Re: I need a cram course on BB Darts. (20 questions)
[Re: RodStRace]
#635856
03/11/10 06:54 PM
03/11/10 06:54 PM
Posts: 9,336 South-Central (Sebring), FL
Commando1
go over to bigblockdarts for a bunch of info. If you can't be bothered to research these due to ADD, there is no way you can build one!
I've searched ForABodiesOnly, BigBlockDarts, GTS Registry, etc, and Googled every combonation of key words possible. I did my due diligence first. I don't expect anybody to do my research for me. ![](/ubbthreads/images/graemlins/thumbs.gif)
Can't build one with A.D.D.? My friend, you don't understand A.D.D., then. It's an asset, not a disability like all these college brainwashed shrinks would have you believe.
Don't need no stinkin Ritalin.... ![](/ubbthreads/images/graemlins/hammer.gif)
AND, the reason I asked some of these questions is because I have three A-bodies I'm looking at and trying to figure out the best one to work with...
FWIW: I used to race a '67 Dart in the late sixties at N.E. Raceway. After 40 years, I CRS*
Again, Thanks to all. ![](/ubbthreads/images/graemlins/thumbs.gif)
*can't remember squat...
[Re: 68HemiB]
#635858
03/11/10 08:06 PM
03/11/10 08:06 PM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
okay, then! ![](/ubbthreads/images/graemlins/thumbs.gif) ~600 built in 1969 (440) All auto all 8.75 hard parts are the exhaust manifolds esp. left side oil pan/pickup left motor mount bracket and block that will work radiator (I think) wheels? All this is if going STOCK. obviously, headers, mount and an oil pan isn't going to keep a rodder/racer down! There were 68-69 383s too. The B block fits better than an RB. More Bs were built too.
[Re: Commando1]
#635860
03/11/10 09:11 PM
03/11/10 09:11 PM
Posts: 603 Mass
charge70
Mass
Power steering wasn't offered on M-Codes due to the fact that the motor mount bracket is in the way where the p/s pump would be.383's could get p/s because they used a different bracket/actually the M-Code bracket is a modified 383 piece.Also,radiator,oil pan fan,pulleys ect. are all 383 issue parts. John.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: charge70]
#635861
03/11/10 09:50 PM
03/11/10 09:50 PM
Commando1
I guess that is where I'm confused. Why would/did the 440 have a different left side mount than the 383? Is this to say that if one had an original 383 Dart, swapping in a 440 would be a problem w/o modifyiing the mount?
Am I wearing out our patience yet?
[Re: rtman]
#635863
03/11/10 09:57 PM
03/11/10 09:57 PM
Commando1
John Ah Ah has a '69 BB Dart and is very knowledgable...if you can get a hold of him
When he's not looking. I'm gonna steal it and use it as a reference car... ![](/ubbthreads/images/graemlins/hammer.gif)
[Re: sst404b]
#635870
03/12/10 12:56 PM
03/12/10 12:56 PM
Posts: 603 Mass
charge70
Mass
Here are some pics that I have of the motor mounts and exhaust manifolds.
[Re: Dartman440]
#635873
03/12/10 01:59 PM
03/12/10 01:59 PM
Posts: 17,527 Las Vegas, NV
6bblgt
Las Vegas, NV
Here is a b sheet
The window sticker shown: is for a different car, is a reproduction with mistakes, or BOTH!
What's the VIN or VON of either?
