stupid question, road lamp mounting position?
#641313
03/15/10 09:35 PM
03/15/10 09:35 PM
Posts: 346 indiana
mopar mike
indiana
70 cuda, where does a road lamp switch mount? i bought a kit and i cannot find it in the electrical section in the fsm? a pic of it mounted on the dash would be great. also it says to put the light green wire in the tan connector, there are two? a q4, and a q4a? is there a difference? how do i tell which is which? thanks moparts
Re: stupid question, road lamp mounting position?
[Re: Paul Jacobs]
#641317
03/16/10 03:53 PM
03/16/10 03:53 PM
Posts: 1,945 Grand Rapids MI
N9671X2
Grand Rapids MI
Here's a pic of an Oct built Cuda-It's my business partners and is 95% original.
Rally dash cars should be mounted onto the dash frame under neath the heater control bezel, attached to the metal frame, not the plastic. Dash frame, assuming correct year frame will have holes for it. Standard dash is on the switch panel, this panel would also be cut for it if it were an original roadlamp car, it not, you are going to probably have to get an exact location and modify.
[Re: mopar mike]
#641322
03/16/10 04:49 PM
03/16/10 04:49 PM
Posts: 210 Denmark, Helsingor
AAR70
Denmark, Helsingor
You can use both two tan connektors for the green road lamp wire .The tan connektors is acessery feeds.
[Re: N9671X2]
#641324
03/16/10 05:21 PM
03/16/10 05:21 PM
Posts: 1,039 INDIANA
Paul Jacobs
INDIANA
That would be nice to assume, but I have documented 5 early (sept/oct) cars with the switch in the same location as I pictured. Hence the reason I made it a point to state it was an early car. This car is still original down to it's tires, belts, hoses, vapor seperator, battery cables, exhaust system etc and there was no hole in the dash for the switch-and it's on the broadcast sheet. All these same early cars had argent Cuda tailpanel emblems too, as well as some other oddities. This I had to research thouroughly, because a car I was restoring was an early car, and had the switch in the "wrong" spot I thought. I not here to argue of course, just stating what I have found in research. Whether you choose to accept it or not is up to you. I've learned to many things over the past 25 years to accept anything as gospel! cheers ![](/ubbthreads/images/graemlins/beer.gif)
[Re: sawdust]
#641326
03/16/10 05:46 PM
03/16/10 05:46 PM
Paul Jacobs
INDIANA
Paul,
Which plant were they from, I am guessing Hamtrack?
Yes your correct-also the only plant I found which had the black tar exposed in the trunk on the front parting seam-tacky for sure!
