Page 2 of 3 1 2 3
Re: Another heated pinion angle debate!!!!! [Re: maximum entropy] #643814
03/21/10 01:09 PM
03/21/10 01:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
what's a heated pinion angle?
Thats when you use a torch to change the angle... LOL
Re: Another heated pinion angle debate!!!!! [Re: DoctorDiff] #643815
03/21/10 01:10 PM
03/21/10 01:10 PM
Canada
CrAzYMoPaRGuY Offline
Canada
This is how I define those terms:
Pinion angle: Relationship between the pinion centerline and the transmission centerline.
Operating angle: Slope of the driveshaft.
Here's the problem with that definition, IMO....
Can you set the pinion angle in a vehicle with a two piece driveshaft?
Can you set the pinion angle in a 4x4, front or rear differential?
How??
(C'mon Quicktree.... )
CrAzYMoPaRGuY
Re: Another heated pinion angle debate!!!!! [Re: moparniac] #643816
03/21/10 01:13 PM
03/21/10 01:13 PM
Canada
Canada
yea old Vedgie has been over on the bullet trying to find out how many stupid threads he can start.
here for old times sakes
You musta read it 100 times Tony, but once more won't hurt you....
http://www.markwilliams.com/driveshafttech.aspx
CrAzYMoPaRGuY
Re: Another heated pinion angle debate!!!!! [Re: CrAzYMoPaRGuY] #643817
03/21/10 01:19 PM
03/21/10 01:19 PM
Q
Quicktree Offline
Quicktree  Offline
Q
How??
we drag race and work on drag cars not 4 wheel drives and 2 piece drive shaft equipped vehicles. go find you a 4x4 or bus forum I am sure they can tell you how they do it. either that or ask sixpackgut
Re: Another heated pinion angle debate!!!!! [Re: Quicktree] #643818
03/21/10 01:24 PM
03/21/10 01:24 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
How??
Hummm.... Can you say constant velocity joint
Re: Another heated pinion angle debate!!!!! [Re: Quicktree] #643819
03/21/10 01:30 PM
03/21/10 01:30 PM
Canada
Canada
How??
4x4 guys figure THEIR pinion angles are JUST AS IMPORTANT to their drivelines as you figure pinion angles are to your cars.
If you need to dismiss the actual definition when it comes to certain vehicles then so be it, but unless YOUR version of what a pinion angle's TRUE definition is can be used to set up a race car, a 4x4, a street car, or a 1978 Dodge 2wd pickup with a two piece driveshaft.... well, it probably means you should redefine what YOUR definition is, don't ya think?
I have NOOOOO doubt what you do to set up your pinion angle will work, and it most likely will be exactly what I do to set up MY pinion angle, it's your DEFINITION of pinion angle that has me scratching my head year after year.
An operating angle being the driveshaft slope doesn't even make sense to me, different driveshaft slopes to different tranny and differential angles, height differences etc would have "operating angles" that were defined by driveshaft slope all over the place.
From the Mark Williams site... once again, and as was posted above in a diagram or two by others....
"Operating angles in a driveshaft are the angles between the pinion, driveshaft and transmission centerlines."
That's the definition I go by.
It can be used for a street car, a race car, a 4x4, a bus, whatever, and it works. Once set the PINION ANGLE can THEN be achieved.
Left two columns are setting up the OPERATING angle, and then and only then is the pinion angle set. The right column is the PINION ANGLE, which is set AFTER the operating angle is set....
CrAzYMoPaRGuY
Re: Another heated pinion angle debate!!!!! [Re: CrAzYMoPaRGuY] #643820
03/21/10 01:38 PM
03/21/10 01:38 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you don't have to worry about what you call it. you will never make it to the track to find out
Re: Another heated pinion angle debate!!!!! [Re: Quicktree] #643821
03/21/10 01:40 PM
03/21/10 01:40 PM
Canada
Canada
This summer I'll be there.
I'll have an English cap and some Grey Poupon, but I'll be breaking parts with ya!
And you have to admit... you ALMOST hit my 6.66 prediction....
CrAzYMoPaRGuY
Re: Another heated pinion angle debate!!!!! [Re: CrAzYMoPaRGuY] #643822
03/21/10 01:42 PM
03/21/10 01:42 PM
Q
Quicktree Offline
Quicktree  Offline
Q
we ran 6.57 last week
Re: Another heated pinion angle debate!!!!! [Re: Quicktree] #643823
03/21/10 01:44 PM
03/21/10 01:44 PM
Canada
Canada
You are running nitrous or lightening the car or SOMETHING to get away from my predicted number, ADMIT IT!!!!!!!!!!!!!!!!
6.66 is your destiny......
CrAzYMoPaRGuY
Re: Another heated pinion angle debate!!!!! [Re: CrAzYMoPaRGuY] #643824
03/21/10 03:54 PM
03/21/10 03:54 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Once again...I don't worry about the driveshaft angle unless the suspension is severely raised or lowered.
If the U-joints are close to binding (ie. lifted 4 x 4 truck), I alter the transmission centerline a few degrees to straighten out the driveshaft angle. I set the pinion parallel to the transmission, then I roll the pinion downward "X" degrees to acheive the desired "pinion angle".
Any other method is strictly hit or miss.
Re: Another heated pinion angle debate!!!!! [Re: DoctorDiff] #643825
03/21/10 04:55 PM
03/21/10 04:55 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Needed to add this thread to my favorites.
Re: Another heated pinion angle debate!!!!! [Re: DoctorDiff] #643826
03/21/10 06:53 PM
03/21/10 06:53 PM
Canada
Canada
I think everybody, or MOST everybody... does it the same way. It's just what is called actual "pinion angle" or how the actual "pinion angle" is set, by itself, that has people arguing... year after year.
CrAzYMoPaRGuY
Re: Another heated pinion angle debate!!!!! [Re: CrAzYMoPaRGuY] #643827
03/21/10 07:36 PM
03/21/10 07:36 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I cant figure out what all the fuss is over rear pinion angle, That's the easy one to do, its the front drive axle that's a PITA
Re: Another heated pinion angle debate!!!!! [Re: emarine01] #643828
03/24/10 03:54 PM
03/24/10 03:54 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Alright...bumping this one back to the top instead of creating a new thread!
operating angle--the angle between the drive shaft to transmission and drive shaft to pinion, yes?
so, I want to set my operating angle first, THEN set my pinion angle?
or should I totally ignore operating angle and just make sure trans and pinion are parallel?
what is the preferred operating angle? isn't there a number that is preferred so that it promotes the needle bearings to rotate?
I can set this by shimming the trans shaft up or down, right?
THEN, once I have the operating angle, I set the pinion angle to be parallel to the transmission? or I set it to be 4-5 degrees nose down from the transmission?
WHY IS THIS SO CONFUSING?!?! I've read several times that you want to set the pinion to be parallel to the trans, THEN rotate the pinion down 4-5 degrees...WHY!? THEN IT'S NOT PARALLEL!
I realize axle wrap under acceleration will bring it back into being parallel, but I'm trying to chase down my vibration that is constant at certain speeds. it vibrates under acceleration, cruising, AND deceleration.
one place I read that if it vibrates on acceleration, to rotate it pinion down, and if it vibrates on deceleration, to rotate it pinion up.
what about when it always vibrates?
with the truck on jack stands, my transmission center line is about 2 degrees off from my pinion center line, so my angles definitely need adjustment...but do I set the pinion to be parallel to the trans NOW, or do I set it to be 4-5 degrees nose down from the trans? if I go nose down, won't that make my truck vibrate when cruising under light load and when slowing down?
**Photobucket sucks**
Re: Another heated pinion angle debate!!!!! [Re: 70Cuda383] #643829
03/24/10 04:53 PM
03/24/10 04:53 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
you turn the driveshaft 180 and see if it still vibrates.
Re: Another heated pinion angle debate!!!!! [Re: blownzoom440] #643830
03/24/10 04:59 PM
03/24/10 04:59 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
nope. hadn't done that. Hadn't thought about it. I've heard that before but never understood why.
how does turning it affect the vibration?
Re: Another heated pinion angle debate!!!!! [Re: 70Cuda383] #643831
03/24/10 05:04 PM
03/24/10 05:04 PM
ELYRIA,OH
ELYRIA,OH
it changes the weight if there is any to change.
Re: Another heated pinion angle debate!!!!! [Re: blownzoom440] #643832
03/24/10 05:20 PM
03/24/10 05:20 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
what weight? I'm confused...the drive shaft was balanced off the vehicle and is balanced. how does rotating it 180 degrees affect a neutrally balanced shaft? the front slip yoke would rotate 180 degrees with the shaft, and the rear yoke...wasn't in consideration when the shaft was balanced.
Re: Another heated pinion angle debate!!!!! [Re: 70Cuda383] #643833
03/24/10 05:45 PM
03/24/10 05:45 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The vibration is either caused by the angles at the u-joints,drive train alignment or other componants.The shaft alone will not cause the issue unless it is damaged(bent) or yoke alignment is off or totally out of balance.Since it is a straight tube,with the correct yoke orientation and balanced I would look at the angles,alignment and componants.
Page 2 of 3 1 2 3
