Re: overheating 440---could the head gaskets be on wrong???
[Re: F6F6Dodge]
#638724
03/13/10 06:13 PM
03/13/10 06:13 PM
Posts: 1,806 Newfoundland Canada
Mopar1
Newfoundland Canada
New 5 core type radiator-------larger cam--pulls very little vaccuum around 11 pounds I think....standard 750 cfm Edelbrock carb...I'm thinking of taking the car to a Chassis Dyno to see if they can help---does this sound like a good idea or waste of money??? Cam size is the next larger than a six pack size...
Are the top and bottom tanks on the new rad stock size or are they larger? If the tanks are stock size I would suspect the rad. If you have 5 cores jammed into a stock tank the cores are going to be a lot smaller and will restrict coolant flow.
[Re: pacifica]
#638726
03/13/10 11:10 PM
03/13/10 11:10 PM
Posts: 10,230 Someplace you aren't
SomeCarGuy
Mismatched pulley set?
Shroud?
Timing?
That POS Eddy should be OK on the mix not being too lean. Still good idea to look at the plugs.
I 2nd a Milo or Eddy high flow pump. I use the Eddy, have on two BB's. Can't get them hot.
I want my fair share
[Re: nz383man]
#638729
03/15/10 05:20 PM
03/15/10 05:20 PM
Posts: 126 Indiana
F6F6Dodge
Indiana
The radiator still looks clean--there doesn't seem to be any scale build up..... Does anyone know if there is a difference between a water pump in a 440 motor that has a/c vs. one without a/c???? if so--where can I get one??? I was told the regular pump has 8 blades and the a/c one only has 6 blades to push the water......Thanks again for all the help!!!!
[Re: F6F6Dodge]
#638734
03/18/10 05:53 PM
03/18/10 05:53 PM
Posts: 338 Montreal Quebec
STROKIE
Montreal Quebec
Thanks for the help, but I may have stumbled upon the real problem.....from another post on this blog----it would involve the Edelbrock 750cfm carb #1411......according to the other blog---this carb SUCKS!!!! is this true????
451 C.I. (400 block 440 crank) 750 cfm edelbrock (1411) No Problem with this carb... 22 inch rad, shroud,Mopar cluthfan Milodon high volume water pump and use more water instead of antifreeze if you don't use your car during cold weather... I use 90% Water 10% Antifreeze + 1 bottle of Waterwetter Never had Overheating Problem
[Re: RapidRobert]
#638736
03/18/10 08:41 PM
03/18/10 08:41 PM
Posts: 137 MN
58pwrwgn
MN
You didn't say what kind of waterpump housing you were using, but this might be an interesting read. He had an over heating promblem with the top of the motor becoming hot. Sorry, I can't get the address to post. Go to the engine section. It is locked as the third post down. http://www.dodgecharger.com/forum/index.php/topic,60599.0.html
