Re: overheating 440---could the head gaskets be on wrong??? [Re: F6F6Dodge] #638722
03/13/10 05:31 PM
03/13/10 05:31 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
It seems to be better on the interstate at highway speed, but once slowed down in traffic is when the vapor lock situation starts....As far as the fan goes-----I have a 7 blade big pitch after market direct drive fan-----it pulls air through the radiator like a vacuum cleaner.....
Ok what's the size of the radiator? I had a similar deal on my 64 Dodge...I went from a 2 core to a 3 core and never had a problem again. It got so hot once on a humid,hot summer night,it vapor locked shut-off & melted the shifter cable and was stuck in high gear...
Example if your using a small block radiator w/22 inch radiator support it will stay hot down the highway but with alot of air it helps get rid of heat under the hood. But then it gets really hot in traffic due to the low volume of water it has to cycle to keep cool even if the fan works great...
EDIT...Sorry I saw your post the one about the new 5 core it that's the case the top and bottom tanks must be huge...If they are stock tanks don't know how that would work...
Re: overheating 440---could the head gaskets be on wrong??? [Re: QuickBpBp] #638723
03/13/10 05:46 PM
03/13/10 05:46 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
I fought for years to get mine to cool..26 in rad 3 different types of cooling fans 2 different radiators ,,would be cool in traffic but heat up at highway speeds..Finally a guy had a radiator out of a Ford V10 pickup,,I made it fit,and with dual cooling fans it has a hard time getting to thermostat temp..I cant get it to run hot...most of the time I don't even use the fans, only when stopped in traffic...
Re: overheating 440---could the head gaskets be on wrong??? [Re: F6F6Dodge] #638724
03/13/10 06:13 PM
03/13/10 06:13 PM
Newfoundland Canada
Mopar1 Offline
Mopar1  Offline
Newfoundland Canada
New 5 core type radiator-------larger cam--pulls very little vaccuum around 11 pounds I think....standard 750 cfm Edelbrock carb...I'm thinking of taking the car to a Chassis Dyno to see if they can help---does this sound like a good idea or waste of money???
Cam size is the next larger than a six pack size...
Are the top and bottom tanks on the new rad stock size or are they larger? If the tanks are stock size I would suspect the rad. If you have 5 cores jammed into a stock tank the cores are going to be a lot smaller and will restrict coolant flow.
Re: overheating 440---could the head gaskets be on wrong??? [Re: Mopar1] #638725
03/13/10 10:11 PM
03/13/10 10:11 PM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
Have you put a thermometer in the hot coolant to see actual temp? Does the coolant circulate looking in the rad with the cap off?
Re: overheating 440---could the head gaskets be on wrong??? [Re: pacifica] #638726
03/13/10 11:10 PM
03/13/10 11:10 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Mismatched pulley set?
Shroud?
Timing?
That POS Eddy should be OK on the mix not being too lean. Still good idea to look at the plugs.
I 2nd a Milo or Eddy high flow pump. I use the Eddy, have on two BB's. Can't get them hot.
I want my fair share
Re: overheating 440---could the head gaskets be on wrong??? [Re: QuickBpBp] #638727
03/14/10 11:07 AM
03/14/10 11:07 AM
With a candy thermometer or a good mechanical gauge I'd find out exactly what your temps are (on the hiway and in town). Take the stat out for 1 day (the slower warmup wont hurt you just for 1 day). check for timing in the ballpark. Have a radiator shop suck up some rad coolant into the bottle and see if the blue fluid turns yellow (indicates a combustion leak) or if you have an emissions testing station close by have them stick the probe into the top of the rad & see if combustion gasses are present (you'll know in seconds). check for a vac leak (not sure the best way to do that). What do your plugs look like. You have a 5 row rad
Re: overheating 440---could the head gaskets be on wrong??? [Re: RapidRobert] #638728
03/15/10 12:46 AM
03/15/10 12:46 AM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
Is your new radiator still clean?
Was your block hot tanked?
I had a 383 block that sat for some time with the water galleries exposed to the air & once I started the engine & warmed it up scale started coming out & blocking the tubes in my top tank. I didn't think to check the radiator for some time as I had just re-cored it so I blamed everything else first. I had to get the tanks removed, core rodded re-soldered & I fitted a filter sock on the top hose nipple(& along inside the top tank), which I took off & cleaned every couple of weeks until all the scale had gone. Then I removed the sock & everything was back to normal.
I don't think the "rebuilt" engine I bought was hot tanked!
The scale in the block would not have helped with the cooling either.
Re: overheating 440---could the head gaskets be on wrong??? [Re: nz383man] #638729
03/15/10 05:20 PM
03/15/10 05:20 PM
Indiana
F6F6Dodge Offline OP
Indiana
The radiator still looks clean--there doesn't seem to be any scale build up.....
Does anyone know if there is a difference between a water pump in a 440 motor that has a/c vs. one without a/c???? if so--where can I get one??? I was told the regular pump has 8 blades and the a/c one only has 6 blades to push the water......Thanks again for all the help!!!!
Re: overheating 440---could the head gaskets be on wrong??? [Re: F6F6Dodge] #638730
03/15/10 06:00 PM
03/15/10 06:00 PM
Correct, as an A/C setup has a different pulley ratio to turn the WP pulley faster so the fan would move more air at idle/low speeds (to compensate for the A/C) but this would supposedly then make the WP cavitate at higher rpms from the faster WP impeller speed so they reduces the vanes to correct this. Myself I dont buy the cavitation worry and the $5 anticavitation disc welded on the 8 vane unit gives you much more flow.
Re: overheating 440---could the head gaskets be on wrong??? [Re: RapidRobert] #638731
03/15/10 06:46 PM
03/15/10 06:46 PM
Indiana
Indiana
Thanks for the help, but I may have stumbled upon the real problem.....from another post on this blog----it would involve the Edelbrock 750cfm carb #1411......according to the other blog---this carb SUCKS!!!! is this true????
Re: overheating 440---could the head gaskets be on wrong??? [Re: F6F6Dodge] #638732
03/15/10 06:50 PM
03/15/10 06:50 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Yes, its true
Re: overheating 440---could the head gaskets be on wrong??? [Re: GTX MATT] #638733
03/15/10 06:58 PM
03/15/10 06:58 PM
Indiana
Indiana
Could this be the reason my car runs hot-----lean condition from a P.O.S. carb???
Re: overheating 440---could the head gaskets be on wrong??? [Re: F6F6Dodge] #638734
03/18/10 05:53 PM
03/18/10 05:53 PM
Montreal Quebec
STROKIE Offline
STROKIE  Offline
Montreal Quebec
451 C.I. (400 block 440 crank)
750 cfm edelbrock (1411) No Problem with this carb...
22 inch rad, shroud,Mopar cluthfan
Milodon high volume water pump
and use more water instead of antifreeze if you
don't use your car during cold weather...
I use 90% Water 10% Antifreeze + 1 bottle of Waterwetter
Never had Overheating Problem
Re: overheating 440---could the head gaskets be on wrong??? [Re: F6F6Dodge] #638735
03/18/10 08:27 PM
03/18/10 08:27 PM
Been a few problems w the eddy 750 #1407. I believe your probem is elsewhere & been following this and I hope you discover it.
Re: overheating 440---could the head gaskets be on wrong??? [Re: RapidRobert] #638736
03/18/10 08:41 PM
03/18/10 08:41 PM
MN
58pwrwgn Offline
58pwrwgn  Offline
MN
You didn't say what kind of waterpump housing you were using, but this might be an interesting read. He had an over heating promblem with the top of the motor becoming hot.
Sorry, I can't get the address to post. Go to the engine section. It is locked as the third post down.
http://www.dodgecharger.com/forum/index.php/topic,60599.0.html
