Re: Another Eagle cast crank broken (408 stroker)
[Re: Mike Swann]
#634697
08/27/11 07:06 AM
08/27/11 07:06 AM
Posts: 20,689 in a cattle trailer down by th...
Guitar Jones
I've seen that too, in fact the guy that did machine work for me had one in a 11.00/10.90 A body with an automatic and it broke the same way.
[Re: goldmember]
#634700
08/29/11 12:30 AM
08/29/11 12:30 AM
Posts: 9 ontario Canada
dr.mopar
ontario Canada
It doesn't take 500hp to run 10.90's @3200lbs. I tried to use an eagle cast crank in my daily driver truck,but in 10 minutes after it showed up I had in back in the box for return. I was not able to save my buddy as he used this crank for almost 2 seasons,running 11.00 @ 3200lbs then it came apart and destroyed a lot more than the crankshaft. Good luck.
I will agree to disagree, in my opinion it takes all of 500+ horsepower to run 10.90's in a 3200lbs door car and the need for a forged crank is obvious in such a fast car. If the friend got two yrs. out of the deal I would say he did pretty good considering the crank is on the ragged edge of its recommeded range.
[Re: dr.mopar]
#634702
08/29/11 12:54 AM
08/29/11 12:54 AM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
I will agree to disagree. It does not take a forged crank to withstand that output. Just a factory cast crank or a cast MP/Scat crank and you'll have far better odds of a reliable engine,rather than a potential disaster. The engine in the duster was less than 500 hp(yes, it was on the dyno),so give me some idea how long that crank might last @ 450hp,475hp,etc I'd love to know the answer.I'll just keep putting better cranks in my builds and sleep better.
[Re: goldmember]
#634703
08/29/11 01:29 AM
08/29/11 01:29 AM
dr.mopar
ontario Canada
Not all dyno's are created equal, just ask Hughes. At 450HP the eagle cranks are lasting a very long time, 7+ yrs. which is a long time in the life of most street strip rides. In fact I just got 7 yrs. out of a 360 which had two cylinders cracked. Was it the blocks falt these cyls cracked? Who knows, however it didn't help that I overheated it a yr. ago when it started leaking fluid. So which came first the crack, or the overheating which likely led to the cracks? What did I put back in? Another 360 because they make great drag motors with or without a stroker crank..
[Re: dr.mopar]
#634708
10/01/11 09:30 PM
10/01/11 09:30 PM
dr.mopar
ontario Canada
Latest update, our 408 with the eagle cast crank went 11.93 @ 111.4 in our 3600lb b-body satellite today. Boy am I happy..
[Re: dr.mopar]
#634709
10/01/11 11:29 PM
10/01/11 11:29 PM
Guitar Jones
And of course when it breaks you'll update us on that as well right?
[Re: goldmember]
#634711
10/02/11 01:00 AM
10/02/11 01:00 AM
Guitar Jones
We can hope he does. I'll make a deal with him,I'll report back when the stock 360 cast crank breaks,it's been 100,000 street miles and makes 10 second passes without a second thought @ 3600lbs. We have hundreds of passes on this junk so you better get busy.
You can see the numbers in my sig, that's 15 years of 7000 rpm shifts on a stock 360 crank. If he get's even a quarter of that I'll be surprised.
[Re: Guitar Jones]
#634712
10/02/11 10:42 AM
10/02/11 10:42 AM
dr.mopar
ontario Canada
Lets see, race car compared to street car, kind of an apple and oranges thing don't you think. W5's? It better run 10's. If you want to compare apples to apples lets do it. I unbolted all the parts from my J headed 360 and installed them on a street 408. Installed in the same car and it picked up 6 tenths. Worth it? certainly. Bottom line, no one said the 360 crank wasn't good, in fact it is awesome. I'm just saying to the anti eagle crowd there is nothing wrong with the 4" Eagle cast crank if used as recommended..
