Page 2 of 4 1 2 3 4
Re: 440 Source Stealth Heads [Re: dOc !] #642813
03/17/10 06:28 PM
03/17/10 06:28 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
No not poor quality, just common sense says to look a part over before you bolt on.
Re: 440 Source Stealth Heads [Re: ireland383] #642814
03/17/10 06:38 PM
03/17/10 06:38 PM
sixbbl69 Offline
sixbbl69  Offline
Oh here we go again. I'll take Stealths any day over Eddies for price.
and you get what you pay for.not saying anything bad about any head.
Re: 440 Source Stealth Heads [Re: ireland383] #642815
03/17/10 06:44 PM
03/17/10 06:44 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
COMMON SENSE ? .... so if you buy a complete motor or transmission ... you should DISassemble that and check-all the internals?
Re: 440 Source Stealth Heads [Re: dOc !] #642816
03/17/10 06:53 PM
03/17/10 06:53 PM
NotRussia
2
2fast4yourBrain Offline
Whack top Dodger
Whack top Dodger
2
NotRussia
I can understand changing the locks (and springs for high lift cams), but why change the retainers if you're not racing?
Something wrong w/them?
Seems like a waste. I think for added insurance, the heads should just come with 10* Comp locks.
Re: 440 Source Stealth Heads [Re: 2fast4yourBrain] #642817
03/17/10 07:10 PM
03/17/10 07:10 PM
Marcell, MN
68 Roadrunner Offline
Marcell, MN
For sure! I couldn't believe when the guy at 440 Source told me I had to change them because my cam was over .510 lift. Are a lot of guys buying aluminum heads and running small cams? Should just come with them standard IMO. So far that is my only complaint. I still don't have the motor assembled so I can't tell you how well they work!
1968 Roadrunner 383 auto .060 KB 400 domed pistons, Stealth heads, Torker intake, Holley 830, Lunati Voodoo cam 276/284, .513/.533, TCI 3500, 3.91 gears, all ARP fasteners,
Re: 440 Source Stealth Heads [Re: dOc !] #642818
03/17/10 07:42 PM
03/17/10 07:42 PM
San Gabriel, CA 91775
rexus31 Offline
rexus31  Offline
Double check the fitment of the head gaskets to make sure they do not breach the chamber.
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue 1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red 1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red "What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
Re: 440 Source Stealth Heads [Re: dOc !] #642819
03/17/10 08:04 PM
03/17/10 08:04 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
Crate Hemi was a perfect example of why that is a GOOD idea. If it comes out of a box assume it is FUBAR.
Kevin
Re: 440 Source Stealth Heads [Re: Twostick] #642820
03/18/10 12:37 AM
03/18/10 12:37 AM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
I don't get it. Why do people jump up and defend Edelbrock or 440 Source heads and say that you should expect to have to clean them up or do some work and yet in another post where people are complaining about a $75 sending unit and everyone agrees the aftermarket is to blame?
As consumers we should at least expect that a set of heads that costs from $1000 to $2000 and are promoted as bolt ons should at minimum have a proper valve job including spring heights and stem heights etc.
Allowing manufactures to send out product that has to be checked or realistically redone just enforces the behavior that they can turn out poor quality and we will continue to pay for it.
If they are turning out rough unfinished castings then sell them as such.
Re: 440 Source Stealth Heads [Re: iron6] #642821
03/18/10 01:56 AM
03/18/10 01:56 AM
smyrna,tn
draginmopars Offline
smyrna,tn
i bought an early set...I found out after porting / removing the pinch area, then went to check pushrod length, 3/8 were rubbbing with a .588 cam. I couldn't clearance the rods cause the wall was already thin
Called Manton got some 11/32 dia.
Been runnning them 2 years now no problems [image][/image]
Ha-Ha Racin
Havin Fun 101
Howard
68 "Cummins" Satellite
70 W-2 449 "More Door" Dart
70 340 Dart Swinger, 4spd
71 360 Dart Swinger
72 540/ 518 Dart Swinger
73 airwolf 446/a-500 Cuda
73 "Cummins" Crew cab-car hauler
84 446 Dodge Rampage (tube chassis)
92 CTD 11' flat bed
92 CTD club cab
07 Dodge Caliber
Re: 440 Source Stealth Heads [Re: GTXKen] #642822
03/18/10 09:10 AM
03/18/10 09:10 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Personally I think everyone takes the "bolt-on" or "ready to run" statement too literally.
Buying car parts is no different than buying a door at Home Hardware - it may need some material shaved off the edge before it closes or need the hinges moved a tad to fit.
Or how about buying a "ready to serve" TV dinner - sure its ready to serve ... AFTER you heat it up.
And then there's the fact that car guys are a picky bunch. I don't doubt that those heads are WAY better out of the box than any head that came on your original car BUT ... someone tore a set down and they weren't absolutely perfect so now everyone is expecting Super Stock quality parts when that was never the manufacturers intention to provide.
Let's face it guys, $1000 for a pair of aluminum heads is pretty damn cheap. And if you bolted them on with stock hardware (what they're made for) they'd likely work just fine and give you years of trouble-free service.
Re: 440 Source Stealth Heads [Re: Stanton] #642823
03/18/10 10:00 AM
03/18/10 10:00 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
As my machinist said they werent bad for a grand.They arent a $3000 set of heads.If my motor wasnt so radical and 4 speed I could have run them pretty much out of the box.But with a .588 solid cam I swapped stuff.Im still happy with them for the price.Even if they were hi buck heads I would have them checked anyway.Rocky
Chrysler Firepower
Re: 440 Source Stealth Heads [Re: Stanton] #642824
03/18/10 10:45 AM
03/18/10 10:45 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Well said Stanton!
Re: 440 Source Stealth Heads [Re: ireland383] #642825
03/18/10 10:54 AM
03/18/10 10:54 AM
Marcell, MN
Marcell, MN
Not too start an argument here. But I have to say I disagree. A bolt on part should be just that. I manage a Lumberyard / hardware store. When we sell a door it is ready to install. You don't need to adjust the hinges or trim the edge! (atleast not on a prehung door) If I was selling just a door slab that a person was going to retrofit into an old door frame...then that would be a different story. But I wouldn't advertise that as a "bolt on" type part. (like the heads are) If they are selling them as a "bolt on" then they should be ready to install. I can't even imagine selling someone a new steel entry door and then they had to move the hinges and "trim the edge". Just my
Re: 440 Source Stealth Heads [Re: ireland383] #642826
03/18/10 10:54 AM
03/18/10 10:54 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
The 510" lift max of the stock springs is probably due to the fact that the heads are a stock replacement type head- and compared to stock cams a 510 lift cam (509) is much much bigger/aggressive than stock. ???
Keep old mopars alive.
Re: 440 Source Stealth Heads [Re: 2boltmain] #642827
03/18/10 10:56 AM
03/18/10 10:56 AM
Marcell, MN
Marcell, MN
That makes sense. I guess I don't consider them a stock replacement head.
Re: 440 Source Stealth Heads [Re: 68 Roadrunner] #642828
03/18/10 10:57 AM
03/18/10 10:57 AM
Marcell, MN
Marcell, MN
Are a lot of guys really putting these heads on a totally stock motor?
Re: 440 Source Stealth Heads [Re: 68 Roadrunner] #642829
03/18/10 11:25 AM
03/18/10 11:25 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
THERE you go ...... now to the guy that compares a set of these (or any) heads to heating-up a TV dinner ? ...
Re: 440 Source Stealth Heads [Re: 68 Roadrunner] #642830
03/18/10 11:28 AM
03/18/10 11:28 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
I would suggest that THIS would be a major mistake .. it could slow the car down .. big-time.
Re: 440 Source Stealth Heads [Re: dOc !] #642831
03/18/10 11:49 AM
03/18/10 11:49 AM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Re: 440 Source Stealth Heads [Re: ireland383] #642832
03/18/10 11:54 AM
03/18/10 11:54 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Oh geese ..
GO heat-up yerrr TV dinner !
Page 2 of 4 1 2 3 4
