Page 2 of 3 1 2 3
Re: Another Eagle cast crank broken (408 stroker) [Re: MR_P_BODY] #634677
03/09/10 09:50 PM
03/09/10 09:50 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Cast cranks are for lawnmowers.
Re: Another Eagle cast crank broken (408 stroker) [Re: BobR] #634678
03/09/10 10:40 PM
03/09/10 10:40 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
Cast cranks are for .......
.... cars with TORQUE CONVERTERS !
Re: Another Eagle cast crank broken (408 stroker) [Re: dOc !] #634679
03/10/10 12:15 AM
03/10/10 12:15 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
And 48 inch mower decks.
Re: Another Eagle cast crank broken (408 stroker) [Re: dart_73_br] #634680
03/10/10 11:04 AM
03/10/10 11:04 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
Dram,tell me something new.Why does a stock 360 crank hold 450 hp and not this cast crank?
Because old stock cranks was not made in China!
Seems to me that the 4" stroke vs. the stock 3.58" stroke might have something to do with it. Less overlap between the mains and the rod journals. I bet a cast 4" crank with 340 mains would be really bad.
Floyd Lippencott IV
Re: Another Eagle cast crank broken (408 stroker) [Re: tubtar] #634681
03/10/10 11:08 AM
03/10/10 11:08 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
something very miniscule to consider..
but heat cycles makes a crank stonger.
so to a tiney degree..a used crank main gain
a tiny bit more strength from it having been heat cycled.
i aggree that crank was destined to fail.
when its mass produced youll have that percentage
airbubbles,metalergy,,ect...its gonna happen in a cast crank..to some degree..
fwiw..
cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Another Eagle cast crank broken (408 stroker) [Re: cheapstreetdustr] #634682
03/10/10 11:12 AM
03/10/10 11:12 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I don't understand how a person could put an Eagle 4" cast crank in any build. It only takes a few seconds to see what you have.LOL If you must use a cast crank there are better options.
Re: Another Eagle cast crank broken (408 stroker) [Re: goldmember] #634683
03/10/10 11:40 AM
03/10/10 11:40 AM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
Just throwing this out there,....I've got an estimated 500-525 hp with my 4" CAST crank (mopar performance) with a pretty heavy bob wieght. Car is heavy (3350lbs). Has been together for about 7 years now. Runs 11.0's with automatic, and I just put a stick in it last year (still tuning), but hoping to run low 11's with the stick.
One time, I spun a rod bearing. Had the crank cut and they said that it was slightly bent, very slightly. They tried to straighten it, and the machine shop said that they couldn't believe how STRONG this crank was. They said it was about as strong as some (other makes) forged cranks they has seen.
Never had a problem with the crank! (340 mains, too)
Re: Another Eagle cast crank broken (408 stroker) [Re: LAR_414] #634684
03/10/10 11:55 AM
03/10/10 11:55 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I have seen the MP cast crank take some abuse. Mid 10's most weekends for 7 plus years(did break last year in dramatic fashion,LOL). The MP and the Eagle are far from similar.
Re: Another Eagle cast crank broken (408 stroker) [Re: goldmember] #634685
03/10/10 12:01 PM
03/10/10 12:01 PM
AndyF Offline
AndyF  Offline
These days there is only a small difference in total engine cost to go forged. I suppose things were different years ago. At one time the cast stroker crank was the only thing available to people on a budget but that is no longer the case.
Re: Another Eagle cast crank broken (408 stroker) [Re: AndyF] #634686
03/10/10 12:33 PM
03/10/10 12:33 PM
Buenos Aires, ARGENTINA
madmax2 Offline OP
madmax2  Offline OP
The crankshaft was purchased in 2007, forged crankshafts were much more expensive than today.
and we thought we would hold less than 500 HP without problems.
'70 Dodge GTX sb 418ci (Early A-body),
Lunati Solid cam 270°/243°@.050/.548", Edelbrock Heads, Weiand X-CELerator,
Holley Terminator EFI, Tremec 6 sp manual, 3.90:1, TTI Headers.
Re: Another Eagle cast crank broken (408 stroker) [Re: madmax2] #634687
03/10/10 12:44 PM
03/10/10 12:44 PM
Sao Paulo, Brazil
dart_73_br Offline
dart_73_br  Offline
Sao Paulo, Brazil
Yeah, this cranks are supposed to handle 500hp with no problems...
Re: Another Eagle cast crank broken (408 stroker) [Re: dart_73_br] #634688
03/10/10 05:11 PM
03/10/10 05:11 PM
just like the saftey on your guns..
"Its a mechanical device made by man,,prone to
failure"
still remember that 26yrs ago from the test...
good for something...
cheapst
[image][/image]
Re: Another Eagle cast crank broken (408 stroker) [Re: dart_73_br] #634689
03/10/10 05:36 PM
03/10/10 05:36 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
There are lots of reasons parts fail, The easy thing to do is blame the part After 20 or so years rebuilding and repairing diesels I have seen more parts fail from improper assembly or the wrong part used for the application than defective parts,Now I am not saying that cheep eagle cranks are good < looked like a pourous casting> from pics, but I do know a chevy builder that uses 4 inch arm cast cranks in 650 hp range with out failure and I think they are eagle made
Re: Another Eagle cast crank broken (408 stroker) [Re: emarine01] #634690
03/10/10 05:40 PM
03/10/10 05:40 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
The Eagle cranks for Chevys do seem to hold up better than the pieces they make for the Mopar guys.
Re: Another Eagle cast crank broken (408 stroker) [Re: madmax2] #634691
03/10/10 05:42 PM
03/10/10 05:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What was the balancer on it and did you have it
balanced or did you have the crank company balance it
Re: Another Eagle cast crank broken (408 stroker) [Re: MR_P_BODY] #634692
03/10/10 09:52 PM
03/10/10 09:52 PM
Colo Springs, CO
DconD100 Offline
DconD100  Offline
Colo Springs, CO
Do the engines spin the opposite direction down there in Argentina?
My eagle 4 inch arm is holding up at about 450 observed hp. It internally balanced with the I-beam rods, and I have an ATI balancer...sure hope it keeps on trucking! I only have about 5000 miles, and about 50 quartemile passes on it.
Pump Gas Small Blocks Rock! 11.53 @ 116mph E85 408 at 8500 ft da, 3605 pound truck, 3.91s, street driven
Re: Another Eagle cast crank broken (408 stroker) [Re: DconD100] #634693
08/26/11 12:28 AM
08/26/11 12:28 AM
ontario Canada
dr.mopar Offline
dr.mopar  Offline
ontario Canada
Nice, it should stay together for a long time, you are producing the Horepower range the crank was intended for and probably shifting below the 6000rpm range.
My personal experience, eagle cast crank is a thing of beauty, light, affordable, easy to internally balance with no mallory, and the I beam eagle rods are the best value in the the market.
Doc
Re: Another Eagle cast crank broken (408 stroker) [Re: dr.mopar] #634694
08/26/11 01:15 PM
08/26/11 01:15 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
to the original poster:
did you have any balancers breaking before this crank broke?
asking since i have observed a crazy behavior from a friends cast eagle crank and im afriad his crank is about to do what yours already did, at about the same powerlevel.
Re: Another Eagle cast crank broken (408 stroker) [Re: 1Fast340] #634695
08/27/11 12:40 AM
08/27/11 12:40 AM
ontario Canada
dr.mopar Offline
dr.mopar  Offline
ontario Canada
I wonder how many of these failed cranks are due to other problems as Scat points out with their units.
First, have these units been balanced externally? Or balanced at all.
If so have they been balanced properly by a pro?
Second, assembly? Were the balancers installed correctly? Or pounded on with a hammer.
Bottom line is these engines are often assembled by backyard mechanics with backyard practices. Often leading to mechanical failures.
People suggesting they broke a crank in the burn out box is just silly. Simply that was the hair that broke the camels back. So what really lead to the crank failure? Over revving? Who knows, I am sure there are many reasons for the failures, however my experience has been if built properly, within the limits outlined by the manufacters both Scat and Eagle make good products.
Why more eagle failures? They probably out sell Scat two to one.
Re: Another Eagle cast crank broken (408 stroker) [Re: madmax2] #634696
08/27/11 02:26 AM
08/27/11 02:26 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Lack of nickel as an alloying agent in the Eagle casting, imo. You see cracking in a lot in sockets and wrenches(hand tools) as well. They will add a lot of carbon to get it strong, but without the nickel, no fatigue life or fracture toughness.
The price of nickel has skyrocketed over the years and has been disappearing in non quality controlled metals, like Eagle cranks.
Ask Eagle if you can see the assay report on the casting lot. Bwahahahahaha.
8.30's @3400 lbs
Page 2 of 3 1 2 3
