Re: which high amp alternator for LA? [Re: mshred] #640055
03/19/10 10:39 PM
03/19/10 10:39 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
It has one battery in the stock location AND I installed an extra one in the trunk.
To save the hassles of venting I chose a dry cell. It's also small for it's power and can be mounted any way except upside down.
I will take some pics of the install tomorrow.
Which area of Ontario are you in?
Re: which high amp alternator for LA? [Re: Magnum] #640056
03/20/10 06:32 PM
03/20/10 06:32 PM
Wisconsin
beecrazy69 Offline
beecrazy69  Offline
Wisconsin
I am running a cs130 GM alternator rated at 105 amps. It is off a late 80s early 90s gm (Cadilac 5.0L Fleetwood Brougham/ Caprice/ Pontiac Safari Wagon ....) It is internally regulated.
I found the info on Moparts (maybe the Tech Archives?) It is suppose to be a direct bolt in for non A/C big blocks, not sure on small blocks(mine has A/C). It needed 100 ohm 1 watt resistor in the field wire to the alt to be a dummy alt idiot light since Mopars don't use them on the dash.
It has 14.4 volts at idol!!! An 8 gauge charge back wire must be run to the post on the starter solenoid or it will cause an electrical fire to the bulkhead and dash wiring!!
Re: which high amp alternator for LA? [Re: beecrazy69] #640057
03/21/10 01:06 AM
03/21/10 01:06 AM
hooziewhatsit Offline
Sure looks like it would bolt on to a SB with the right spacer. Also looks like the housing could be re-clocked if the output stud is too close to the block.
