Re: Torqueflite front drums
[Re: JohnRR]
#63781
09/09/08 11:24 AM
09/09/08 11:24 AM
Posts: 5,080 organ
maximum entropy
organ
i get all my stuff from cope. nice guy, good prices, great service. i think i paid 535.00 for my billet steel drum. i fit 6 clutches in it and probably could have fit 7 if i tried real hard. check his web site. i went with steel because i drive on the street occasionally.
[Re: PC-CHARGER]
#63789
11/11/09 10:07 AM
11/11/09 10:07 AM
Posts: 16,929 NC
440Jim
NC
To help understand what is needed or not I've tried below to explain the problem of sprag roller clutch failure on a Torqueflite.
Great explaination, I saved it on my computer for future reference.
[Re: PC-CHARGER]
#63790
11/11/09 10:20 AM
11/11/09 10:20 AM
Posts: 16,929 NC
440Jim
NC
Just a note about the quantity of plates in the front clutch.
FWIW, I run 5 frictions in my front clutch, and 165 psi line pressure (Griner valve body). That holds the torque of my 511 just fine. And after years and hundreds of passes, the wear was small.
[Re: zygotemrsmith]
#63793
05/06/11 12:06 PM
05/06/11 12:06 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
Ok, so Chrysler made about how many high performance cars with Torqueflites ? 383s,413s,440s and Hemis - where are all the people that filed lawsuit against Chrysler for exploding grenades in their cars when they took them for a romp. I have no doubt that most of those folks knew nothing about 2nd to 3rd burnout. Where are the recall notices to protect the public from these dangerous transmissions in all high horsepower Chrysler muscle cars. I am going to call some BS factor on a good bit of this.
[Re: John_Kunkel]
#63796
05/06/11 02:26 PM
05/06/11 02:26 PM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
It's simple, few stock motors can attain the rpm needed to cause drum failure.
This kid on big block dart did it with a 13 second car... It can happen to the stockers as well....
http://www.bigblockdart.com/forum/showth...erent-thread%29
[Re: Crizila]
#63800
05/06/11 11:11 PM
05/06/11 11:11 PM
Posts: 2 Texas
zygotemrsmith
Texas
Yet another take on the poorly engineered Torqueflite failure item --> On the RARE occation when a Torqueflite blows up in "Drive position/first gear", the sprag is often erroniously faulted. What happens is the sprag puts the pressure of the rollers directly against the transmission housing resulting in a spectacular explosion. I have only seen this in Drag cars with monstrous torque (built Hemi's and 440's) using 14x32" slicks. You won't have anything to worry about with the stock sprag They are popping out of the woodwork on this
