Re: mechanical six-pack carbs.
[Re: Danan]
#64519
10/29/11 08:01 PM
10/29/11 08:01 PM
DaytonaTurbo
Manitoba, Canada
The mechanical six pack set-ups DO have accelerator pumps on the outboard carbs!!
Regarding six packs: I cannot believe how much BS (mis)information is floating around the internet, repeated and passed on my people who have never owned/run a six pack. Same thing with 426 hemis...
Yes, the mechanical secondary six pack carbs do have accelerator pumps, because they need them. It's basically just a holley double pumper spread out over 3 carbs. You need that accelerator pump shot to help cover the transition. What you definitely don't want to do is redneck a mechanical linkage to a set of vacuum carbs. That would perform horridly. Like was mentioned already, there used to be a company that would convert your vacuum carbs to have accelerator pump and mechanical linkage. But my question is at that point why wouldn't you just buy a pair of holley 2300 series carbs and run them?
[Re: 70sixpkrt]
#64520
10/29/11 09:02 PM
10/29/11 09:02 PM
Posts: 21 Mississauga, On.
Duster 371
Mississauga, On.
I had a set brand new in the box that I sold about 6 yrs ago. I can not find pictures of it with the box and part number. Sorry.
Holley part #s were 4782 and 4783
[Re: meepmeep70]
#64522
10/30/11 03:22 AM
10/30/11 03:22 AM
Posts: 3,687 South San Francisco, Ca
70sixpkrt
I was talking about the Edelbrock linkage. I sold the carbs and linkage at the same time. The linkage was brand new in the box and I had a pic of the Edelbrock part #.
[Re: 72383cudaman]
#64523
10/30/11 06:17 AM
10/30/11 06:17 AM
Posts: 511 Jasper, Indiana
fastnos
Jasper, Indiana
I do not have any part number for the progressive linkage. If you know of anyone with some old "Direct Connection Catalogs" the numbers should be in there, along with the numbers for the carbs too. Might be a starting point at least. Here are a couple of pics from the net over past few years of different linkages...
A True Hybrid: Burns Gas AND Rubber!
[Re: fastnos]
#64525
10/30/11 06:22 AM
10/30/11 06:22 AM
fastnos
Jasper, Indiana
and another...with vaccuum secondaries
[Re: fastnos]
#64526
10/30/11 06:28 AM
10/30/11 06:28 AM
fastnos
Jasper, Indiana
Last one, might be able to track down one of these by old NOS number on different web sites...?
[Re: fastnos]
#64528
10/30/11 09:10 AM
10/30/11 09:10 AM
Posts: 3,298 West Coast, USA
jbc426
West Coast, USA
I ended up with a very nice and simple heim-joint linkage from Ben at Promax. Also, using #6 banjo fuel fittings with good result & clearance.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: xs29j8]
#64531
10/30/11 03:49 PM
10/30/11 03:49 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I ran three 250 CFM Holleys with a homemade linkage setup for almost a decade. The throttle response was incredible, the best I have ever had on a carbureted car. Basically it was a 750 CFM triple-pumper... Downsides were around town fuel mileage and top end power due to the 750 CFM limit... 13.6s@ 102 MPH. The carbs were meant for a 289 Cobra, and bought new at a swap meet in Houston for $40/set of three. On the end carbs, I had to cut down the extended air horns to clear the cross bars n the air cleaners.
Here's a photo of the setup:
hmm a neat trick would be to get 3 FoMoCo 550's and run them.
[Re: Danan]
#64532
10/30/11 04:28 PM
10/30/11 04:28 PM
Posts: 3,916 usa
lewtot184
usa
ain't this the truth! i made my own linkage back in the day.
