Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons [Re: autoxcuda] #63503
05/29/08 07:54 AM
05/29/08 07:54 AM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
you don't have to have the that bolt. i used a reg 1/2-20. but you will have to hold the other side when you tighten it up
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers
GarysMocars Legendary Dealer
Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons [Re: 65cuda] #63504
05/29/08 03:37 PM
05/29/08 03:37 PM
Spokane, WA
48Heap Offline
48Heap  Offline
Spokane, WA
you can buy a sway bar kit. another great thing about the spool mount is the sway bar goes through the k and doesn't hang below. also your not going to pull a motor mount apart.
I did something similar for my '63 Valiant, but I sectioned 1.5" from the middle and moved the mounts forward 2" instead. I wanted the spool mounts, better swaybar, and through bolt idler.
15 Chrysler 200S 3.6
15 Challenger R/T 6M STP
74 Duster 360 -> original 4 speed car
a.k.a. DionR
Re: 73-76 A-Body Spool Mount K-Frame, Pros/Cons [Re: 48Heap] #63505
05/29/08 05:08 PM
05/29/08 05:08 PM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
So the stupid question is, where do you get the bolts? I got the mounts but no bolts came with them.
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
