Page 2 of 6 1 2 3 4 5 6
Re: 1968 Road Runner - paint code 999 - VIN, VON confused [Re: 6bblgt] #644631
03/19/10 01:39 AM
03/19/10 01:39 AM
Petaluma, CA
JimDiesel Offline OP
Petaluma, CA
I will check more tomorrow when I can see more.
behind kick panels - doesn't seem to really be painted.
Fender wheels - undercoated
Under package tray- looks like light gray or so with orange overspray.
There is a lot of orange everywhere. I am thinking that was the color, although the hood and roof most likely were repainted since the vinyl top and stripes were missing.
Was there a standard color primer?
68 Road Runner
67 Coronet
Re: 1968 Road Runner - paint code 999 - VIN, VON confused [Re: JimDiesel] #644632
03/19/10 02:00 AM
03/19/10 02:00 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Drivers side - 2841301
Passengers side - 2841300
Those numbers may be part numbers for the drip rail or panels. The number you're looking for it the same number(s) that is double stamped on the radiator support and matches the number on the lower (bottom) right on the fender tag. It should be on the top of the drip rail on the driver's side middle to rear on the drip rail and under the weather strip, see photo. You may have found the number with the arrow near it?
Re: 1968 Road Runner - paint code 999 - VIN, VON confused [Re: A12] #644633
03/19/10 07:04 AM
03/19/10 07:04 AM
Vicksburg, MI
coffeeman383 Offline
Vicksburg, MI
Is a VON the same as S.O. Number? And was it only used up to and including 1968?
PS I like the silver and the wheels!
Re: 1968 Road Runner - paint code 999 - VIN, VON confused [Re: coffeeman383] #644634
03/19/10 11:25 AM
03/19/10 11:25 AM
Brantford Ontario
69_SIX_PACK Offline
69_SIX_PACK  Offline
Brantford Ontario
Omaha Orange is a cool colour
Is that the actual car in the first pic before it was repainted silver?
Re: 1968 Road Runner - paint code 999 - VIN, VON confused [Re: coffeeman383] #644635
03/19/10 12:38 PM
03/19/10 12:38 PM
Basically the same thing. an SO number is the sales order number that was pre-printed on the dealers sales order forms and used as a portion/combination in different places such as the IBM, B/S, FT, and as the hidden numbers on the cars up until the 1969 year. In 1969 they changed this to a VON or vehicle order number which was still used in the various places mentioned above EXCEPT not for the hidden numnbers on the car bodies.
Re: 1968 Road Runner - paint code 999 - VIN, VON confu [Re: JimDiesel] #644636
03/19/10 01:33 PM
03/19/10 01:33 PM
Gabba Gabba Hey! NYC
Diego (not Ted) Offline
I disagree.
The code may specify a non-production color, but who's to say it's correct with *any* color?
I'd hate to have an owner with one of these regional CA cars paint it some other color and claim it's correct. In the end, the pedigree is lost unless a build sheet exists.
The fact that the current owner has found some orange on this car is pretty cool, though.
Re: 1968 Road Runner - paint code 999 - VIN, VON confu [Re: Diego (not Ted)] #644637
03/19/10 02:21 PM
03/19/10 02:21 PM
I disagree.
If it had a broadcast sheet it too would only show a 999 color code so it proves nothing regarding what the car was actually painted.
Re: 1968 Road Runner - paint code 999 - VIN, VON confu #644638
03/19/10 02:41 PM
03/19/10 02:41 PM
Petaluma, CA
Petaluma, CA
yes, the picture shows the condition of the car around the time we bought it. I know there are more pictures some where. I will have to look for them.
I will take some more pics this weekend of the interior and trunk.
As far as the original color, I don't think I will ever know for sure, but I am having a good time investigating.
Thanks for compliments on the silver - its a dodge viper color, The wheels are Edelbrock
wheels that they made for a very short time.
And Thanks for all Help/Advice!!
68 Road Runner
67 Coronet
Re: 1968 Road Runner - paint code 999 - VIN, VON confu [Re: JimDiesel] #644639
03/19/10 06:04 PM
03/19/10 06:04 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
my car is a 69 999, with 98e, omaha orange. I have all documents and fender tag. Don't know if this will help you, but, when I was prep for repaint, 98E was written in marker on the lower rad support. driver side. I found this under the paint on the factory primer. But mine is a 69.
you should be able to find that orange all over hidden to prove that color.
Re: 1968 Road Runner - paint code 999 - VIN, VON confu [Re: hemibeep] #644640
03/19/10 06:05 PM
03/19/10 06:05 PM
Tampa FL
hemibeep Offline
hemibeep  Offline
Tampa FL
also, my 69 build sheet shows 98e as paint code, not sure how that would work for 68.
Re: 1968 Road Runner - paint code 999 - VIN, VON confu [Re: hemibeep] #644641
03/19/10 06:16 PM
03/19/10 06:16 PM
Yes they had YOUR paint code in 69 but 68 is is only 999.
Re: 1968 Road Runner - paint code 999 - VIN, VON confu #644642
03/19/10 07:38 PM
03/19/10 07:38 PM
Wasn't aware it wasn't indicated. I know in GMs it sometimes or usually is.
Re: 1968 Road Runner - paint code 999 - VIN, VON confu [Re: Diego (not Ted)] #644643
03/20/10 11:59 AM
03/20/10 11:59 AM
Petaluma, CA
Petaluma, CA
Couple more pics of the car when it was purchased
68 Road Runner
67 Coronet
Re: 1968 Road Runner - paint code 999 - VIN, VON confu [Re: JimDiesel] #644644
03/20/10 12:00 PM
03/20/10 12:00 PM
Petaluma, CA
Petaluma, CA
#2
68 Road Runner
67 Coronet
Re: 1968 Road Runner - paint code 999 - VIN, VON confu [Re: JimDiesel] #644645
03/20/10 12:01 PM
03/20/10 12:01 PM
Petaluma, CA
Petaluma, CA
Some cop wheels that were on it for a bit after repaint
68 Road Runner
67 Coronet
Re: 1968 Road Runner - paint code 999 - VIN, VON confu [Re: JimDiesel] #644646
03/20/10 12:23 PM
03/20/10 12:23 PM
Petaluma, CA
Petaluma, CA
Found the SO number in trunk.
It matches th radiator support and fender tag.
Heading to work for a bit.
I will try to take apart the interior and snap some pics tomorrow.
I am excited that this car appears to actually be a special order car.
68 Road Runner
67 Coronet
Re: 1968 Road Runner - paint code 999 - VIN, VON confu [Re: JimDiesel] #644647
03/20/10 01:35 PM
03/20/10 01:35 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
There is an original owner 68 RR car locally in So Cal. The car was bought new in So Cal. (Burbank C-P?) The car was featured in Mopar Collectors Guide a while back. He bought it right off the dealer lot. He did not special order it.
So not all 68 Omaha Orange cars were originally sold up in No Cal.
Yes, I reallize Scott did not say they all were up there. But there I've seen other people assume that.
http://www.autotraderclassics.com/articl...sationId=159631
Fall Fling 28 October 19, 2024 at Woodley Park, Van Nuys CA
300+ Mopars, 125+ swap, midway, Friday Malibu cruise,
Re: 1968 Road Runner - paint code 999 - VIN, VON confu [Re: autoxcuda] #644648
03/20/10 02:31 PM
03/20/10 02:31 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
it also has the rocker molding, which is rare in 68.
Re: 1968 Road Runner - paint code 999 - VIN, VON confu [Re: ademon] #644649
03/20/10 03:14 PM
03/20/10 03:14 PM
Petaluma, CA
Petaluma, CA
DAMN
Awesome Pics Cuda!
Thats what my car should look like!
Except with Vinyl Top and black stripes
68 Road Runner
67 Coronet
Re: 1968 Road Runner - paint code 999 - VIN, VON confu [Re: JimDiesel] #644650
03/20/10 03:43 PM
03/20/10 03:43 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Found the OS number in trunk.
It matches Rad support and fender.
Also notice what color the paint is down inside those numbers
