Re: 440-1 vs B1
[Re: moparniac]
#637543
03/12/10 06:26 PM
03/12/10 06:26 PM
Posts: 3,441 Mo.
supercomp
Mo.
my indy are CNC 345s
These look bigger. B1 Orig.
Re: 440-1 vs B1
[Re: supercomp]
#637544
03/12/10 06:39 PM
03/12/10 06:39 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
They both look sweet, but I know which makes more power. I've run stage 6, Indy -1 (only slightly better, but made more power when fully ported) and B1's. There is no comparison in power level.
Re: 440-1 vs B1
[Re: B1Fish540]
#637545
03/12/10 06:56 PM
03/12/10 06:56 PM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
the -1s when fully worked over(like GregsDart has done to his) will give the original B1 a run for its money..but in the end the B1 will win. The -1 is a great flowing "max wedge" type head whereas the B1 was designed from a clean sheet of paper with maximum flow in mind.
My heads have 365cc after hogging out for alky. That has to be the practical limit i would think. On power potential, "no comparison " is baloney. Look at my ET. I expect to better it by .2 this year with new head work and other engine improvements to compliment the increased flow. That is despite going back to a bias ply slick from a radial. They will never be on par with a B1 in fully ported condition, but can be made to run well for a head strangled with the size port opening they have and other restrictions. After putting 2.3 intakes in mine, head flow was better than B1 original ported heads up to about .500, landing at 396 cfm at .800 and 400 cfm at .900. The original porting numbers came off flow benches at three separate shops, so trying to say the numbers are bogus ain't gonna fly. I believe the practical limit on power is going to be performance of 8.50s at 2950 lbs. Should relate to 950 hp or there abouts. The gentleman that ported them, Radar from R & R in Iowa helped develop the B1 so he has his act together. He commented that a good build is about 2.45 hp per cfm of head flow. Hope I get there. That would be 970 hp.
Re: 440-1 vs B1
[Re: gregsdart]
#637546
03/12/10 07:24 PM
03/12/10 07:24 PM
Posts: 6,295 U.S.
moparniac
U.S.
whats fully ported b1's go ??? i know 8secbird on YB say baloney also as he has been 8.00 on nitrous in a big heavy roadrunner ... single plate i believe
Mopar Performance
Re: 440-1 vs B1
[Re: gregsdart]
#637547
03/12/10 07:28 PM
03/12/10 07:28 PM
camastomcat
Salt Lake City
This argument could go on for days. And I know who Radar is and his reputation for making power. I also had a nice set of stage 6 heads that worked well, but the cost me alot of money to get there. The Indy -1's were only slightly better than the stage 6's. So my point is, you could spend alot on the -1's and make a decent head out of them, or but a set of B1 originals or M/C's better yet, so why would you want to???? and the number one reasonis, you don't have to deal with Indy. Because talking to the Koffels is a pleasure, and their product is smokin. And if you can get a guy like Radar to port them, even better. JMHO, but PSO's are the next step as I don't want to buy new headers and already scare myself with the current powerplant.
Re: 440-1 vs B1
[Re: moparniac]
#637548
03/12/10 07:32 PM
03/12/10 07:32 PM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
Thats fine if bird wants to believe that. Maybe there is'nt a great deal of difference with both on nitrous..but races are won by .01s and .001s and, imo, B1s will always have the edge with evrything else equal.
Re: 440-1 vs B1
[Re: camastomcat]
#637550
03/13/10 01:31 AM
03/13/10 01:31 AM
Posts: 778 Sherwood park, Alberta.
go green
This picture is a perfect example of why you can not just compare port volumes . Case in point look at the port opening verses the deck height. pred vs b1 pred vs eddy I will take angle of entry more so than just simple port volume that why the pred kills the B1 stuff and why the b1 beats the 440-1 stuff. Having a big volume doesn't matter as much if you have to run uphill and then dump into the chamber.
Re: 440-1 vs B1
[Re: B1Fish540]
#637552
03/13/10 09:05 AM
03/13/10 09:05 AM
Posts: 147 Milledgeville, (central) Georg...
Bighead440
great post Go green! pics are worth a 1000 words. The straighter the shot the better! The B1 PSOs address that problem somewhat with much higher and rounder port. So in a nutshell, the higher the port and the longer the valve, the better!
Sounds like the old Brewer head... Got some I'm DYING to try someday... MAN what a shortblock they'd need... RB
Re: 440-1 vs B1
[Re: Diablo]
#637556
03/13/10 12:33 PM
03/13/10 12:33 PM
camastomcat
Salt Lake City
Just goes to show The Pred heads and TS heads can not even be put into the same category as any of the other heads just based on the port entry.
There's no argueing about that. They are both very impressive. I wonder if anybody has pics of the PSO's to compare?
Re: 440-1 vs B1
[Re: go green]
#637557
03/13/10 12:44 PM
03/13/10 12:44 PM
Posts: 61 N. IL
tntmachine
N. IL
pred vs b1
pred vs eddy
That's the answer that I was looking for... Thanks
Re: 440-1 vs B1
[Re: camastomcat]
#637558
03/13/10 01:13 PM
03/13/10 01:13 PM
B1Fish540
Flint, Michigan
heres the PSO intake...
Re: 440-1 vs B1
[Re: camdog440]
#637560
03/13/10 03:35 PM
03/13/10 03:35 PM
Posts: 6,295 U.S.
moparniac
U.S.
preet thin inbetween ports there. what you use for a gasket?
Mopar Performance
Re: 440-1 vs B1
[Re: moparniac]
#637562
03/13/10 04:21 PM
03/13/10 04:21 PM
Posts: 1,402 State of Corruption
camdog440
State of Corruption
That's what I thought too. I'm not sure which gasket I'm using yet... but it shouldn't be too much of a problem I do have a lot of port matching to do on the new Super Victor intake.
