Re: stupid question, road lamp mounting position? [Re: DaytonaTurbo] #641333
03/17/10 08:20 PM
03/17/10 08:20 PM
ILL
mark7171 Offline
mark7171  Offline
ILL
Whatever interior peice you drill into will be very expensive to replace, once you put a hole through it. Be observant.
Seems that eveyone on this site is made of money?
Re: stupid question, road lamp mounting position? [Re: Snoopy] #641334
03/17/10 09:14 PM
03/17/10 09:14 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
70 Cuda, Oct 6, 1969 SPD, Rallye Dash. Road lamp location.
Don't mean to hijack - but Snoopy, in regards to your pic - do you know, or anyone else - did each car (with ralley dash)get it's frame drilled for a road lamp switch (the round hole next to the oval hole) - my dash frame does not have the round hole, but it does have the oval hole, and a roadlamp switch toggle does not fit through that oval hole - I tried to do it after putting together a complete original '71 roadlamp setup - just seems odd that they would drill out a frame here or there instead of casting it at the foundry when the frames were stamped - or did they have seperate roadlamp frames - non roadlamp frames that would be picked according to buildsheet when it came down the line - that makes more sense now that I think about it - don't know why they just wouldn't round out the oval for the switch - thanks - Joe
Re: stupid question, road lamp mounting position? [Re: Snoopy] #641335
03/17/10 09:34 PM
03/17/10 09:34 PM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
Nice picture of the bumper mounting. Question though, what is the deal with rubber bumper does the bracket mount on top or under the bumper bracket. Had a heck of a time getting my fog lamps mounted with original brackets as they (lamps) hit the bumper.
Re: stupid question, road lamp mounting position? [Re: shakerjoe] #641336
03/17/10 09:36 PM
03/17/10 09:36 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
My original and my backup both have the round holes and the switch fit in both frames.
Re: stupid question, road lamp mounting position? [Re: Snoopy] #641337
03/17/10 09:39 PM
03/17/10 09:39 PM
Snoopy Offline
Snoopy  Offline
Switch mounted in original 70 frame.
Re: stupid question, road lamp mounting position? [Re: Snoopy] #641338
03/17/10 10:28 PM
03/17/10 10:28 PM
Wausau Wi
Convertcuda Offline
Convertcuda  Offline
Wausau Wi
Snoopy you are the best. Thanks for the post. Could you do a 1 more: 1)shows the head marking of the bolt that goes through bumper bracket and then through the roadlamp bracket. You have been a great help OE detail.
Re: stupid question, road lamp mounting position? [Re: Convertcuda] #641339
03/17/10 11:15 PM
03/17/10 11:15 PM
Snoopy Offline
Snoopy  Offline
I don't have a decent picture that shows the bolt detail. Maybe Bill (gtx6970) or Paul can post a picture?
Re: stupid question, road lamp mounting position? [Re: Paul Jacobs] #641340
03/18/10 12:10 AM
03/18/10 12:10 AM
cataclysm80 Offline
cataclysm80  Offline
Here's a pic of an Oct built Cuda-It's my business partners and is 95% original.
Rally dash cars should be mounted onto the dash frame under neath the heater control bezel, attached to the metal frame, not the plastic. Dash frame, assuming correct year frame will have holes for it. Standard dash is on the switch panel, this panel would also be cut for it if it were an original roadlamp car, it not, you are going to probably have to get an exact location and modify.
That would be nice to assume, but I have documented 5 early (sept/oct) cars with the switch in the same location as I pictured. Hence the reason I made it a point to state it was an early car. This car is still original down to it's tires, belts, hoses, vapor seperator, battery cables, exhaust system etc and there was no hole in the dash for the switch-and it's on the broadcast sheet.
All these same early cars had argent Cuda tailpanel emblems too, as well as some other oddities. This I had to research thouroughly, because a car I was restoring was an early car, and had the switch in the "wrong" spot I thought.
I not here to argue of course, just stating what I have found in research. Whether you choose to accept it or not is up to you. I've learned to many things over the past 25 years to accept anything as gospel! cheers
That extra explanation helps a lot Paul. Thanks a bunch!
Tav
Re: stupid question, road lamp mounting position? [Re: cataclysm80] #641341
03/18/10 06:10 PM
03/18/10 06:10 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
great pics snoopy,that dash drawing of the harness routing gave me a bit more insight in this road lamp harness/connection dilema ive had for a couple of years.so when the snow melts and the sun begins to shine then im gonna do some connecting.do anyone know if its room ehnauf to get up under the dash and do the connecting without the need to remove the hole dashboard?as in what needs to be removed?.thanks
Re: stupid question, road lamp mounting position? [Re: cataclysm80] #641342
03/18/10 06:17 PM
03/18/10 06:17 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
hej igen. no mean to hijack but as we are on to road lamps..what i wonder is if one could put in and route a road lamp harness over the correct places up behind the dash?what parts of dash has to be removed to do it properly?have anyone tried.
Re: stupid question, road lamp mounting position? [Re: cuda-sweden] #641343
03/19/10 11:29 AM
03/19/10 11:29 AM
Harrisburg, Pa.
screamindriver Online content
screamindriver  Online Content
Harrisburg, Pa.
Snoopy's pic is accurate for the routing...So in order to get the harness through the correct clamps you'll need to pull out the gauge cluster and possibly the ashtray to add the wiring and relay to a car that does'nt have it... And also since we're on the roadlamps...Here's an old post that shows the differences between the older repops and the original roadlamps...B/E&A has the roadlamps with the correct housings and stampings available.. .... link
Re: stupid question, road lamp mounting position? [Re: screamindriver] #641344
03/19/10 03:54 PM
03/19/10 03:54 PM
Wi , USA
O
oe convert Offline
oe convert  Offline
O
Wi , USA
Do have a pic of the correct style bolt that goes through the roadlamp bracket? Also, head marking?
Ken
Re: stupid question, road lamp mounting position? [Re: screamindriver] #641345
03/19/10 07:49 PM
03/19/10 07:49 PM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
Snoopy's pic is accurate for the routing...So in order to get the harness through the correct clamps you'll need to pull out the gauge cluster and possibly the ashtray to add the wiring and relay to a car that does'nt have it... And also since we're on the roadlamps...Here's an old post that shows the differences between the older repops and the original roadlamps...B/E&A has the roadlamps with the correct housings and stampings available.. . thanks for the tip,that link was great to.let there be light
