Crazy ignition switch troubles. #64598
05/27/08 03:23 PM
05/27/08 03:23 PM
Arkansas
340727dart Offline OP
Arkansas
Today, I accidentally found out I can start my '71 Dart without a key.
The switch turns without a key in it and I can start the car.
Does that mean the ignition switch is bad, or is it the locking mechanism?
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
Re: Crazy ignition switch troubles. [Re: 340727dart] #64599
05/27/08 04:19 PM
05/27/08 04:19 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I would say cilinder got broken
Re: Crazy ignition switch troubles. [Re: NachoRT74] #64600
05/27/08 05:43 PM
05/27/08 05:43 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Try shooting some WD40 or brake clean into the lock. Some times the cylinder gets dirty and the tumblers stick. In your case they maybe stick up making the lock unlocked all the time. Or the original owner was a cheap dude who removed the tumblers rather than replacing or rekeying the cylinder.
