having a major clearance issue with my Idler arm and Hooker Super comp 5116 Headers on my 71 Demon 340?? When the wheel is turned right major rub then it jumps over tube and needs to be wedged back over the tube
It is a R3 block with stock motor mounts....could that be the reason?? I do not want to ding the header yet but, is there any other choice??
1970 R/T Challenger 4-speed
1971 Demon 340 3-speed
Re: A-Body Idler arm clearance issue!! [Re: U_Code_Cuda] #646890
03/21/10 08:30 PM
03/21/10 08:30 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
If it's the stud I could consider replacing the steering gear and center link/idler arm/pitman arm with 73-76 parts.
If the idler runs above the header tube and it's the body of the idler hitting I'm not much help.
