Page 2 of 3 1 2 3
Re: I need a cram course on BB Darts. (20 questions) [Re: Commando1] #635854
03/11/10 05:33 PM
03/11/10 05:33 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Need an expert to check out your next ride? I am in the Keys right now heading back to Tampa tomorrow...
JB Rhinehart, Realist
A-Body's RULE!
Re: I need a cram course on BB Darts. (20 questions) [Re: rtman] #635855
03/11/10 05:40 PM
03/11/10 05:40 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Re: I need a cram course on BB Darts. (20 questions) [Re: RodStRace] #635856
03/11/10 06:54 PM
03/11/10 06:54 PM
South-Central (Sebring), FL
Commando1 Offline OP
go over to bigblockdarts for a bunch of info.
If you can't be bothered to research these due to ADD, there is no way you can build one!
I've searched ForABodiesOnly, BigBlockDarts, GTS Registry, etc, and Googled every combonation of key words possible. I did my due diligence first. I don't expect anybody to do my research for me.
Can't build one with A.D.D.? My friend, you don't understand A.D.D., then. It's an asset, not a disability like all these college brainwashed shrinks would have you believe.
Don't need no stinkin Ritalin....
AND, the reason I asked some of these questions is because I have three A-bodies I'm looking at and trying to figure out the best one to work with...
FWIW: I used to race a '67 Dart in the late sixties at N.E. Raceway. After 40 years, I CRS*
Again, Thanks to all.
*can't remember squat...
Re: I need a cram course on BB Darts. (20 questions) [Re: Commando1] #635857
03/11/10 07:03 PM
03/11/10 07:03 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
Hey look! Cows!
Down to just a blue car now.
Re: I need a cram course on BB Darts. (20 questions) [Re: 68HemiB] #635858
03/11/10 08:06 PM
03/11/10 08:06 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
okay, then!
~600 built in 1969 (440)
All auto
all 8.75
hard parts are the exhaust manifolds esp. left side
oil pan/pickup
left motor mount bracket and block that will work
radiator (I think)
wheels?
All this is if going STOCK.
obviously, headers, mount and an oil pan isn't going to keep a rodder/racer down!
There were 68-69 383s too. The B block fits better than an RB. More Bs were built too.
Re: I need a cram course on BB Darts. (20 questions) [Re: RodStRace] #635859
03/11/10 08:45 PM
03/11/10 08:45 PM
There's one last issue that has me confused.
A-body "K" member 2883984 was for the 383 w/o P.S in '68. 288399 was for the 383 WITH P.S. in '68.
WITH? So Norm did sell'em with P.S. The factory in '69 did not offer P.S even tho the 399 "K" member was used by the factory in '69. Go figure..
Re: I need a cram course on BB Darts. (20 questions) [Re: Commando1] #635860
03/11/10 09:11 PM
03/11/10 09:11 PM
Mass
charge70 Offline
charge70  Offline
Mass
Power steering wasn't offered on M-Codes due to the fact that the motor mount bracket is in the way where the p/s pump would be.383's could get p/s because they used a different bracket/actually the M-Code bracket is a modified 383 piece.Also,radiator,oil pan fan,pulleys ect. are all 383 issue parts. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: I need a cram course on BB Darts. (20 questions) [Re: charge70] #635861
03/11/10 09:50 PM
03/11/10 09:50 PM
I guess that is where I'm confused.
Why would/did the 440 have a different left side mount than the 383?
Is this to say that if one had an original 383 Dart, swapping in a 440 would be a problem w/o modifyiing the mount?
Am I wearing out our patience yet?
Re: I need a cram course on BB Darts. (20 questions) [Re: Commando1] #635862
03/11/10 09:54 PM
03/11/10 09:54 PM
MassHole Central
rtman Offline
rtman  Offline
MassHole Central
John Ah Ah has a '69 BB Dart and is very knowledgable...if you can get a hold of him
Re: I need a cram course on BB Darts. (20 questions) [Re: rtman] #635863
03/11/10 09:57 PM
03/11/10 09:57 PM
When he's not looking. I'm gonna steal it and use it as a reference car...
Re: I need a cram course on BB Darts. (20 questions) [Re: Commando1] #635864
03/11/10 11:16 PM
03/11/10 11:16 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
The A-body 383 used the 65 C-body mount and a special isolator. 440's did not have the two bosses for this mount so a special mount had to be used. I think I have pictures on my computer at work.
Re: I need a cram course on BB Darts. (20 questions) [Re: Jim_Lusk] #635865
03/12/10 01:00 AM
03/12/10 01:00 AM
Southern Michigan
Dartman440 Offline
Dartman440  Offline
Southern Michigan
Here is a b sheet
Re: I need a cram course on BB Darts. (20 questions) [Re: Dartman440] #635866
03/12/10 01:03 AM
03/12/10 01:03 AM
Southern Michigan
Dartman440 Offline
Dartman440  Offline
Southern Michigan
B sheet
Re: I need a cram course on BB Darts. (20 questions) [Re: Dartman440] #635867
03/12/10 01:04 AM
03/12/10 01:04 AM
Southern Michigan
Dartman440 Offline
Dartman440  Offline
Southern Michigan
The car
Re: I need a cram course on BB Darts. (20 questions) [Re: Dartman440] #635868
03/12/10 10:01 AM
03/12/10 10:01 AM
Anybody have a pic of the factory 440 exhaust manifolds?
Re: I need a cram course on BB Darts. (20 questions) [Re: Commando1] #635869
03/12/10 11:11 AM
03/12/10 11:11 AM
sst404b Offline
sst404b  Offline
You can't tell the difference between the 383 and the 440 unless they are side by side and the casting numbers
Ray
Re: I need a cram course on BB Darts. (20 questions) [Re: sst404b] #635870
03/12/10 12:56 PM
03/12/10 12:56 PM
Mass
charge70 Offline
charge70  Offline
Mass
Here are some pics that I have of the motor mounts and exhaust manifolds.
Re: I need a cram course on BB Darts. (20 questions) [Re: charge70] #635871
03/12/10 12:57 PM
03/12/10 12:57 PM
Mass
charge70 Offline
charge70  Offline
Mass
Motor mount-440
Re: I need a cram course on BB Darts. (20 questions) [Re: charge70] #635872
03/12/10 12:57 PM
03/12/10 12:57 PM
Mass
charge70 Offline
charge70  Offline
Mass
Motor mount-383
Re: I need a cram course on BB Darts. (20 questions) [Re: Dartman440] #635873
03/12/10 01:59 PM
03/12/10 01:59 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
Here is a b sheet
The window sticker shown: is for a different car, is a reproduction with mistakes, or BOTH!
What's the VIN or VON of either?
Page 2 of 3 1 2 3
