Main bearing clearance problem #635901
03/10/10 06:46 PM
03/10/10 06:46 PM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
I installed my new King main bearings in my block and checked the clearance against my crank (stock forged) and I only have .0020" on three journals and .00019" and .00018" on the others. The block was honed and its dead on specs, crank has been polished, but it only has .0001"-.0004" wear after beaing polished.
How would be the best way to handle this? I was hoping to get at least .0025".
Re: Main bearing clearance problem [Re: '72CudaRacer] #635902
03/10/10 06:51 PM
03/10/10 06:51 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
what are you using to determine these clearances?
Re: Main bearing clearance problem [Re: '72CudaRacer] #635903
03/10/10 06:58 PM
03/10/10 06:58 PM
N of Detroit
DaveDudek Offline
DaveDudek  Offline
N of Detroit
On a street engine with a hyd cam I'd run what you have.
Dave Dudek
1st Factory Stock legal car in the 10`s!!! [/b]
FAST & Factory Stock Rules: www.fastraces.org
FAST 69 Hemi RR 9.98@139
Re: Main bearing clearance problem [Re: jamesc] #635904
03/10/10 07:04 PM
03/10/10 07:04 PM
Mooresburg, Tn
Mooresburg, Tn
A micrometer, a dial bore gauge and a calculater.
I've even got my machinist to come over last nite and check it. Still tight.
Re: Main bearing clearance problem [Re: DaveDudek] #635905
03/10/10 07:06 PM
03/10/10 07:06 PM
Mooresburg, Tn
Mooresburg, Tn
Dave, Its a drag race only engine (440) and a solid cam. If it was a street engine, I let'er eat. I just think its too tight for a bracket engine.
Re: Main bearing clearance problem [Re: DaveDudek] #635906
03/10/10 07:06 PM
03/10/10 07:06 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
.002-.003 is in spec. I'd say your fine. tighter tolerances mean you can run a lighter weight oil. I bet today's new engines run tighter then that!
you could have an error of .0001 - .0002 if there was a spec of dust or something when you measured.
**Photobucket sucks**
Re: Main bearing clearance problem [Re: 70Cuda383] #635907
03/10/10 07:42 PM
03/10/10 07:42 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
We don't run anything looser than .002 and never had a problem with bearings being too tight on street, drag or circle motors. I sure wouldn't worry about your readings. BTW
Re: Main bearing clearance problem [Re: '72CudaRacer] #635908
03/10/10 09:26 PM
03/10/10 09:26 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Brian,
What were the actual crank main dimensions?
RIP Monte Smith
Re: Main bearing clearance problem [Re: CompWedgeEngines] #635909
03/10/10 10:36 PM
03/10/10 10:36 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Sell the bearings and get some Clevite HXN's...problem solved
Re: Main bearing clearance problem [Re: Bob_Coomer] #635910
03/10/10 10:44 PM
03/10/10 10:44 PM
Mooresburg, Tn
Mooresburg, Tn
Bob, what does the hxn stand for? The X is .001" OS. Do you or anyone else know if 1) King has std.X mains 2) how does King fit compared to Clevite 77, tight? Or will Clevite Std. be the same problem?
Brian
Re: Main bearing clearance problem [Re: CompWedgeEngines] #635911
03/10/10 11:05 PM
03/10/10 11:05 PM
Mooresburg, Tn
Mooresburg, Tn
Brian,
Todd, I been tring to call you all day. No answer, mail box full. again.
Crank front to rear;
2.7498
2.7499
2.7499
2.7496
2.7496
Thanks, Brian
Re: Main bearing clearance problem [Re: '72CudaRacer] #635912
03/10/10 11:43 PM
03/10/10 11:43 PM
Syracuse,NY
Syracuse,NY
Yes, phone has been a little silly lately. It reached 40 degrees and now everyone thinks their engine should be done...lol
RIP Monte Smith
