A12 Identification
#638821
03/13/10 01:40 PM
03/13/10 01:40 PM
Posts: 104 Pugetroplis WA
RallyeMike
Pugetroplis WA
I have found what is 99% chance an A12 Bee derelict with no fenders, grill, or drive train. Not sure if the body tag is present. The car is tucked away in a small town and friends of mine remember it new as an A12 from the 70's.
The property owner where it sits says he thinks the non-resident owner will sell it now, so I'm going to pursue it. What are 4 or 5 quick things to look at to tell positively it is an A12 car?
I appreciate the help !
"My top end is uuuuunlimited!"
Re: A12 Identification
[Re: RallyeMike]
#638822
03/13/10 01:52 PM
03/13/10 01:52 PM
Posts: 426 Mid-Atlantic
Scatransit
Mid-Atlantic
A few: 5th digit an "M" DANA rear 2 extra 1/2 leaves on right side spacers (about 1/8 inch thick) under lower control arm bumpers unique engine harness with the idle solenoid wire going to passenger side
[oo]======[oo]
[Re: Scatransit]
#638824
03/13/10 02:04 PM
03/13/10 02:04 PM
Posts: 3,379 KY USA
mopargem
KY USA
All A12's have an oval filler hole
68 Polara 500...LL1 Y7 M6X 69 Hemi road runner...X9 X9 M6X 69 A12 road runner....R4 R4 M6X 69 ModTop FLORAL Super Bee...F6 M6W 70 AAR 'cuda...EW1 EW1 H4X9 71 Duster 340...FJ6 V24 L6X9 71 road runner FC7 V1X M6X9 72 Rallye Charger B5 V1W 74 'cuda 360...KB5 V1X A6X9 08 SRT Challenger #234
[Re: mopargem]
#638825
03/13/10 04:27 PM
03/13/10 04:27 PM
Posts: 5,048 Atlanta Indiana
Dave Watt
Atlanta Indiana
Make sure the 5th digit in the VIN# is an "M" which is the 440+6 engine. Write down the entire VIN# for my A12 database. I agree with everyone above except for the leaf springs. I have Broadcast sheet documentation on many of the early build A12 cars where they were delivered with the standard Rallye suspension, 5 leafs per side. 99% of them have the Hemi suspension with 7 leafs on the passenger side though.
[Re: Scatransit]
#638827
03/13/10 05:28 PM
03/13/10 05:28 PM
RallyeMike
Pugetroplis WA
There is no drive train including the axle, so the leaf sprigs would be in question anyhow. Hood hinges can be removed, pins can be added, etc. All good stuff, but things like the solenoid wire .... Great stuff!
It's been awhile since I have been into B-bodies of this era. Is the oval gas filler hole a gag or is this really true? Why would they do that only on A12 cars?
Any more obscure items to look for?
[Re: RallyeMike]
#638828
03/13/10 05:55 PM
03/13/10 05:55 PM
Posts: 18,632 jersey shore
flypaper
I hate Texas
I hate Texas
jersey shore
they did it on all cars built after jan of 69 a12 cars were built after jan of 69
alot of the things that are listed here are most likely long gone on a gutted out a12 car.
what you should look for is the obvious m in the vin number on the dash vin tag does it have a fender tag ??? if yes, does it match the vin tag on the dash?? after looking for or at the fender tag, then look at the the front rad support and see if the last 6 digits of the vin with a 9a before it is stamped in to it. then you should go to the driver side trunk gutter and under the trunk lid seal should be those same numbers stamped in it as on the rad support. if those numbers match up you have a a12 car
good luck
ps bring back pics and numbers please
[Re: flypaper]
#638830
03/13/10 07:25 PM
03/13/10 07:25 PM
Dave Watt
Atlanta Indiana
Not to split hairs but to give accurate information, the numbers on the radiator support and trunk lip will actually be stamped A9 XXXXXX.
[Re: Scatransit]
#638831
03/13/10 07:32 PM
03/13/10 07:32 PM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
I think your suggestion about the 1/8" spacers under the rubber bumpers on the lower control arms is the best suggestion yet for a car that may be missing eveery other form of identification. It's unlikely anybody would have removed the bumpers and spacer plates! It should have holes in the front for the original hood pins even if someone added a hood with hinges at a later date. If there are hinges, you could remove them to check out the paint behind them to see how it's painted in that area?
[Re: 5126brl No more]
#638833
03/13/10 08:49 PM
03/13/10 08:49 PM
RallyeMike
Pugetroplis WA
Ok. I have my list. Should be enough clues if the fender tag happens to be missing. Thanks guys.
[Re: RallyeMike]
#638834
03/13/10 09:19 PM
03/13/10 09:19 PM
#638835
03/13/10 10:40 PM
03/13/10 10:40 PM
Posts: 1,400 Columbia Station, Ohio
69RTSE
A good way to tell is the owner will have bad attitude and tell you "Do you know what this is?" Hope this helps!
Seriously though, good luck. I hope everything works out for you. Hopefully we'll see some pictures soon....
