Parts needed to convert '71 440-4bbl to 440-6 pack? #64252
05/26/08 09:12 PM
05/26/08 09:12 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
have a 71 charger with a 440 4bbl (stock) and wondering what parts I need or kit I need to do a 6 pack conversion? anyone let me know?
Re: Parts needed to convert '71 440-4bbl to 440-6 pack? [Re: AHall] #64253
05/26/08 10:37 PM
05/26/08 10:37 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
You can order the kits from mopar performance and have everything new for around $2200 if you know where to look. Check the resource section here on the board.
Re: Parts needed to convert '71 440-4bbl to 440-6 pack? [Re: AHall] #64254
05/27/08 03:22 AM
05/27/08 03:22 AM
(Central) PA
Runner2go Offline
Runner2go  Offline
(Central) PA
This guy appears to be selling a complete setup... since he cooked his motor.
Might need throttle cable & spring brackets... or he might be including them, best to ask
Fairly complete set up
Bolting them on is pretty simple.
If you have AC your going to need to fabricate some new supports, cut the air cleaner or just remove the AC
Hopefully you already have 3sp whippers on a 71.
The Moparts Q&A section will hook you right up once you have one and are ready to bolt it on
1966 383, 4-sp Charger 38yrs
1970 440+6, 4-sp Road Runner 36yrs
1974 360, auto Challenger 25yrs,in Family 41yrs
2003 Ram 2500 QCLB 4x4 Cummins HO
2010 5.7L R/T 6sp Challenger - Mopar10
2018 392 Daytona Charger
Re: Parts needed to convert '71 440-4bbl to 440-6 pack? [Re: AHall] #64255
05/27/08 07:56 AM
05/27/08 07:56 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
Is this going in front of a 4-speed or 727? The reason I ask is the appropriate kick-down rod is needed for a 727.. The 4bbl and 6bbl rod are different... Using a 4bbl rod will cause the rod to hit the firewall wall at full-throttle...........
Troy
Houston Mopar Connection Club
Re: Parts needed to convert '71 440-4bbl to 440-6 pack? [Re: Runner2go] #64256
05/27/08 06:39 PM
05/27/08 06:39 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
it has A/C and the A/C will be staying.
Re: Parts needed to convert '71 440-4bbl to 440-6 pack? [Re: hemi68charger] #64257
05/27/08 06:39 PM
05/27/08 06:39 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
727
Re: Parts needed to convert '71 440-4bbl to 440-6 pack? [Re: AHall] #64258
05/27/08 06:40 PM
05/27/08 06:40 PM
DFW Texas
AHall Offline OP
AHall  Offline OP
DFW Texas
where do I get the 6 pack intake?
Re: Parts needed to convert '71 440-4bbl to 440-6 pack? [Re: AHall] #64259
05/27/08 06:56 PM
05/27/08 06:56 PM
Mattituck NY.
FJ6AAR Online content
FJ6AAR  Online Content
Mattituck NY.
Hi, try this place. I never bought from them so I can't tell you about service, but he appears to be knowledgable. I will be calling him eventually for some sixpack hardware. Rob
http://www.sixpackperformance.net/home.php?cat=294
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
