Educate me on cam specs and their effect on motor #64684
05/27/08 05:54 PM
05/27/08 05:54 PM
Davenport, IA
70shaker Offline OP
70shaker  Offline OP
Davenport, IA
I have a 472 Hemi with a solid roller that is a street car. It does not sound agressive enough for my taste. It is a Comp Cams with specs:
lift .616 int .577 ex.
285 duration at .015 lift
110 lobe seperation
I have an old Lunati roller left over from my racing days that I am toying with installing based on input from you guys. It has specs:
lift .600 int .602 ex.
.320 duration at .015 lift
106 lobe seperation
I know the bigger duration will give it a more aggresive sound but what is the effect of lobe seperation on a cam's function.
Thnks in advance for educating me.
Ex Hemi Racer
70 Challenger Hemi 4 speed clone
Re: Educate me on cam specs and their effect on motor [Re: 70shaker] #64685
05/27/08 06:20 PM
05/27/08 06:20 PM
Davenport, IA
70shaker Offline OP
70shaker  Offline OP
Davenport, IA
Never mind guys. I should have done some checking elsewhere. The Comp Cams website has all of the info I was looking for.
Ex Hemi Racer
Re: Educate me on cam specs and their effect on motor [Re: 70shaker] #64686
05/27/08 08:36 PM
05/27/08 08:36 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Just narrowing the Lobe Seperation angle from 110 to 106 would make a big difference in "sound" because you will increase the amount of overlap when both the intake and exhaust valve are open.
Re: Educate me on cam specs and their effect on motor [Re: 451Mopar] #64687
05/28/08 12:36 AM
05/28/08 12:36 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
gets sound, but sacrifice vacuum, for brake booster, also get more rough iddle.
Of course gets also a great boost at High RPMs
( that's why I have read )
Re: Educate me on cam specs and their effect on motor [Re: 70shaker] #64688
05/28/08 06:54 AM
05/28/08 06:54 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Re: Educate me on cam specs and their effect on motor [Re: NachoRT74] #64689
05/28/08 07:59 AM
05/28/08 07:59 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
actually a narrow lobe separation maximizes mid-range torque and drops off faster in the upper RPM range. a wider lobe separation will flatten out the torque curve, and sacrafice a little in the midrange, but carry the torque higher in the rev range, making more upper RPM power for a given duration.
2017 Grand Cherokee Overland
