Page 2 of 3 1 2 3
Re: Cranking Compression? [Re: MR_P_BODY] #641593
03/16/10 11:00 AM
03/16/10 11:00 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Does anyone know of a cranking compression calculator
to see what I should see for my engine... I'm going
to do a compression test today and a leak down but I
would like to know what it SHOULD be
thanks
http://www.wallaceracing.com/dynamic-cr.php
Re: Cranking Compression? [Re: MR_P_BODY] #641594
03/16/10 11:20 AM
03/16/10 11:20 AM
PA
moparacer Offline
moparacer  Offline
PA
Wallace has about every calculator you would ever need.
They have a dynamic and effective comp calculator.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Cranking Compression? [Re: moparacer] #641595
03/16/10 11:28 AM
03/16/10 11:28 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I use the KB site one. It's simple (aside from remembering the negative figure for dome volume/positive deck height) and is within 20psi of my results in most cases.
Re: Cranking Compression? [Re: moper] #641596
03/16/10 11:38 AM
03/16/10 11:38 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
the wallace racing cal. is real close with mine.
Re: Cranking Compression? [Re: mopar dave] #641597
03/16/10 12:28 PM
03/16/10 12:28 PM
MR_P_BODY Offline OP
Well with checking all the different calculators and
doing a compression check MAYBE I dont have the compression
I thought I had.... I cant believe I was that far off
when I checked the measurements when I built it....
it comes up with a 9.5 compression ratio on just about
all of them..... I did a leak down and that showed
pretty decent, from 2% to 7% ... no wonder
I'm
not making the power I figure it should
Re: Cranking Compression? [Re: MR_P_BODY] #641598
03/16/10 12:34 PM
03/16/10 12:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Too many variables..........just test it and you`ll know for sure. My experience shows that big duration cams w/lots of overlap generally show lower numbers for example: my 360 w/a dur. of 255@ .050 cranked bet 190-200 cold. My 470 w/275-280 dur.@.050 cranks bet 170-175 and my buddys low 8-sec chevy small block w/a BIG roller(don`t remember #`s) cranks at 155 or so.
Re: Cranking Compression? [Re: Thumperdart] #641599
03/16/10 01:33 PM
03/16/10 01:33 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
mine comes in at 9.5 dynamic with 200psi. this is with 11.4 static using a 268/272 solid roller.
Re: Cranking Compression? [Re: mopar dave] #641600
03/16/10 01:39 PM
03/16/10 01:39 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Are those advertised #`s or @.050?
Re: Cranking Compression? [Re: Thumperdart] #641601
03/16/10 01:41 PM
03/16/10 01:41 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Mike , my junk comes close on all of the above my cranking comp is 220 and the calcs are coming in @ 217 to 229 Remember to add in your cam advance cause it closes the intake earlier, the calc guys left that out
Re: Cranking Compression? [Re: emarine01] #641602
03/16/10 01:54 PM
03/16/10 01:54 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Try throwing altutude in the mix, I went from 1300 ft to 8400 ft and lost 45 psi on all 8 holes.
Now I tune for 6000ft which is what the track is. I thought I was going to have to change the cam but it doesnt seem to be the case.
Re: Cranking Compression? [Re: mopar dave] #641603
03/16/10 01:54 PM
03/16/10 01:54 PM
Thats the one thing ... I dont have a degree at 0,
my cam card only has .050 for the valve timing and
my cam is a 276/284
Re: Cranking Compression? [Re: MR_P_BODY] #641604
03/16/10 02:02 PM
03/16/10 02:02 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Mike, try adding like 25 or 30 to your .050 for a solid roller ramp and see what happens
Re: Cranking Compression? [Re: Thumperdart] #641605
03/16/10 02:41 PM
03/16/10 02:41 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
intake valve closes at 58*atdc and yes i believe that is at .050".
Re: Cranking Compression? [Re: mopar dave] #641606
03/16/10 02:55 PM
03/16/10 02:55 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
if i put the cam advance in i get 206 cranking with 216 volume to pressure index. whats the volume to pressure index representing or what does it mean?
Re: Cranking Compression? [Re: mopar dave] #641607
03/16/10 03:16 PM
03/16/10 03:16 PM
UK
602heavy Offline
602heavy  Offline
UK
Never found these calculators to be accurate , some of them ask for intake valve closure @ .050" & add 15* ............unless you know where the intake valve closes (seat) then it's a all guessing game.
Re: Cranking Compression? [Re: MR_P_BODY] #641608
03/16/10 03:37 PM
03/16/10 03:37 PM
AndyF Offline
AndyF  Offline
I don't see how you can work backwards to CR from cranking compression. Put a 16V system on there and the cranking compression will go up due to the faster cranking speed. Pull all the plugs and pull the carb off the intake and the cranking compression will go up a bunch. Do it warm and the cranking compression will go up.
Re: Cranking Compression? [Re: AndyF] #641609
03/16/10 04:00 PM
03/16/10 04:00 PM
One of the calculators stated it for a 300 crank RPM
and I am assuming they do some magic calculations to
come up with a number
Re: Cranking Compression? [Re: MR_P_BODY] #641610
03/16/10 04:13 PM
03/16/10 04:13 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
i used http://www.not2fast.com/turbo/compression/cranking_pressure.shtml
for intake opening I only have .050 also. in the instructions it says to add 40 (thats 20 degrees x 2) to the duration at .050 so i did and it came out to 166.
my cranking pressure is surprisingly 165
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: Cranking Compression? [Re: aarcuda] #641611
03/16/10 04:40 PM
03/16/10 04:40 PM
That comes out much closer(with in 5 psi)
Re: Cranking Compression? [Re: MR_P_BODY] #641612
03/16/10 07:23 PM
03/16/10 07:23 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
I'm
[/quote
Mike did you cc the block and the chamber? That will tell the truth. Don
Page 2 of 3 1 2 3
