Re: Hemi fits toooooooooooo tight [Re: sthemi] #642435
03/17/10 11:22 PM
03/17/10 11:22 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Other side,
Also,
Are you using the correct brackets? there are two styles, one for E body that puts the engine in a different place...than yours..
Re: Hemi fits toooooooooooo tight [Re: sthemi] #642436
03/18/10 05:41 AM
03/18/10 05:41 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Other side,
Also,
e body motor mounts ?
do you have p numbers ?
never realized , thought hemi 71 e/b mounts
hemi mounts were same .. ?????????
thought stock hemi mounts were all common
i bet nitrousn is close .
ill bet theres polyloc mounts involved
and a polyueurethane rear tranny mount involved.
is there ?
http://shakerhood.com/index.php?cPath=26
http://www.megapartsusa.com/products.asp?cat=10&pg=2
Re: Hemi fits toooooooooooo tight [Re: sthemi] #642437
03/18/10 07:19 AM
03/18/10 07:19 AM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
Other side,
Also,
It should be set up for the 69 b-body. Right now its at the body shop. We have it as a roller now. I hope to get it home in the next few days. The valve cover is an easy fix. Steering box has several issues. I may be able to shim the gear box if thats possible. Or maybe shim the motor mounts? The valve cover can be milled and a small bump in the tower should get me an easy 1/4 inch of clearance.
Stock mounts, MP iron reads, Indy aluminum covers.
Re: Hemi fits toooooooooooo tight [Re: NITROUSN] #642438
03/18/10 07:23 AM
03/18/10 07:23 AM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
ooof you forgot to mention keeseler is in play here...
Re: Hemi fits toooooooooooo tight [Re: sogtx] #642439
03/18/10 08:48 AM
03/18/10 08:48 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
One thing I might add here, and I work on a lot of hemi stuff.
If you are planning on running headers and any of the aftermarket K frames, then you are best to resign yourself to going with manual steering. The P/S is a big headache otherwise.
If you have ever seen an original Hemi car with all original equipment-the fit is very tight in many areas. All it takes is for something to be "off" just a slight bit with the made up Hemi K frames that are available and you will have some serious fitment problems.
MB
Re: Hemi fits toooooooooooo tight [Re: HPMike] #642440
03/18/10 08:59 AM
03/18/10 08:59 AM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
MB
That's what I encountered w/ my Challenger. Other option for power steering is a J Body box that doesn't have the dome top. I had Firm Feel make one for me & Dennis shaved a little off the housing for extra clearance & add the stage 2 kit, as well. I've decided to go manual steering instead & save some weight, so will be selling the brand new J body box. I'll try to post pics.
Re: Hemi fits toooooooooooo tight [Re: Triggerfish] #642441
03/28/10 09:51 PM
03/28/10 09:51 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
Hows it fittin >
Re: Hemi fits toooooooooooo tight [Re: sogtx] #642442
04/20/11 07:21 PM
04/20/11 07:21 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Waiting to hear also....
Re: Hemi fits toooooooooooo tight [Re: astjp2] #642443
04/20/11 10:44 PM
04/20/11 10:44 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
Well I have another post a few weeks back on the headers. Here is what I did.
One I got a new Indy right side valve cover. It is made for tower clearance. It fit real nice and solved that issue.
Two I bought an original hemi K frame and basicly everything basicly still fit the same. The gear box did fit away from the frame an 1/16 on an inch so the box fit better. I contacted TTI and we discussed the issue. I took a lot of pictures and a lot of measurements. After TTI reviewed my info they requested that I send the left side header back. As of this past Monday they called me and said a new one was made and being jet hot coated. So hopefully in a couple weeks I will get the new header and get it togeather. Fingers crossed. I will say that TTI never blew me off or told me to pack sand. They asked for critical data which I provided and by doing so they are taking care of the problem. Will try to update this when I get working on it.
Re: Hemi fits toooooooooooo tight [Re: NITROUSN] #642444
04/21/11 04:06 AM
04/21/11 04:06 AM
QLD Australia
Keith Black® Offline
QLD Australia
I put the same k-member from the same people in my 68 charger.
Everything is very tight, just like yours. It's just the way they are, especially the TTI's. We had to modify mine/clearance to fit at the steering box & torsion bar area (2-1/4 primaries).
The Indy valve covers are larger than stock so no surprise there, even the other's are very close.
Darren Beale
Keith Black Racing Engines®
