E body rear frame end/shackle mount available? #636826
03/11/10 04:47 PM
03/11/10 04:47 PM
Canada
demon Offline OP
demon  Offline OP
Canada
On E bodies the rear frame rails swell up and rust
thru where the rear shackle is mounted. This is a seperate piece that slips into the frame rail and has the bumper mount holes and shackle tube built into it. Is this part available from anyone or just as part of the reproduction frame rails?
I don't need frame rails,just the part that inserts at the very rear. Thanks
Re: E body rear frame end/shackle mount available? [Re: demon] #636827
03/11/10 09:28 PM
03/11/10 09:28 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
I would like to know this as well .
Re: E body rear frame end/shackle mount available? [Re: moparmojo] #636828
03/12/10 12:58 PM
03/12/10 12:58 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I havn't seen just that piece available. I bought the rear frame rail sections for my car. They are around 27" long I think. You could always get those and use what you needed but they aren't cheap. You'd be throwing away most of it.
Re: E body rear frame end/shackle mount available? [Re: burdar] #636829
03/12/10 01:56 PM
03/12/10 01:56 PM
Canada
demon Offline OP
demon  Offline OP
Canada
yeah,I thought about buying those sections but you are right. They are kind of pricey for what you get. I may just have to do that though. Thanks
