How do I clean my fuel tank #634504
03/08/10 09:36 PM
03/08/10 09:36 PM
Boise Idaho
Boise Chall Offline OP
Boise Idaho
I'm working on a 73 Satellite / Roadrunner that's been sitting in a field for 15 years after I pulled the motor I noticed what looked like melted black plastic on the floor after seeing it a couple times I realized it was coming from the fuel line. I had some on my fingers and it washes off with just water. It's still coming out of the fuel line so I know it's not hard yet but what's the best way to clean this stuff out plan to pull the tank remove the sending unit and dump out as much of the crap as I can and blow out the fuel lines with a blow gun but what will get everything clean enough for a new motor? carb cleaner? Sea foam ? paint gun cleaning solvent? what do you guys use?
Re: How do I clean my fuel tank [Re: Boise Chall] #634505
03/08/10 10:12 PM
03/08/10 10:12 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I would blow out the lines, then run mineral spirits or some other solvent through them to flush out the crud. then inspect the lines to see how they look. it might be easier to simply replace all the lines, expecially if they look really rusty under the car.
as for the tank...is this a budget deal or a "do it right" deal? on the cheap, drop the tank, pour in the same minieral spirits/solvent and swish it around for awhile. then try an engine degreaser foam that you let soak, then rinse away with water. let the water dry and re-install the tank.
or, take it somewhere and have them boil out the inside of the tank, then have it sealed up from the inside so that it won't leak.
unless the tank ALSO looks very rusty, in which case...buy a new tank.
**Photobucket sucks**
Re: How do I clean my fuel tank [Re: 70Cuda383] #634506
03/09/10 12:49 AM
03/09/10 12:49 AM
Boise Idaho
Boise Idaho
It has no rust on the fuel lines or on the tank. I forgot about taking it to a radiator shop to have it boiled out and sealed. I will do what you said with the mineral spirits or solvent in the fuel lines. Oh and yes this is a budget deal this car will just be a cruiser. My Challenger was supposed to be a cruiser/ street beater but I got carried away while I was building it although I still beat the crap out of it I don't want to hurt it if you know what I mean.
Re: How do I clean my fuel tank [Re: Boise Chall] #634507
03/09/10 12:58 AM
03/09/10 12:58 AM
woodcrest, CA
magnum440d100 Offline
woodcrest, CA
on my 63 d100, I took the tank out, and sloshed CLR around in it..its been like that for 2 years now
Re: How do I clean my fuel tank [Re: magnum440d100] #634508
03/09/10 01:36 AM
03/09/10 01:36 AM
IN
ahy Offline
ahy  Offline
IN
Eastwood has a 3 step cleaning and sealing kit for tanks. Strong detergent, acid, strong solvent (acetone) and a sealer. It cleans out the crud and prevents any future rust contamination. I've used it and it worked well.
Re: How do I clean my fuel tank [Re: ahy] #634509
03/09/10 01:39 AM
03/09/10 01:39 AM
Jamestown, Indiana
James74 Offline
James74  Offline
Jamestown, Indiana
I know you said its a budget deal, but I saw new tanks for $150 at the Indy meet saturday. FYI...
Re: How do I clean my fuel tank [Re: James74] #634510
03/09/10 08:02 AM
03/09/10 08:02 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
I have cleaned some nasty ones out by using a bout 10 gallons of E85 gas and putting about 2 or 3 gallons at a time in and sloshing around and letting sit a little while and then redueing. came out clean as a whistle.
Re: How do I clean my fuel tank [Re: MoparforLife] #634511
03/09/10 08:28 AM
03/09/10 08:28 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I used POR15s tank kit on my 65.The fuel had sat in it for probally 6 years and was nasty.Followed the instructions on the kit.That was at least 12 years ago.Still looks like a new tank inside.I did replace my fuel lines also.Rocky
Chrysler Firepower
Re: How do I clean my fuel tank [Re: therocks] #634512
03/09/10 09:29 AM
03/09/10 09:29 AM
Tucson Arizona
Hardy Offline
Hardy  Offline
Tucson Arizona
Yes POR15 works good I treated a tank and sealed it with the kit I bought. No problems, takes a few hours to do right
Re: How do I clean my fuel tank [Re: Hardy] #634513
03/09/10 11:14 AM
03/09/10 11:14 AM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
chemtool B12 solvent sold at parts stores works great to remove old varnished gas
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
Re: How do I clean my fuel tank [Re: aarcuda] #634514
03/09/10 02:08 PM
03/09/10 02:08 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I let my tank sit in the sun for a few days.Cleaned it with their cleaner then let it sit in hot sun 2 days.Then used their sealer and it sat for another 2 days in hot sun.Looks better than any new tank.Rocky
Chrysler Firepower
Re: How do I clean my fuel tank [Re: Boise Chall] #634515
03/09/10 02:52 PM
03/09/10 02:52 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Maybe worthwhile to call and see how much a radiator shop would charge to clean it out.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: How do I clean my fuel tank [Re: HealthServices] #634516
03/09/10 03:08 PM
03/09/10 03:08 PM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
I had mine boiled out and sealed. Worked well for many (8) years. Then, the sealer, a red substance started to degrade and go thru the fuel lines causing blockage. Changed to a new tuel tank. So, clean and boil out but I wouldn't pay the extra for sealing. If it needs a seal, you need a new tank.
Re: How do I clean my fuel tank [Re: BELVEDERE67] #634517
03/09/10 05:57 PM
03/09/10 05:57 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Dont use these sealers as mentioned, they will not last. Take a nonflamable cleaner such as simple green and dump it in there with a chain with flat links and shake it for a while. If that doesnt get it, replace the tank, they arent that expensive. I do motorcycle tanks all the time and never have any flaking rust problems.
Re: How do I clean my fuel tank [Re: CYACOP] #634518
03/09/10 08:03 PM
03/09/10 08:03 PM
Boise Idaho
Boise Idaho
I called a radiator shop today they want $65-$225 to boil it and seal it. I found another tank thats clean but has a small hole in the bottom of it like somebody ran over something with it. it looks like I'll be soldering a penny over the hole
Re: How do I clean my fuel tank [Re: Boise Chall] #634519
03/09/10 08:08 PM
03/09/10 08:08 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I put a sealer in a rusty (surface rust) motorcycle gas tank and will never put sealer in anything again. The sealer peeled off and caused more problems than it was worth.
Just clean it real good or replace it
Re: How do I clean my fuel tank [Re: roadhazard] #634520
03/09/10 11:36 PM
03/09/10 11:36 PM
IN
ahy Offline
ahy  Offline
IN
To prevent peeling sealer, the prep is critical. The Eastwood kit (detergent, acid, acetone) preps the metal for the sealer so it sticks. Sealer only is trouble as posted above.
Sandblasting also works but is rare and a bit expensive. I had a '47 PW tank sandblasted and sealed and its been trouble free for 5 years.
Re: How do I clean my fuel tank [Re: ahy] #634521
03/09/10 11:41 PM
03/09/10 11:41 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
If your on a budget have a rad shop boil it out. Then use the POR sealer. But then again by the time your done you will spend almost as much as a new tank. There pretty cheap for new ones.
Re: How do I clean my fuel tank [Re: Dougsmopars] #634522
03/10/10 08:30 AM
03/10/10 08:30 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree the old sealers would peel.The POR 15 dosent.Mine has been in for over 10 years and its like the day I put it in.Its a 3 stage kit and you have to follow the instructions.When I did mine tanks werent readily avaliable.But Id still use their lit again.Rocky
Chrysler Firepower
